Set up Dynatrace on Docker
  • Latest Dynatrace
  • 1-min read
  • Published Jun 25, 2021
Dynatrace offers full-featured Docker monitoring, as well as generic container monitoring for containerd and CRI-O, giving you all the same deep monitoring capabilities for containerized applications that are available for non-containerized applications.
Integrations
If you want to use Docker outside a container platform, there are two methods to monitor applications using OneAgent:
  • Set up OneAgent for application-only
  • Set up Dynatrace as a Docker container
In a typical scenario, container orchestration and management tools such as Kubernetes, OpenShift, and Cloud Foundry use Docker, containerd, or CRI-O as a container runtime. If you're running one of these platforms, follow the appropriate deployment instructions: Kubernetes, OpenShift, Cloud Foundry, or Fargate. Any platform that uses containers can also be monitored using the application-only approach.
Related topics
  • Containers
