Connection Pools Apache Commons extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor Apache Commons DBCP connection pool performance, usage, and availability for Java JDBC applications using JMX metrics.
Get started
Overview
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Apache Commons.
Use cases
  • Collect the connection pool performance, usage and availability metrics for Apache Commons.
Feature sets
Durations
Metric nameMetric keyDescription
Max borrow wait durationapache.commons.connectionPool.maxBorrowWaitDurationGets the maximum time a thread has waited to borrow objects from the pool
Max wait durationapache.commons.connectionPool.maxWaitDurationGets the maximum duration the borrowObject() method should block before throwing an exception when the pool is exhausted and getBlockWhenExhausted() is true. When less than 0, the borrowObject() method may block indefinitely
Mean active durationapache.commons.connectionPool.meanActiveDurationGets the mean time objects are active for based on the last MEAN_TIMING_STATS_CACHE_SIZE objects returned to the pool
Mean borrowed wait durationapache.commons.connectionPool.meanBorrowWaitDurationGets the mean time threads wait to borrow an object based on the last MEAN_TIMING_STATS_CACHE_SIZE objects borrowed from the pool
Mean idle durationapache.commons.connectionPool.meanIdleDurationGets the mean time objects are idle for based on the last MEAN_TIMING_STATS_CACHE_SIZE objects borrowed from the pool
Min evictable idle durationapache.commons.connectionPool.minEvictableIdleDurationGets the minimum amount of time an object may sit idle in the pool before it is eligible for eviction by the idle object evictor. When non-positive, no objects will be evicted from the pool due to idle time alone.
Connections
Borrowed countapache.commons.connectionPool.borrowedCount.countGets the total number of objects successfully borrowed from the pool
Created countapache.commons.connectionPool.createdCount.countGets the total number of objects created for this pool
Destroyed countapache.commons.connectionPool.destroyedCount.countGets the total number of objects destroyed by this pool
Max totalapache.commons.connectionPool.maxTotalGets the maximum number of objects that can be allocated by the pool (checked out to clients, or idle awaiting checkout) at a given time. When negative, there is no limit to the number of objects that can be managed by the pool at one time
Idle countapache.commons.connectionPool.numIdleGets the number of instances currently idle in this pool
Active countapache.commons.connectionPool.numActiveGets the number of instances currently borrowed from this pool. Returns a negative value if this information is not available
Waiters countapache.commons.connectionPool.numWaitersGets an estimate of the number of threads currently blocked waiting for an object from the pool
Returned countapache.commons.connectionPool.returnedCount.countGets the total number of objects returned to this pool over the lifetime of the pool. This excludes attempts to return the same object multiple times
Hub
Explore in Dynatrace Hub
Related tags
ApplicationJMXConnection poolApacheInfrastructure Observability
