Collect the connection pool performance, usage and availability metrics for Oracle Weblogic.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Apache Commons.
Java Metric Extensions 2.0 (JMX).There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Connection Pools WebLogic extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
License consumption is based on the number of connection pools and server runtimes. The following formula provides approximate metric data points ingested per minute with all feature sets enabled. Note that this is only an approximation as the true numbers will depend heavily on the traffic you experience.
(22 * # of WebLogic Connection Pools and Server Runtimes) + (1 * # of WebLogic Connection Pools and Config Paths) + (3 * # of WebLogic Connection Pools, Server Runtimes, and JMS Server Runtimes) + (2 * # of Server runtimes)
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| Stuck thread count | weblogic.stuckThreads | — |
| Hogging thread count | weblogic.hoggingThreads | — |
| Active connections | weblogic.connectionPool.activeConnectionsCurrentCount | — |
| Current capacity | weblogic.connectionPool.currCapacity | — |
| Leaked connections | weblogic.connectionPool.leakedConnectionCount.count | — |
| Available connections (idle) | weblogic.connectionPool.numAvailable | — |
| Waiting for connections | weblogic.connectionPool.waitingForConnectionCurrentCount | — |
| Failed connection requests | weblogic.connectionPool.failedReserveRequestCount.count | — |
| Reconnection failures | weblogic.connectionPool.failuresToReconnectCount.count | — |
| Requests for connections | weblogic.connectionPool.reserveRequestCount.count | — |
| Current message count | weblogic.currentMessages | — |
| Pending message count | weblogic.pendingMessages | — |
| Total message count | weblogic.totalMessages | — |
| Max capacity | weblogic.connectionPool.maxCapacity | — |
| Statement cache size | weblogic.connectionPool.prepStmtCacheCurrentSize | — |
| Statement cache hits | weblogic.connectionPool.prepStmtCacheHitCount.count | — |
| Statement cache misses | weblogic.connectionPool.prepStmtCacheMissCount.count | — |
