The credential vault is a centralized repository where you securely store and manage credentials (username-password pairs, certificates, or tokens) used by synthetic monitors (browser and HTTP), Extensions, and AppEngine apps.
To access the credential vault, go to Credential Vault.
Credentials are stored in Advanced Encryption Standard–encrypted form (AES-256) in the credential vault. Access to the data is encrypted using TLS 1.3. The contents of credentials in the vault are not visible to any user, including the creator; they are visible only to the synthetic monitors that reference them. Users with access to the credential vault can overwrite some or all credentials—check Who can edit or overwrite a credential for details on overwriting credentials.
The credential vault is developed entirely by Dynatrace and resides on the Dynatrace Cluster. See the key Synthetic Monitoring components involved in credential vault security and communication below. All communication among key components is encrypted.
Dynatrace Cluster
Function: The Dynatrace Cluster hosts the credential vault in the cluster database as part of your Dynatrace monitoring environment.
Credential access and security: All credentials are created, changed, and deleted on the Dynatrace Cluster. The credential vault is environment-specific and is not shared across environments. Only the cluster has access to the credential vault and resolves credential IDs to actual values when preparing monitors for execution.
Communication: All communication among key components is encrypted. If a monitor needs to be executed from a private Synthetic location, the cluster resolves and sends credentials as part of the monitor configuration to the Synthetic engine on creation and update (when monitors or referenced credentials are created or updated), not before every execution. In the same way, if a monitor needs to be executed from a public Synthetic location, the cluster resolves and sends credentials as part of the monitor configuration to the public Synthetic infrastructure on creation or update.
Synthetic engine
Function: The Synthetic engine executes synthetic monitors on both private and public Synthetic locations and has access to monitor configurations and any resolved credentials in order to do so.
Communication: The Synthetic engine does not communicate directly with the credential vault or see its contents. On private Synthetic locations, the Synthetic engine requests and retrieves the schedule of monitors to be executed and their configurations (with resolved credentials) from the Dynatrace Cluster on creation or update, that is, when monitors or referenced credentials are created or updated. On public Synthetic locations, this same communication takes place with the public Synthetic infrastructure. All communication among key components is encrypted.
Credential access and security: The Synthetic engine has access only to those resolved credentials that are part of the monitors it needs to execute; it can't retrieve or view any other credentials. All monitor configurations are stored in Synthetic engine memory (with no persistence layers involved) for as long as the monitors need to be executed. If a monitor is turned off or deleted, its configuration is flushed from Synthetic engine memory.
All credential data is exchanged via internal API secured with API token, and access is highly restricted at the network-protocol level. Each individual monitor execution is isolated; no memory or scripts are shared among executions.
Public Synthetic infrastructure
Function: This includes all infrastructure required to execute monitors from public locations. The public Synthetic infrastructure stores and communicates information to public Synthetic locations for the execution of synthetic monitors.
Communication: If a monitor needs to be executed from a public Synthetic location, the Dynatrace Cluster sends the monitor configuration (with resolved credentials) to the public Synthetic infrastructure on creation or update (when monitors or referenced credentials are created or updated), not before every execution. The public Synthetic infrastructure then serves the same information to public Synthetic locations as the cluster does to private Synthetic locations. All communication among key components is encrypted.
Credential access and security: Monitor configurations with resolved credentials are encrypted and persisted in the Synthetic database. Credentials aren't persisted directly as credentials but only as part of monitor configurations.
Dynatrace manages and secures the entire public Synthetic infrastructure and public Synthetic locations. Access is only possible from within the Dynatrace corporate network and is secured by SSH key-based authentication. Access to private keys is limited to a small group of Dynatrace employees.
To view and write to the credential vault, a user requires the View environment permission at the environment level.
If you have only the View environment permission (and no other higher permission such as Change monitoring settings), you can:
To overwrite and delete credentials owned by other users, you require the Change monitoring settings permission at the environment level.
Users with View environment or Change monitoring settings at the management-zone level can only view public credentials in the vault; they can't create credentials in the vault.
To create or edit synthetic monitors, you require the Change monitoring settings permission at the environment or management-zone level.
See Credential vault API below for the token scope required to access the credential vault via API.
Each credential has access levels. When a credential is initially created (in the vault or when creating or editing a synthetic monitor), it's designated as Owner only.
The owner of a credential may turn off the Owner access only toggle in the vault to change a credential's access level to All. The owner may also limit access to the credential to specified users by providing a comma-separated list of usernames (which can include email addresses set as usernames) in Users with access, for example, username1, username2, userx@company.com. The credential's access level is then set to Shared.
To give other users access to your credential, turn off Owner access only. If you turn off Owner access only and don't limit credential access to the usernames listed in Users with access, the credential is accessible to all users.
Other users can change a credential's access level by becoming the new owner of the credential and overwriting it with new authentication details.
Users with the View environment permission at the environment level can only overwrite credentials they own.
A credential's access level (Owner only, Shared, or All) determines who can use it in a synthetic monitor. An owner-only credential is one that only the credential owner can use, for example, to create or edit a synthetic monitor. A shared credential is available to the specified user list for use, for example, in synthetic monitors and apps. A public credential is available to all users.
Read more below in Work with credentials.
A credential scope represents the use case for a credential; you can select multiple scopes at once. The table below describes each scope and the credential types it applies to.
| Scope | Credential types | Description |
Synthetic |
| For credentials to be used in synthetic monitors |
Extension authentication |
| Credentials used by extensions (data sources) to authenticate to a resource and retrieve data |
Extension validation |
| Used to sign extensions |
AppEngine |
| To provide access to credentials from Dynatrace apps (latest Dynatrace) and ad hoc functions (without app context) |
Select the AppEngine scope to permit built-in apps from the latest Dynatrace to access a credential. This scope is available for all credential types.
When you first select the scope for a credential, the access defaults to All applications in Dynatrace apps with access.
To limit credential access to specific apps, place your cursor in the field to select from a list of available built-in apps in your environment. You can select multiple apps, one at a time. Credential access is now limited to the apps you select.
Optionally, turn on Allow access without app context. This allows ad hoc functions, for example, from Workflows
and Notebooks
, to access your credential outside the context of an app.
You can't allow access without app context for credentials with public access. It means that Dynatrace won't allow you to create new credentials if they meet all three conditions mentioned below:
Credentials created before Dynatrace version 1.337+) with such a configuration will work as is unless you start editing them. When editing these credentials, you won't be able to save your changes until at least one of the conditions above is no longer met. For example, you can save such a credential after you add a user to the Users with access list or turn on Owner access only.
For a credential to be accessible by a user within the context of an app, both the user and the app must have access to the credential separately. If user X has access to the credential but app A does not, user X can't use the credentials from app A.
Go to Credential Vault to see all the credentials in your environment.
Users with the View environment permission at the environment level can only view public credentials and credentials they own.
The available credential types for synthetic monitoring are username-password pairs, certificates, and tokens. Username-password pairs can be synchronized with external vault systems—read more in External vault integration in Classic.
Each credential is listed with an icon identifying the Type, Name, the monitors it's Used by, Owner, Access level, Scope, and controls to edit and Delete it.
You can filter the list by Type, Name, Access, Owner, or Scope (select Synthetic).
You can see the ID and properties of a credential, but credential content can't be viewed; it can only be overwritten. The contents of credentials are visible only to the synthetic monitors, apps, or ad hoc functions referencing them.
If you don't have access to a credential, you'll see a message about using or overwriting the credential. See Who can edit or overwrite a credential below.
Select HTTP or Browser next to a credential to see the associated monitors on the Synthetic page. The list is automatically filtered by the credential name and owner.
Optional Turn on local playback of Synthetic browser monitors without entering credentials so that your users can play back browser clickpaths locally without having to enter any associated tokens or username-password pairs that they have access to. If turned off, the user needs to enter associated credentials in order to play back browser clickpaths locally. Note that only users with access to the credentials in a browser clickpath can play it back.
You can create credentials directly in the vault or in the course of synthetic monitor creation and editing.
You can create the following types of credentials for synthetic monitoring.
Username and password pairs can be used for basic as well as web-form authentication, in single-URL browser monitors, browser clickpaths, and HTTP monitors.
Username-password pairs in the Dynatrace credential vault can be synchronized with an external vault (Azure Key Vault, HashiCorp Vault, or CyberArk Vault). Synthetic monitors containing these credentials use the synchronized values obtained from the external vaults—read more in External vault integration in Classic.
To create login credentials in the vault
Select Add new credential in the upper-right corner.
Select User and password as the Credential type.
Select Synthetic for Credential scope. Read more about other Credential scopes, including the AppEngine scope.
Edit the default Credential name to identify your new credential properly.
If synchronizing this username-password pair with an external vault (Synchronization with external vault), follow the instructions in External vault integration in Classic.
Enter the Username and Password. The password is automatically masked as you type. Note that these fields don't appear for synchronized credentials.
Supported username formats
<username> and <domain>\<username><username><username>Optional Provide a Description.
Credentials are set to Owner access only by default. Turn off this toggle to make the credential accessible to other users. Optionally, limit access to the credential to specified users by providing a comma-separated list of usernames in Users with access. Read more in Owner-only, shared, and public credentials and Work with credentials.
Save your credential. Note that once created, the contents of credentials can only be overwritten.
Certificate credentials are used in HTTP monitors—you can add a client certificate to an HTTP request.
To create a certificate credential in the vault
Select Certificate as the Credential type.
Upload
a Certificate file. Allowed file formats are PFX, P12, and PEM.
If you run into issues with using a PEM certificate, see Convert PEM certificates below.
Enter the Certificate password.
Provide a Credential name and optional Description.
If you run into issues when creating a credential using a PEM certificate, consider converting the certificate file to the P12 or PFX formats, which are endorsed for Java standards.
Use the openssl command-line utility to convert the certificate file. For example, the following command converts a PEM certificate to the P12 format.
openssl pkcs12 -export -in /path/to/certificate.pem -out /path/to/certificate.p12
A token is a generic credential type with a single value. You can create tokens in the credential vault and insert references to them from HTTP monitors—in request URLs, HTTP header values, and in the request body. In clickpaths, you can insert a token ID in the Keystroke event.
Token credentials in the Dynatrace credential vault can be synchronized with an external vault (Azure Key Vault or HashiCorp Vault). Synthetic monitors containing these credentials use the synchronized values obtained from the external vaults—read more in External vault integration in Classic.
To create a token credential in the credential vault
The access level of a credential (owner only or public) determines who can use the credential to:
Users can delete/overwrite credentials and change credential access levels.
These operations require the Change monitoring settings permission.
When creating a monitor or editing an existing monitor that doesn't have associated credentials, you can:
Use an existing credential stored in the vault in the monitor—you can select public credentials or credentials that you own or are shared with you.
Create a new credential as part of the monitor creation/editing workflow. The credential is automatically designated as owner only and stored in the vault. After you create a credential, note that another user may change a credential's access level by becoming the new owner and overwriting it with new authentication details.
You can store passwords captured in recorded clickpaths to the vault (with a companion username or as a single-value token). These are stored as owner only. See how to use the Keystroke event.
Alternatively, you can edit the recorded event to use an existing credential from the vault or create one of your own from within the clickpath.
If a browser monitor (clickpath or single URL) is associated with a restricted credential (owner only or shared with a few users), any user can make changes to certain fields, even if they don't have access to the credential used. You can edit monitor name, device emulation settings, wait conditions, frequency, locations, outage alerting, performance thresholds, metrics, connected applications, validation, and HTTP status codes to be ignored. And, of course, you can change a token or user ID/password credential. You can create a credential within monitor settings in edit mode. You'll need to change all credentials in the monitor to ones that you have access to. Note that replacing another user's credential with one you have access to is irreversible.
Controls that you cannot edit—such as the URL, switching on/off HTTP authentication, adding or deleting clickpath events, data entry in Keystroke, and Advanced setup in monitor settings—are grayed out or display an error message when you attempt to save changes, whether in script or UI mode.
If an HTTP monitor is associated with restricted credential (owner only or shared with a few users), any user can make changes to certain fields, even if they don't have access to the credential used. You can edit monitor name, locations, validation, thresholds, and, of course, change a certificate or a UID/password pair. You can edit and change the credentials in a URL, header value, or request body. You can create a credential within monitor settings in edit mode. You'll need to change all credentials in the monitor to ones that you have access to. Note that replacing another user's credential with one you have access to is irreversible.
Controls that you cannot edit such as the request URL, HTTP method, pre-execution script, post-execution script, HTTP headers, request body, the follow redirects option, and adding/deleting HTTP requests are grayed out or display an error message when you attempt to save changes, whether in script or UI mode.
If you're unable to edit a monitor that has an associated credential, you can search for the credential owner to discuss changes or request access. You can also overwrite another user's credential.
The contents of credentials are visible only to the synthetic monitors, apps, or ad hoc functions referencing them. You can see the ID and properties of a credential in the vault, but the credential content can only be overwritten.
Users with the Change monitoring settings permission at the environment level can overwrite another user's credential, and, thereby, take over ownership. In the course of overwriting (or anytime after), they can then also change the access level of the credential (whether shared, public, or owner only).
Users with the View environment permission at the environment level can only overwrite or delete credentials they own.
Select a credential and select Overwrite credential or Overwrite certificate.
In order to overwrite a credential, you need to provide the full set of authentication details. This means that you can only overwrite a credential (and take ownership) by providing a new username-password pair, a new certificate, or a new token. In the case of username-password pairs, if you leave the password blank, the old password value is not retained.
Users with the Change environment settings permission at the environment level can delete another user's credentials—if you delete a credential that's used in a monitor, that monitor becomes inactive.
The credential vault displays all credentials in your environment with owner name and access level. You can sort and filter credentials by Owner in the credential vault.
You can search for credential owners in Synthetic Classic. You can filter for monitors using a specific credential (Associated credential) and/or the credential owners (Associated credential owner). Note that these filters are only available when at least one credential from the vault is used in a monitor. The filters show you all the credentials (and their owners) currently used in monitors.
When you open a monitor using an owner-only or shared credential, the owner's name is highlighted.
You can access the credential vault by API, which lends itself to a vast range of automation use cases.
Read more about token scopes in the API authentication Documentation topic.
