Monitor C3P0 JDBC connection pool performance, usage, and availability in Java applications to detect leaks and exhaustion issues.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Wildfly, and C3P0.
Java Metric Extensions 2.0 (JMX).When activating your extension using a monitoring configuration, you can limit monitoring to one of the feature sets. To work properly, the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Max Pool Size | c3p0.connectionPool.maxPoolSize | — |
| Num Connections | c3p0.connectionPool.numConnections | — |
| Num Busy Connections | c3p0.connectionPool.numBusyConnections | — |
| Num Unclosed Orphaned Connections | c3p0.connectionPool.numUnclosedOrphanedConnections | — |
| Num Idle Connections | c3p0.connectionPool.numIdleConnections | — |
| Num Active threads | c3p0.connectionPool.threadPoolNumActiveThreads | — |
| Thread Pool Size | c3p0.connectionPool.threadPoolSize | — |
