The process of monitoring the user experience of your native mobile apps is fundamentally different from monitoring browser-based web applications. This is because mobile-app monitoring involves the compilation, packaging, and shipment of a monitoring library along with your own mobile application package.
To monitor your mobile app with Dynatrace, you'll need to instrument OneAgent for iOS, which provides visibility into activity lifecycle, user actions, web requests, crashes, and more.
For the supported iOS versions, check Technology support | Mobile app Real User Monitoring.
Starting with OneAgent for iOS version 8.335, Dynatrace stopped supporting Xcode 16. We only support Xcode 26+.
Also, be aware that Apple's App Store submission guidelines will restrict support to applications built with a minimum of Xcode 26 around April 2026.
Starting with OneAgent for iOS version 8.343, Dynatrace will stop supporting iOS 12, iOS 13, and iOS 14. The new minimum supported version is iOS 15. Version 8.341 is the last OneAgent for iOS version to support iOS 12 - 14.
