Built-in classic metrics
  • Dynatrace Classic
  • Reference
  • 3-min read
  • Published Sep 03, 2020
Each Dynatrace-supported technology offers multiple "built-in" metrics. Built-in metrics are included in the product out of the box, in some cases as part of built-in extensions.
Metrics that are based on OneAgent or ActiveGate extensions (prefix ext:) and calculated metrics (prefix calc:) are custom metrics, not built-in metrics; DDU consumption for these metrics can vary widely depending on how you use Dynatrace.
The ext: prefix is used by metrics from OneAgent extensions and ActiveGate extensions, and also by classic metrics for AWS integration.
Despite the naming similarities, AWS integration metrics are not based on extensions.
To view all the metrics available in your environment, use the GET metrics API call. We recommend the following query parameters:
  • pageSize=500—to obtain the largest possible number of metrics in one response.
  • fields=displayName,unit,aggregationTypes,dduBillable—to obtain the same set of fields as you see in these tables.
  • Depending on which metrics you want to query, one of the following values for the metricSelector parameter:
    • metricSelector=ext:*—to obtain all metrics coming from extensions.
    • metricSelector=calc:*—to obtain all calculated metrics.
    • Omit the parameter to obtain all the metrics of your environment.
The sections below describe inconsistencies or limitations identified for Dynatrace built-in metrics.
Application and billing metrics for mobile and custom apps
The Other applications metrics section contains metrics captured for mobile and custom applications. These metrics, which start with builtin:apps.other, are captured without the indication whether it's a mobile or a custom application. However, the "billing" application metrics, which start with builtin:billing.apps, are split for these application types:
  • Mobile apps:
    • builtin:billing.apps.mobile.sessionsWithoutReplayByApplication
    • builtin:billing.apps.mobile.sessionsWithReplayByApplication
    • builtin:billing.apps.mobile.userActionPropertiesByMobileApplication
  • Custom apps:
    • builtin:billing.apps.custom.sessionsWithoutReplayByApplication
    • builtin:billing.apps.custom.userActionPropertiesByDeviceApplication
Billing metrics count both billed and unbilled sessions
The following "billing" metrics for session count are actually the sum of billed and unbilled user sessions.
  • builtin:billing.apps.web.sessionsWithReplayByApplication
  • builtin:billing.apps.web.sessionsWithoutReplayByApplication
If you want to get only the number of billed sessions, set the Type filter to Billed.
Different measurement units for request duration metrics
Different measurement units are used for similar request duration metrics for mobile and custom apps.
builtin:apps.other.keyUserActions.requestDuration.os is measured in microseconds while other request duration metrics (builtin:apps.other.requestTimes.osAndVersion and builtin:apps.other.requestTimes.osAndProvider) are measured in milliseconds.
Custom vs built-in metrics
Custom metrics are defined or installed by the user, while built-in metrics are by default part of the product. Certain built-in metrics are disabled by default and, if turned on, will consume DDUs. These metrics cover a wide range of supported technologies, including Apache Tomcat, NGINX, Couchbase, RabbitMQ, Cassandra, Jetty, and many others.
A custom metric is a new type of metric that offers a user-provided metric identifier and unit of measure. The semantics of custom metrics are defined by you and aren't included in the default OneAgent installation. Custom metrics are sent to Dynatrace through various interfaces. Following the definition of a custom metric, the metric can be reported for multiple monitored components. Each component’s custom metric results in a separate timeseries.
For example, if you define a new custom metric called Files count that counts the newly created files within a directory, this new metric can be collected either for one host or for two individual hosts. Collecting the same metric for two individual hosts results in two timeseries of the same custom metric type, as shown in the example below:
Custom metrics
Custom metrics
For the purposes of calculating monitoring consumption, collecting the same custom metric for two hosts counts as two separate custom metrics.
Applications
Custom
Metric keyName and descriptionUnitAggregations
builtin:apps.custom.reportedErrorCount
Reported error count (by OS, app version) [custom]
The number of all reported errors.
Countautovalue
builtin:apps.custom.sessionCount
Session count (by OS, app version) [custom]
The number of captured user sessions.
Countautovalue
Mobile
builtin:apps.mobile.sessionCount
Session count (by OS, app version, crash replay feature status) [mobile]
Countautovalue
builtin:apps.mobile.sessionCount.sessionReplayStatus
Session count (by OS, app version, full replay feature status) [mobile]
Countautovalue
builtin:apps.mobile.reportedErrorCount
Reported error count (by OS, app version) [mobile]
Countautovalue
Web applications
builtin:apps.web.action.affectedUas
User action rate - affected by JavaScript errors (by key user action, user type) [web]
The percentage of key user actions with detected JavaScript errors.
Percent (%)autovalue
builtin:apps.web.action.apdex
Apdex (by key user action) [web]
The average Apdex rating for key user actions.
autoavg
builtin:apps.web.action.count.custom.browser
Action count - custom action (by key user action, browser) [web]
The number of custom actions that are marked as key user actions.
Countautovalue
builtin:apps.web.action.count.load.browser
Action count - load action (by key user action, browser) [web]
The number of load actions that are marked as key user actions.
Countautovalue
builtin:apps.web.action.count.xhr.browser
Action count - XHR action (by key user action, browser) [web]
The number of XHR actions that are marked as key user actions.
Countautovalue
builtin:apps.web.action.cumulativeLayoutShift.load.userType
Cumulative Layout Shift - load action (by key user action, user type) [web]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions that are marked as key user actions.
autoavgcountmaxmedianminpercentilesum
builtin:apps.web.action.cumulativeLayoutShift.load.userType.geo
Cumulative Layout Shift - load action (by key user action, geolocation, user type) [web]
builtin:apps.web.action.cumulativeLayoutShift.load.browser
Cumulative Layout Shift - load action (by key user action, browser) [web]
builtin:apps.web.action.domInteractive.load.browser
DOM interactive - load action (by key user action, browser) [web]
The time taken until a page's status is set to "interactive" and it's ready to receive user input. Calculated for load actions that are marked as key user actions.
Millisecondautoavgcountmaxmedianminpercentilesum
builtin:apps.web.action.duration.custom.browser
Action duration - custom action (by key user action, browser) [web]
The duration of custom actions.
builtin:apps.web.action.duration.load.browser
Action duration - load action (by key user action, browser) [web]
The duration of load actions that are marked as key user actions.
builtin:apps.web.action.duration.xhr.browser
Action duration - XHR action (by key user action, browser) [web]
The duration of XHR actions that are marked as key user actions.
builtin:apps.web.action.firstByte.load.browser
Time to first byte - load action (by key user action, browser) [web]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.firstByte.xhr.browser
Time to first byte - XHR action (by key user action, browser) [web]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions that are marked as key user actions.
builtin:apps.web.action.firstInputDelay.load.userType
First Input Delay - load action (by key user action, user type) [web]
The time from the first interaction with a page to when the user agent can respond to that interaction. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.firstInputDelay.load.userType.geo
First Input Delay - load action (by key user action, geolocation, user type) [web]
builtin:apps.web.action.firstInputDelay.load.browser
First Input Delay - load action (by key user action, browser) [web]
builtin:apps.web.action.largestContentfulPaint.load.userType
Largest Contentful Paint - load action (by key user action, user type) [web]
The time taken to render the largest element in the viewport. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.largestContentfulPaint.load.userType.geo
Largest Contentful Paint - load action (by key user action, geolocation, user type) [web]
builtin:apps.web.action.largestContentfulPaint.load.browser
Largest Contentful Paint - load action (by key user action, browser) [web]
builtin:apps.web.action.loadEventEnd.load.browser
Load event end - load action (by key user action, browser) [web]
The time taken to complete the load event of a page. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.loadEventStart.load.browser
Load event start - load action (by key user action, browser) [web]
The time taken to begin the load event of a page. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.networkContribution.load
Network contribution - load action (by key user action, user type) [web]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.networkContribution.xhr
Network contribution - XHR action (by key user action, user type) [web]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions that are marked as key user actions.
builtin:apps.web.action.responseEnd.load.browser
Response end - load action (by key user action, browser) [web]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.responseEnd.xhr.browser
Response end - XHR action (by key user action, browser) [web]
The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions that are marked as key user actions.
builtin:apps.web.action.serverContribution.load
Server contribution - load action (by key user action, user type) [web]
The time spent on server-side processing for a page. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.serverContribution.xhr
Server contribution - XHR action (by key user action, user type) [web]
The time spent on server-side processing for a page. Calculated for XHR actions that are marked as key user actions.
builtin:apps.web.action.speedIndex.load.browser
Speed index - load action (by key user action, browser) [web]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.visuallyComplete.load.browser
Visually complete - load action (by key user action, browser) [web]
The time taken to fully render content in the viewport. Calculated for load actions that are marked as key user actions.
builtin:apps.web.action.visuallyComplete.xhr.browser
Visually complete - XHR action (by key user action, browser) [web]
The time taken to fully render content in the viewport. Calculated for XHR actions that are marked as key user actions.
builtin:apps.web.action.countOfErrors
Error count (by key user action, user type, error type, error origin) [web]
The number of detected errors that occurred during key user actions.
Countautovalue
builtin:apps.web.action.countOfUserActionsWithErrors
User action count with errors (by key user action, user type) [web]
The number of key user actions with detected errors.
Countautovalue
builtin:apps.web.action.jsErrorsDuringUa
JavaScript errors count during user actions (by key user action, user type) [web]
The number of detected JavaScript errors that occurred during key user actions.
Countautovalue
builtin:apps.web.action.jsErrorsWithoutUa
JavaScript error count without user actions (by key user action, user type) [web]
The number of detected standalone JavaScript errors (occurred between key user actions).
Countautovalue
builtin:apps.web.action.percentageOfUserActionsAffectedByErrors
User action rate - affected by errors (by key user action, user type) [web]
The percentage of key user actions with detected errors.
builtin:apps.web.actionCount.custom.browser
Action count - custom action (by browser) [web]
The number of custom actions.
Countautovalue
builtin:apps.web.actionCount.load.browser
Action count - load action (by browser) [web]
The number of load actions.
Countautovalue
builtin:apps.web.actionCount.xhr.browser
Action count - XHR action (by browser) [web]
The number of XHR actions.
Countautovalue
builtin:apps.web.actionCount.category
Action count (by Apdex category) [web]
The number of user actions.
Countautovalue
builtin:apps.web.actionCount.summary
Action with key performance metric count (by action type, geolocation, user type) [web]
The number of user actions that have a key performance metric and mapped geolocation.
Countautovalue
builtin:apps.web.actionDuration.custom.browser
Action duration - custom action (by browser) [web]
builtin:apps.web.actionDuration.load.browser
Action duration - load action (by browser) [web]
The duration of load actions.
builtin:apps.web.actionDuration.xhr.browser
Action duration - XHR action (by browser) [web]
The duration of XHR actions.
builtin:apps.web.actionsPerSession
Actions per session average (by users, user type) [web]
The average number of user actions per user session.
Countautoavg
builtin:apps.web.activeSessions
Session count - estimated active sessions (by users, user type) [web]
The estimated number of active user sessions. An active session is one in which a user has been confirmed to still be active at a given time. For this high-cardinality metric, the HyperLogLog algorithm is used to approximate the session count.
Countautovalue
builtin:apps.web.activeUsersEst
User count - estimated active users (by users, user type) [web]
The estimated number of unique active users. For this high-cardinality metric, the HyperLogLog algorithm is used to approximate the user count.
Countautovalue
builtin:apps.web.affectedUas
User action rate - affected by JavaScript errors (by user type) [web]
The percentage of user actions with detected JavaScript errors.
builtin:apps.web.apdex.userType
Apdex (by user type) [web]
autoavg
builtin:apps.web.apdex.userType.geoBig
Apdex (by geolocation, user type) [web]
The average Apdex rating for user actions that have a mapped geolocation.
autoavg
builtin:apps.web.bouncedSessionRatio
Bounce rate (by users, user type) [web]
The percentage of sessions in which users viewed only a single page and triggered only a single web request. Calculated by dividing single-page sessions by all sessions.
builtin:apps.web.conversionRate
Conversion rate - sessions (by users, user type) [web]
The percentage of sessions in which at least one conversion goal was reached. Calculated by dividing converted sessions by all sessions.
builtin:apps.web.converted
Session count - converted sessions (by users, user type) [web]
The number of sessions in which at least one conversion goal was reached.
Countautovalue
builtin:apps.web.cumulativeLayoutShift.load.userType
Cumulative Layout Shift - load action (by user type) [web]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions.
builtin:apps.web.cumulativeLayoutShift.load.userType.geo
Cumulative Layout Shift - load action (by geolocation, user type) [web]
builtin:apps.web.cumulativeLayoutShift.load.browser
Cumulative Layout Shift - load action (by browser) [web]
builtin:apps.web.domInteractive.load.browser
DOM interactive - load action (by browser) [web]
The time taken until a page's status is set to "interactive" and it's ready to receive user input. Calculated for load actions.
builtin:apps.web.endedSessions
Session count - estimated ended sessions (by users, user type) [web]
The number of completed user sessions.
Countautovalue
builtin:apps.web.event.count.rageClick
Rage click count [web]
The number of detected rage clicks.
Countautovalue
builtin:apps.web.firstByte.load.browser
Time to first byte - load action (by browser) [web]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions.
builtin:apps.web.firstByte.xhr.browser
Time to first byte - XHR action (by browser) [web]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions.
builtin:apps.web.firstInputDelay.load.userType
First Input Delay - load action (by user type) [web]
The time from the first interaction with a page to when the user agent can respond to that interaction. Calculated for load actions.
builtin:apps.web.firstInputDelay.load.userType.geo
First Input Delay - load action (by geolocation, user type) [web]
builtin:apps.web.firstInputDelay.load.browser
First Input Delay - load action (by browser) [web]
builtin:apps.web.largestContentfulPaint.load.userType
Largest Contentful Paint - load action (by user type) [web]
The time taken to render the largest element in the viewport. Calculated for load actions.
builtin:apps.web.largestContentfulPaint.load.userType.geo
Largest Contentful Paint - load action (by geolocation, user type) [web]
builtin:apps.web.largestContentfulPaint.load.browser
Largest Contentful Paint - load action (by browser) [web]
builtin:apps.web.loadEventEnd.load.browser
Load event end - load action (by browser) [web]
The time taken to complete the load event of a page. Calculated for load actions.
builtin:apps.web.loadEventStart.load.browser
Load event start - load action (by browser) [web]
The time taken to begin the load event of a page. Calculated for load actions.
builtin:apps.web.networkContribution.load
Network contribution - load action (by user type) [web]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions.
builtin:apps.web.networkContribution.xhr
Network contribution - XHR action (by user type) [web]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions.
builtin:apps.web.responseEnd.load.browser
Response end - load action (by browser) [web]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions.
builtin:apps.web.responseEnd.xhr.browser
Response end - XHR action (by browser) [web]
The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions.
builtin:apps.web.serverContribution.load
Server contribution - load action (by user type) [web]
The time spent on server-side processing for a page. Calculated for load actions.
builtin:apps.web.serverContribution.xhr
Server contribution - XHR action (by user type) [web]
The time spent on server-side processing for a page. Calculated for XHR actions.
builtin:apps.web.sessionDuration
Session duration (by users, user type) [web]
The average duration of user sessions.
Microsecondautoavg
builtin:apps.web.speedIndex.load.browser
Speed index - load action (by browser) [web]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions.
builtin:apps.web.startedSessions
Session count - estimated started sessions (by users, user type) [web]
The number of started user sessions.
Countautovalue
builtin:apps.web.visuallyComplete.load.browser
Visually complete - load action (by browser) [web]
The time taken to fully render content in the viewport. Calculated for load actions.
builtin:apps.web.visuallyComplete.xhr.browser
Visually complete - XHR action (by browser) [web]
The time taken to fully render content in the viewport. Calculated for XHR actions.
builtin:apps.web.countOfErrors
Error count (by user type, error type, error origin) [web]
The number of detected errors.
Countautovalue
builtin:apps.web.countOfErrorsDuringUserActions
Error count during user actions (by user type, error type, error origin) [web]
The number of detected errors that occurred during user actions.
Countautovalue
builtin:apps.web.countOfStandaloneErrors
Standalone error count (by user type, error type, error origin) [web]
The number of detected standalone errors (occurred between user actions).
Countautovalue
builtin:apps.web.countOfUserActionsWithErrors
User action count - with errors (by user type) [web]
The number of user actions with detected errors.
Countautovalue
builtin:apps.web.errorCountForDavis
Error count for Davis (by user type, error type, error origin, error context)) [web]
The number of errors that were included in Davis AI problem detection and analysis.
Countautovalue
builtin:apps.web.interactionToNextPaint
Interaction to next paint
Millisecondautocountmaxmedianminpercentile
builtin:apps.web.jsErrorsDuringUa
JavaScript error count - during user actions (by user type) [web]
The number of detected JavaScript errors that occurred during user actions.
Countautovalue
builtin:apps.web.jsErrorsWithoutUa
JavaScript error count - without user actions (by user type) [web]
The number of detected standalone JavaScript errors (occurred between user actions).
Countautovalue
builtin:apps.web.percentageOfUserActionsAffectedByErrors
User action rate - affected by errors (by user type) [web]
The percentage of user actions with detected errors.
Mobile and custom apps
builtin:apps.other.apdex.osAndGeo
Apdex (by OS, geolocation) [mobile, custom]
The Apdex rating for all captured user actions.
autovalue
builtin:apps.other.apdex.osAndVersion
Apdex (by OS, app version) [mobile, custom]
autovalue
builtin:apps.other.crashAffectedUsers.os
User count - estimated users affected by crashes (by OS) [mobile, custom]
The estimated number of unique users affected by a crash. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of users.
Countautovalue
builtin:apps.other.crashAffectedUsers.osAndVersion-std
User count - estimated users affected by crashes (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.crashAffectedUsersRate.os
User rate - estimated users affected by crashes (by OS) [mobile, custom]
The estimated percentage of unique users affected by a crash. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of users.
builtin:apps.other.crashCount.osAndGeo
Crash count (by OS, geolocation) [mobile, custom]
The number of detected crashes.
Countautovalue
builtin:apps.other.crashCount.osAndVersion
Crash count (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.crashCount.osAndVersion-std
Countautovalue
builtin:apps.other.crashFreeUsersRate.os
User rate - estimated crash free users (by OS) [mobile, custom]
The estimated percentage of unique users not affected by a crash. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of users.
builtin:apps.other.keyUserActions.apdexValue.os
Apdex (by key user action, OS) [mobile, custom]
The Apdex rating for all captured key user actions.
autovalue
builtin:apps.other.keyUserActions.count.osAndApdex
Action count (by key user action, OS, Apdex category) [mobile, custom]
The number of captured key user actions.
Countautovalue
builtin:apps.other.keyUserActions.duration.os
Action duration (by key user action, OS) [mobile, custom]
The duration of key user actions.
Microsecondautoavgcountmaxmedianminpercentilesum
builtin:apps.other.keyUserActions.reportedErrorCount.os
Reported error count (by key user action, OS) [mobile, custom]
The number of reported errors for key user actions.
Countautovalue
builtin:apps.other.keyUserActions.requestCount.os
Request count (by key user action, OS) [mobile, custom]
The number of captured web requests associated with key user actions.
Countautovalue
Request duration (by key user action, OS) [mobile, custom]
The duration of web requests for key user actions. Be aware that this metric is measured in microseconds while other request duration metrics for mobile and custom apps are measured in milliseconds.
builtin:apps.other.keyUserActions.requestErrorCount.os
Request error count (by key user action, OS) [mobile, custom]
The number of detected web request errors for key user actions.
Countautovalue
builtin:apps.other.keyUserActions.requestErrorRate.os
Request error rate (by key user action, OS) [mobile, custom]
The percentage of web requests with detected errors for key user actions
builtin:apps.other.newUsers.os
New user count (by OS) [mobile, custom]
The number of users that launched the application(s) for the first time. The metric is tied to specific devices, so users are counted multiple times if they install the application on multiple devices. The metric doesn't distinguish between multiple users that share the same device and application installation.
Countautovalue
builtin:apps.other.requestCount.osAndProvider
Request count (by OS, provider) [mobile, custom]
The number of captured web requests.
Countautovalue
builtin:apps.other.requestCount.osAndVersion
Request count (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.requestErrorCount.osAndProvider
Request error count (by OS, provider) [mobile, custom]
The number of detected web request errors.
Countautovalue
builtin:apps.other.requestErrorCount.osAndVersion
Request error count (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.requestErrorRate.osAndProvider
Request error rate (by OS, provider) [mobile, custom]
The percentage of web requests with detected errors.
builtin:apps.other.requestErrorRate.osAndVersion
Request error rate (by OS, app version) [mobile, custom]
Request duration (by OS, provider) [mobile, custom]
The duration of web requests.
Request duration (by OS, app version) [mobile, custom]
builtin:apps.other.sessionCount.agentVersionAndOs
Session count (by agent version, OS) [mobile, custom]
Countautovalue
builtin:apps.other.sessionCount.osAndCrashReportingLevel
Session count (by OS, crash reporting level) [mobile, custom]
Countautovalue
builtin:apps.other.sessionCount.osAndDataCollectionLevel
Session count (by OS, data collection level) [mobile, custom]
Countautovalue
builtin:apps.other.sessionCount.osAndGeo
Session count - estimated (by OS, geolocation) [mobile, custom]
The estimated number of captured user sessions. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of sessions.
Countautovalue
builtin:apps.other.sessionCount.osAndVersion-std
Session count (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.uaCount.geoAndApdex
Action count (by geolocation, Apdex category) [mobile, custom]
The number of captured user actions.
Countautovalue
builtin:apps.other.uaCount.osAndApdex
Action count (by OS, Apdex category) [mobile, custom]
Countautovalue
builtin:apps.other.uaCount.osAndVersion
Action count (by OS, app version) [mobile, custom]
Countautovalue
builtin:apps.other.uaDuration.osAndVersion
Action duration (by OS, app version) [mobile, custom]
The duration of user actions.
builtin:apps.other.userCount.osAndGeo
User count - estimated (by OS, geolocation) [mobile, custom]
The estimated number of unique users that have a mapped geolocation. The metric is based on 'internalUserId'. When 'dataCollectionLevel' is set to 'performance' or 'off', 'internalUserId' is changed at each app start. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of users.
Countautovalue
builtin:apps.other.userCount.osAndVersion-std
User count - estimated (by OS, app version) [mobile, custom]
The estimated number of unique users. The metric is based on 'internalUserId'. When 'dataCollectionLevel' is set to 'performance' or 'off', 'internalUserId' is changed at each app start. For this high cardinality metric, the HyperLogLog algorithm is used to approximate the number of users.
Countautovalue
Billing
Applications
Session count - billed and unbilled [custom]
The number of billed and unbilled user sessions. To get only the number of billed sessions, set the "Type" filter to "Billed".
Countautovalue
Total user action and session properties
The number of billed user action and user session properties.
Countautovalue
Session count - billed and unbilled - with Session Replay [mobile]
The number of billed and unbilled user sessions that include Session Replay data. To get only the number of billed sessions, set the "Type" filter to "Billed".
Countautovalue
Session count - billed and unbilled [mobile]
The total number of billed and unbilled user sessions (with and without Session Replay data). To get only the number of billed sessions, set the "Type" filter to "Billed".
Countautovalue
Countautovalue
Session count - billed and unbilled - with Session Replay [web]
Countautovalue
Session count - billed and unbilled - without Session Replay [web]
The number of billed and unbilled user sessions that do not include Session Replay data. To get only the number of billed sessions, set the "Type" filter to "Billed".
Countautovalue
builtin:billing.apps.web.userActionPropertiesByApplication
Countautovalue
Custom events classic
builtin:billing.custom_events_classic.usage
(DPS) Total Custom Events Classic billing usage
The number of custom events ingested aggregated over all monitored entities. Custom events include events sent to Dynatrace via the Events API or events created by a log event extraction rule. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.custom_events_classic.usage_by_entity
(DPS) Custom Events Classic billing usage by monitored entity
The number of custom events ingested split by monitored entity. Custom events include events sent to Dynatrace via the Events API or events created by a log event extraction rule. For details on the events billed, refer to the usage_by_event_info metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.custom_events_classic.usage_by_event_info
(DPS) Custom Events Classic billing usage by event info
The number of custom events ingested split by event info. Custom events include events sent to Dynatrace via the Events API or events created by a log event extraction rule. The info contains the context of the event plus the configuration ID. For details on the related monitored entities, refer to the usage_by_entity metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Custom metrics classic
builtin:billing.custom_metrics_classic.raw.usage_by_metric_key
(DPS) Recorded metric data points per metric key
The number of reported metric data points split by metric key. This metric does not account for included metric data points available to your environment.
Countautovalue
builtin:billing.custom_metrics_classic.usage
(DPS) Total billed metric data points
The total number of metric data points after deducting the included metric data points. This is the rate-card value used for billing. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.custom_metrics_classic.usage.foundation_and_discovery
(DPS) Total metric data points billable for Foundation & Discovery hosts
The number of metric data points billable for Foundation & Discovery hosts.
Countautovalue
builtin:billing.custom_metrics_classic.usage.fullstack_hosts
(DPS) Total metric data points billed for Full-Stack hosts
The number of metric data points billed for Full-Stack hosts. To view the unadjusted usage per host, use builtin:billing.full_stack_monitoring.metric_data_points.ingested_by_host . This trailing metric is reported at 15-minute intervals with up to a 15-minute delay.
Countautovalue
builtin:billing.custom_metrics_classic.usage.infrastructure_hosts
(DPS) Total metric data points billed for Infrastructure-monitored hosts
The number of metric data points billed for Infrastructure-monitored hosts. To view the unadjusted usage per host, use builtin:billing.infrastructure_monitoring.metric_data_points.ingested_by_host . This trailing metric is reported at 15-minute intervals with up to a 15-minute delay.
Countautovalue
builtin:billing.custom_metrics_classic.usage.other
(DPS) Total metric data points billed by other entities
The number of metric data points billed that cannot be assigned to a host. The values reported in this metric are not eligible for included metric deduction and will be billed as is. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. o view the monitored entities that consume this usage, use the other_by_entity metric.
Countautovalue
builtin:billing.custom_metrics_classic.usage.other_by_entity
(DPS) Billed metric data points reported and split by other entities
The number of billed metric data points split by entities that cannot be assigned to a host. The values reported in this metric are not eligible for included metric deduction and will be billed as is. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Custom traces classic
builtin:billing.custom_traces_classic.usage
(DPS) Total Custom Traces Classic billing usage
The number of spans ingested aggregated over all monitored entities. A span is a single operation within a distributed trace, ingested into Dynatrace. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.custom_traces_classic.usage_by_entity
(DPS) Custom Traces Classic billing usage by monitored entity
The number of spans ingested split by monitored entity. A span is a single operation within a distributed trace, ingested into Dynatrace. For details on span types, refer to the usage_by_span_type metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.custom_traces_classic.usage_by_span_type
(DPS) Custom Traces Classic billing usage by span type
The number of spans ingested split by span type. A span is a single operation within a distributed trace, ingested into Dynatrace. Span kinds can be CLIENT, SERVER, PRODUCER, CONSUMER or INTERNAL For details on the related monitored entities, refer to the usage_by_entity metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
DDU
builtin:billing.ddu.events.byDescription
DDU events consumption by event info
License consumption of Davis data units by events pool split by event info
autovalue
builtin:billing.ddu.events.byEntity
DDU events consumption by monitored entity
License consumption of Davis data units by events pool split by monitored entity
autovalue
builtin:billing.ddu.events.total
Total DDU events consumption
Sum of license consumption of Davis data units aggregated over all monitored entities for the events pool
autovalue
builtin:billing.ddu.log.byDescription
DDU log consumption by log path
License consumption of Davis data units by log pool split by log path
autovalue
builtin:billing.ddu.log.byEntity
DDU log consumption by monitored entity
License consumption of Davis data units by log pool split by monitored entity
autovalue
builtin:billing.ddu.log.total
Total DDU log consumption
Sum of license consumption of Davis data units aggregated over all logs for the log pool
autovalue
builtin:billing.ddu.metrics.byEntity
DDU metrics consumption by monitored entity
License consumption of Davis data units by metrics pool split by monitored entity
autovalue
builtin:billing.ddu.metrics.byEntityRaw
DDU metrics consumption by monitored entity w/o host-unit included DDUs
License consumption of Davis data units by metrics pool split by monitored entity (aggregates host-unit included metrics, so value might be higher than actual consumption)
autovalue
builtin:billing.ddu.metrics.byMetric
Reported metrics DDUs by metric key
Reported Davis data units usage by metrics pool split by metric key
autovalue
builtin:billing.ddu.metrics.total
Total DDU metrics consumption
Sum of license consumption of Davis data units aggregated over all metrics for the metrics pool
autovalue
builtin:billing.ddu.serverless.byDescription
DDU serverless consumption by function
License consumption of Davis data units by serverless pool split by Amazon Resource Names (ARNs)
autovalue
builtin:billing.ddu.serverless.byEntity
DDU serverless consumption by service
License consumption of Davis data units by serverless pool split by service
autovalue
builtin:billing.ddu.serverless.total
Total DDU serverless consumption
Sum of license consumption of Davis data units aggregated over all services for the serverless pool
autovalue
builtin:billing.ddu.traces.byDescription
DDU traces consumption by span type
License consumption of Davis data units by traces pool split by SpanKind, as defined in OpenTelemetry specification
autovalue
builtin:billing.ddu.traces.byEntity
DDU traces consumption by monitored entity
License consumption of Davis data units by traces pool split by monitored entity
autovalue
builtin:billing.ddu.traces.total
Total DDU traces consumption
Sum of license consumption of Davis data units aggregated over all monitored entities for the traces pool
autovalue
builtin:billing.ddu.includedMetricDduPerHost
DDU included per host
Included Davis data units per host
autovalue
builtin:billing.ddu.includedMetricPerHost
DDU included metric data points per host
Included metric data points per host
autovalue
Events
builtin:billing.events.business_events.ingest.usage
[Deprecated] (DPS) Business events usage - Ingest & Process
Business events Ingest & Process usage, tracked as bytes ingested within the hour. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay. [Deprecated] This metric is replaced by billing usage events.
Byteautovalue
builtin:billing.events.business_events.query.usage
[Deprecated] (DPS) Business events usage - Query
Business events Query usage, tracked as bytes read within the hour. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay. [Deprecated] This metric is replaced by billing usage events.
Byteautovalue
builtin:billing.events.business_events.retain.usage
[Deprecated] (DPS) Business events usage - Retain
Business events Retain usage, tracked as total storage used within the hour, in bytes. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay. [Deprecated] This metric is replaced by billing usage events.
Byteautoavgmaxmin
Foundation and discovery
builtin:billing.foundation_and_discovery.metric_data_points.ingested
(DPS) Ingested metric data points for Foundation & Discovery
The number of metric data points aggregated over all Foundation & Discovery hosts.
Countautovalue
builtin:billing.foundation_and_discovery.metric_data_points.ingested_by_host
(DPS) Ingested metric data points for Foundation & Discovery per host
The number of metric data points split by Foundation & Discovery hosts. See further details.
Countautovalue
builtin:billing.foundation_and_discovery.usage
(DPS) Foundation & Discovery billing usage
The total number of host-hours being monitored by Foundation & Discovery, counted in 15 min intervals.
Countautovalue
builtin:billing.foundation_and_discovery.usage_per_host
(DPS) Foundation & Discovery billing usage per host
The host-hours being monitored by Foundation & Discovery, counted in 15 min intervals. See further details.
Countautovalue
Full stack monitoring
builtin:billing.full_stack_monitoring.metric_data_points.included
(DPS) Available included metric data points for Full-Stack hosts
The total number of included metric data points that can be deducted from the metric data points reported by Full-Stack hosts. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view the number of applied included metric data points, use builtin:billing.full_stack_monitoring.metric_data_points.included_used . If the difference between this metric and the applied metrics is greater than 0, then more metrics can be ingested using Full-Stack Monitoring without incurring additional costs.
Countautovalue
(DPS) Used included metric data points for Full-Stack hosts
The number of consumed included metric data points per host monitored with Full-Stack Monitoring. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view the number of potentially available included metrics, use builtin:billing.full_stack_monitoring.metric_data_points.included_used . If the difference between this metric and the available metrics is greater than zero, then that means that more metrics could be ingested on Full-Stack hosts without incurring additional costs.
Countautovalue
(DPS) Total metric data points reported by Full-Stack hosts
The number of metric data points aggregated over all Full-Stack hosts. The values reported in this metric are eligible for included-metric-data-point deduction. Use this total metric to query longer timeframes without losing precision or performance. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view usage on a per-host basis, use builtin:billing.full_stack_monitoring.metric_data_points.ingested_by_host .
Countautovalue
(DPS) Metric data points reported and split by Full-Stack hosts
The number of metric data points split by Full-Stack hosts. The values reported in this metric are eligible for included-metric-data-point deduction. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. The pool of available included metrics for a "15-minute interval" is visible via builtin:billing.full_stack_monitoring.metric_data_points.included . To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric. See further details.
Countautovalue
builtin:billing.full_stack_monitoring.usage
(DPS) Full-Stack Monitoring billing usage
The total GiB memory of hosts being monitored in full-stack mode, counted in 15 min intervals. Use this total metric to query longer timeframes without losing precision or performance. For details on the hosts causing the usage, refer to the usage_per_host metric. For details on the containers causing the usage, refer to the usage_per_container metric.
GibiByteautovalue
builtin:billing.full_stack_monitoring.usage_per_container
(DPS) Full-stack usage by container type
The total GiB memory of containers being monitored in full-stack mode, counted in 15 min intervals.
GibiByteautovalue
builtin:billing.full_stack_monitoring.usage_per_host
(DPS) Full-Stack Monitoring billing usage per host
The GiB memory per host being monitored in full-stack mode, counted in 15 min intervals. For example, a host with 8 GiB of RAM monitored for 1 hour has 4 data points with a value of 2. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric. See further details.
GibiByteautovalue
Infrastructure monitoring
builtin:billing.infrastructure_monitoring.metric_data_points.included
(DPS) Available included metric data points for Infrastructure-monitored hosts
The total number of included metric data points that can be deducted from the metric data points reported by Infrastructure-monitored hosts. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view the number of applied included metric data points, use builtin:billing.infrastructure_monitoring.metric_data_points.included_used . If the difference between this metric and the applied metrics is greater than zero, then that means that more metrics could be ingested on Infrastructure-monitored hosts without incurring additional costs.
Countautovalue
(DPS) Used included metric data points for Infrastructure-monitored hosts
The number of consumed included metric data points for Infrastructure-monitored hosts. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view the number of potentially available included metrics, use builtin:billing.infrastructure_monitoring.metric_data_points.included_used . If the difference between this metric and the available metrics is greater than zero, then that means that more metrics could be ingested on Infrastructure-monitored hosts without incurring additional costs.
Countautovalue
(DPS) Total metric data points reported by Infrastructure-monitored hosts
The number of metric data points aggregated over all Infrastructure-monitored hosts. The values reported in this metric are eligible for included-metric-data-point deduction. Use this total metric to query longer timeframes without losing precision or performance. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. To view usage on a per-host basis, use the builtin:billing.full_stack_monitoring.metric_data_points.ingested_by_host .
Countautovalue
(DPS) Metric data points reported and split by Infrastructure-monitored hosts
The number of metric data points split by Infrastructure-monitored hosts. The values reported in this metric are eligible for included-metric-data-point deduction. This trailing metric is reported at 15-minute intervals with up to a 15-minute delay. The pool of available included metrics for a "15-minute interval" is visible via builtin:billing.infrastructure_monitoring.metric_data_points.included . To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric. See further details.
Countautovalue
builtin:billing.infrastructure_monitoring.usage
(DPS) Infrastructure Monitoring billing usage
The total number of host-hours being monitored in infrastructure-only mode, counted in 15 min intervals. Use this total metric to query longer timeframes without losing precision or performance. For details on the hosts causing the usage, refer to the usage_per_host metric.
Countautovalue
builtin:billing.infrastructure_monitoring.usage_per_host
(DPS) Infrastructure Monitoring billing usage per host
The host-hours being monitored in infrastructure-only mode, counted in 15 min intervals. A host monitored for the whole hour has 4 data points with a value of 0.25, regardless of the memory size. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric. See further details.
Countautovalue
Kubernetes monitoring
builtin:billing.kubernetes_monitoring.usage
(DPS) Kubernetes Platform Monitoring billing usage
The total number of monitored Kubernetes pods per hour, split by cluster and namespace and counted in 15 min intervals. A pod monitored for the whole hour has 4 data points with a value of 0.25.
Countautovalue
Log
builtin:billing.log.ingest.usage
(DPS) Log Management and Analytics usage - Ingest & Process
Log Management and Analytics Ingest & Process usage, tracked as bytes ingested within the hour. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay.
Byteautovalue
builtin:billing.log.query.usage
(DPS) Log Management and Analytics usage - Query
Log Management and Analytics Query usage, tracked as bytes read within the hour. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay.
Byteautovalue
builtin:billing.log.retain.usage
(DPS) Log Management and Analytics usage - Retain
Log Management and Analytics Retain usage, tracked as total storage used within the hour, in bytes. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay.
Byteautoavgmaxmin
Log monitoring classic
builtin:billing.log_monitoring_classic.usage
(DPS) Total Log Monitoring Classic billing usage
The number of log records ingested aggregated over all monitored entities. A log record is recognized by either a timestamp or a JSON object. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.log_monitoring_classic.usage_by_entity
(DPS) Log Monitoring Classic billing usage by monitored entity
The number of log records ingested split by monitored entity. A log record is recognized by either a timestamp or a JSON object. For details on the log path, refer to the usage_by_log_path metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.log_monitoring_classic.usage_by_log_path
(DPS) Log Monitoring Classic billing usage by log path
The number of log records ingested split by log path. A log record is recognized by either a timestamp or a JSON object. For details on the related monitored entities, refer to the usage_by_entity metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Mainframe monitoring
builtin:billing.mainframe_monitoring.usage
(DPS) Mainframe Monitoring billing usage
The total number of MSU-hours being monitored, counted in 15 min intervals.
MSUautovalue
Real user monitoring
builtin:billing.real_user_monitoring.mobile.property.usage
(DPS) Total Real-User Monitoring Property (mobile) billing usage
(Mobile) User action and session properties count. For details on how usage is calculated, refer to the documentation or builtin:billing.real_user_monitoring.web.property.usage_by_application . Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.real_user_monitoring.mobile.property.usage_by_application
(DPS) Real-User Monitoring Property (mobile) billing usage by application
(Mobile) User action and session properties count by application. The billed value is calculated based on the number of sessions reported in builtin:billing.real_user_monitoring.mobile.session.usage_by_app + builtin:billing.real_user_monitoring.mobile.session_with_replay.usage_by_app . plus the number of configured properties that exceed the included number of properties (free of charge) offered for a given application. Data points are only written for billed sessions. If the value is 0, you have available metric data points. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
(DPS) Total Real-User Monitoring (mobile) billing usage
(Mobile) Session count without Session Replay. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions end during the same minute, then the values are added together. Use this total metric to query longer timeframes without losing precision or performance. To view the application that consume this usage, refer to the usage_by_app metric.
Countautovalue
(DPS) Real-User Monitoring (mobile) billing usage by application
(Mobile) Session count without Session Replay split by application The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions of the same application end during the same minute, then the values are added together. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
(DPS) Total Real-User Monitoring (mobile) with Session Replay billing usage
(Mobile) Session count with Session Replay. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions end during the same minute, then the values are added together. Use this total metric to query longer timeframes without losing precision or performance. To view the application that consume this usage, refer to the usage_by_app metric.
Countautovalue
(DPS) Real-User Monitoring (mobile) with Session Replay billing usage by application
(Mobile) Session count with Session Replay split by application. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions of the same application end during the same minute, then the values are added together. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
(DPS) Total Real-User Monitoring Property (web) billing usage
(Web) User action and session properties count. For details on how usage is calculated, refer to the documentation or builtin:billing.real_user_monitoring.web.property.usage_by_application . Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
(DPS) Real-User Monitoring Property (web) billing usage by application
(Web) User action and session properties count by application. The billed value is calculated based on the number of sessions reported in builtin:billing.real_user_monitoring.web.session.usage_by_app + builtin:billing.real_user_monitoring.web.session_with_replay.usage_by_app . plus the number of configured properties that exceed the included number of properties (free of charge) offered for a given application. Data points are only written for billed sessions. If the value is 0, you have available metric data points. This trailing metric is reported hourly for the previous hour. Metric values are reported with up to a one-hour delay. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
(DPS) Total Real-User Monitoring (web) billing usage
(Web) Session count without Session Replay. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions end during the same minute, then the values are added together. Use this total metric to query longer timeframes without losing precision or performance. To view the application that consume this usage, refer to the usage_by_app metric.
Countautovalue
(DPS) Real-User Monitoring (web) billing usage by application
(Web) Session count without Session Replay split by application. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions of the same application end during the same minute, then the values are added together. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
(DPS) Total Real-User Monitoring (web) with Session Replay billing usage
(Web) Session count with Session Replay. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions end during the same minute, then the values are added together. Use this total metric to query longer timeframes without losing precision or performance. To view the application that consume this usage, refer to the usage_by_app metric.
Countautovalue
(DPS) Real-User Monitoring (web) with Session Replay billing usage by application
(Web) Session count with Session Replay split by application. The value billed for each session is the session duration measured in hours. So a 3-hour session results in a single data-point value of 3. If two sessions of the same application end during the same minute, then the values are added together. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Runtime application protection
builtin:billing.runtime_application_protection.usage
(DPS) Runtime Application Protection billing usage
Total GiB-memory of hosts protected with Runtime Application Protection (Application Security), counted at 15-minute intervals. Use this total metric to query longer timeframes without losing precision or performance. For details on the monitored hosts, refer to the usage_per_host metric.
GibiByteautovalue
builtin:billing.runtime_application_protection.usage_per_host
(DPS) Runtime Application Protection billing usage per host
GiB-memory per host protected with Runtime Application Protection (Application Security), counted at 15-minute intervals. For example, a host with 8 GiB of RAM monitored for 1 hour has 4 data points with a value of 2. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
GibiByteautovalue
Runtime vulnerability analytics
builtin:billing.runtime_vulnerability_analytics.usage
(DPS) Runtime Vulnerability Analytics billing usage
Total GiB-memory of hosts protected with Runtime Vulnerability Analytics (Application Security), counted at 15-minute intervals. Use this total metric to query longer timeframes without losing precision or performance. For details on the monitored hosts, refer to the usage_per_host metric.
GibiByteautovalue
builtin:billing.runtime_vulnerability_analytics.usage_per_host
(DPS) Runtime Vulnerability Analytics billing usage per host
GiB-memory per hosts protected with Runtime Vulnerability Analytics (Application Security), counted at 15-minute intervals. For example, a host with 8 GiB of RAM monitored for 1 hour has 4 data points with a value of 2. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
GibiByteautovalue
Serverless functions classic
builtin:billing.serverless_functions_classic.usage
(DPS) Total Serverless Functions Classic billing usage
The number of invocations of the serverless function aggregated over all monitored entities. The term "function invocations" is equivalent to "function requests" or "function executions". Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.serverless_functions_classic.usage_by_entity
(DPS) Serverless Functions Classic billing usage by monitored entity
The number of invocations of the serverless function split by monitored entity. The term "function invocations" is equivalent to "function requests" or "function executions". For details on which functions are invoked, refer to the usage_by_function metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.serverless_functions_classic.usage_by_function
(DPS) Serverless Functions Classic billing usage by function
The number of invocations of the serverless function split by function. The term "function invocations" is equivalent to "function requests" or "function executions". For details on the related monitored entities, refer to the usage_by_entity metric. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Synthetic
builtin:billing.synthetic.actions
Actions
The number of billed actions consumed by browser monitors.
Countautovalue
builtin:billing.synthetic.actions.usage
(DPS) Total Browser Monitor or Clickpath billing usage
The number of synthetic actions which triggers a web request that includes a page load, navigation event, or action that triggers an XHR or Fetch request. Scroll downs, keystrokes, or clicks that don't trigger web requests aren't counted as such actions. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.synthetic.actions.usage_by_browser_monitor
(DPS) Browser Monitor or Clickpath billing usage per synthetic browser monitor
The number of synthetic actions which triggers a web request that includes a page load, navigation event, or action that triggers an XHR or Fetch request. Scroll downs, keystrokes, or clicks that don't trigger web requests aren't counted as such actions. Actions are split by the Synthetic Browser Monitors that caused them. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.synthetic.external
Third-party results
The number of billed results consumed by third-party monitors.
Countautovalue
builtin:billing.synthetic.external.usage
(DPS) Total Third-Party Synthetic API Ingestion billing usage
The number of synthetic test results pushed into Dynatrace with Synthetic 3rd party API. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.synthetic.external.usage_by_third_party_monitor
(DPS) Third-Party Synthetic API Ingestion billing usage per external browser monitor
The number of synthetic test results pushed into Dynatrace with Synthetic 3rd party API. The ingestions are split by external Synthetic Browser Monitors for which the results where ingested. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
builtin:billing.synthetic.requests
Requests
The number of billed requests consumed by HTTP monitors.
Countautovalue
builtin:billing.synthetic.requests.usage
(DPS) Total HTTP monitor billing usage
The number of HTTP requests performed during execution of synthetic HTTP monitor. Use this total metric to query longer timeframes without losing precision or performance.
Countautovalue
builtin:billing.synthetic.requests.usage_by_http_monitor
(DPS) HTTP monitor billing usage per HTTP monitor
The number of HTTP requests performed, split by synthetic HTTP monitor. To improve performance and avoid exceeding query limits when working with longer timeframes, use the total metric.
Countautovalue
Cloud
AWS
builtin:cloud.aws.az.running
Number of running EC2 instances (AZ)
Countautoavgmaxmin
Azure
builtin:cloud.azure.region.vms.initializing
Number of starting VMs in region
Countautoavgmaxmin
builtin:cloud.azure.region.vms.running
Number of active VMs in region
Countautoavgmaxmin
builtin:cloud.azure.region.vms.stopped
Number of stopped VMs in region
Countautoavgmaxmin
builtin:cloud.azure.vmScaleSet.vms.initializing
Number of starting VMs in scale set
Countautoavgmaxmin
builtin:cloud.azure.vmScaleSet.vms.running
Number of active VMs in scale set
Countautoavgmaxmin
builtin:cloud.azure.vmScaleSet.vms.stopped
Number of stopped VMs in scale set
Countautoavgmaxmin
Cloud Foundry
builtin:cloud.cloudfoundry.auctioneer.fetchDuration
CF: Time to fetch cell states
The time that the auctioneer took to fetch state from all the cells when running its auction.
Nanosecondautoavgmaxmin
builtin:cloud.cloudfoundry.auctioneer.lprFailed
CF: App instance placement failures
The number of application instances that the auctioneer failed to place on Diego cells.
Countautovalue
builtin:cloud.cloudfoundry.auctioneer.lprStarted
CF: App instance starts
The number of application instances that the auctioneer successfully placed on Diego cells.
Countautovalue
builtin:cloud.cloudfoundry.auctioneer.taskFailed
CF: Task placement failures
The number of tasks that the auctioneer failed to place on Diego cells.
Countautovalue
builtin:cloud.cloudfoundry.http.badGateways
CF: 502 responses
The number of responses that indicate invalid service responses produced by an application.
Countautovalue
builtin:cloud.cloudfoundry.http.latency
CF: Response latency
The average response time from the application to clients.
Millisecondautoavgmaxmin
builtin:cloud.cloudfoundry.http.responses5xx
CF: 5xx responses
The number of responses that indicate repeatedly crashing apps or response issues from applications.
Countautovalue
builtin:cloud.cloudfoundry.http.totalRequests
CF: Total requests
The number of all requests representing the overall traffic flow.
Countautovalue
Openstack
Metric keyName and descriptionUnitAggregations
builtin:cloud.openstack.vm.cpu.usage
CPU usage
Percent (%)autoavgmaxmin
builtin:cloud.openstack.vm.disk.allocation
Disk allocation
Byteautoavgmaxmin
builtin:cloud.openstack.vm.disk.capacity
Disk capacity
Byteautoavgmaxmin
builtin:cloud.openstack.vm.memory.resident
Memory resident
Byteautoavgmaxmin
builtin:cloud.openstack.vm.memory.usage
Memory usage
Byteautoavgmaxmin
builtin:cloud.openstack.vm.net.rx
Network incoming bytes rate
Byte/secondautoavgmaxmin
builtin:cloud.openstack.vm.net.tx
Network outgoing bytes rate
VMware
builtin:cloud.vmware.hypervisor.cpu.usage
Host CPU usage %
builtin:cloud.vmware.hypervisor.disk.usage
Host disk usage rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.hostdisk.commandsAborted
Host disk commands aborted
Countautovalue
builtin:cloud.vmware.hypervisor.hostdisk.queueLatency
Host disk queue latency
builtin:cloud.vmware.hypervisor.hostdisk.rIops
Host disk read IOPS
Per secondautoavgmaxmin
builtin:cloud.vmware.hypervisor.hostdisk.readLatency
Host disk read latency
builtin:cloud.vmware.hypervisor.hostdisk.readRate
Host disk read rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.hostdisk.wIops
Host disk write IOPS
builtin:cloud.vmware.hypervisor.hostdisk.writeLatency
Host disk write latency
builtin:cloud.vmware.hypervisor.hostdisk.writeRate
Host disk write rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.mem.compressionRate
Host compression rate
Kibibyte/secondautoavgmaxmin
builtin:cloud.vmware.hypervisor.mem.consumed
Host memory consumed
Kibibyteautoavgmaxmin
builtin:cloud.vmware.hypervisor.mem.decompressionRate
Host decompression rate
builtin:cloud.vmware.hypervisor.mem.swapIn
Host swap in rate
builtin:cloud.vmware.hypervisor.mem.swapOut
Host swap out rate
builtin:cloud.vmware.hypervisor.net.rx
Host network data received rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.net.tx
Host network data transmitted rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.nic.dataRx
Data received rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.nic.dataTx
Data transmitted rate
kB/sautoavgmaxmin
builtin:cloud.vmware.hypervisor.nic.packetsRxDropped
Packets received dropped
Countautovalue
builtin:cloud.vmware.hypervisor.nic.packetsTxDropped
Packets transmitted dropped
Countautovalue
builtin:cloud.vmware.hypervisor.vms.count
Number of VMs
Countautoavgmaxmin
builtin:cloud.vmware.hypervisor.vms.powerOff
Number of VMs powered-off
Countautoavgmaxmin
builtin:cloud.vmware.hypervisor.vms.suspended
Number of VMs suspended
Countautoavgmaxmin
builtin:cloud.vmware.hypervisor.availability
Host availability %
Percent (%)autoavg
builtin:cloud.vmware.vm.cpu.readyPerc
VM CPU ready %
builtin:cloud.vmware.vm.cpu.swapWait
VM swap wait
Millisecondautovalue
builtin:cloud.vmware.vm.cpu.usage
VM CPU usage MHz
Countautoavgmaxmin
builtin:cloud.vmware.vm.cpu.usagePerc
VM CPU usage %
builtin:cloud.vmware.vm.disk.usage
VM disk usage rate
kB/sautoavgmaxmin
builtin:cloud.vmware.vm.mem.active
VM memory active
builtin:cloud.vmware.vm.mem.compressionRate
VM compression rate
builtin:cloud.vmware.vm.mem.consumed
VM memory consumed
builtin:cloud.vmware.vm.mem.decompressionRate
VM decompression rate
builtin:cloud.vmware.vm.mem.swapIn
VM swap in rate
builtin:cloud.vmware.vm.mem.swapOut
VM swap out rate
builtin:cloud.vmware.vm.net.rx
VM network data received rate
kB/sautoavgmaxmin
builtin:cloud.vmware.vm.net.tx
VM network data transmitted rate
kB/sautoavgmaxmin
Containers
CPU
builtin:containers.cpu.limit
Containers: CPU limit, mCores
CPU resource limit per container in millicores.
Millicoresautoavgmaxmin
builtin:containers.cpu.logicalCores
Containers: CPU logical cores
Number of logical CPU cores of the host.
Coresautoavgmaxmin
builtin:containers.cpu.shares
Containers: CPU shares
Number of CPU shares allocated per container.
Countautoavgmaxmin
builtin:containers.cpu.throttledMilliCores
Containers: CPU throttling, mCores
CPU throttling per container in millicores.
builtin:containers.cpu.throttledTime
Containers: CPU throttled time, ns/min
Total amount of time a container has been throttled, in nanoseconds per minute.
Nanosecond/minuteautoavgmaxmin
builtin:containers.cpu.usageMilliCores
Containers: CPU usage, mCores
CPU usage per container in millicores
builtin:containers.cpu.usagePercent
Containers: CPU usage, % of limit
Percent CPU usage per container relative to CPU resource limit. Logical cores are used if CPU limit isn't set.
builtin:containers.cpu.usageSystemMilliCores
Containers: CPU system usage, mCores
CPU system usage per container in millicores.
builtin:containers.cpu.usageSystemTime
Containers: CPU system usage time, ns/min
Used system time per container in nanoseconds per minute.
builtin:containers.cpu.usageTime
Containers: CPU usage time, ns/min
Sum of used system and user time per container in nanoseconds per minute.
builtin:containers.cpu.usageUserMilliCores
Containers: CPU user usage, mCores
CPU user usage per container in millicores.
builtin:containers.cpu.usageUserTime
Containers: CPU user usage time, ns/min
Used user time per container in nanoseconds per minute.
Memory
builtin:containers.memory.cacheBytes
Containers: Memory cache, bytes
Page cache memory per container in bytes.
Byteautoavgmaxmin
builtin:containers.memory.limitBytes
Containers: Memory limit, bytes
Memory limit per container in bytes. If no limit is set, this is an empty value.
Byteautoavgmaxmin
builtin:containers.memory.limitPercent
Containers: Memory limit, % of physical memory
Percent memory limit per container relative to total physical memory. If no limit is set, this is an empty value.
Percent (%)autoavg
builtin:containers.memory.outOfMemoryKills
Containers: Memory - out of memory kills
Number of out of memory kills for a container.
Countautovalue
builtin:containers.memory.physicalTotalBytes
Containers: Memory - total physical memory, bytes
Total physical memory on the host in bytes.
Byteautoavgmaxmin
builtin:containers.memory.residentSetBytes
Containers: Memory usage, bytes
Resident set size (Linux) or private working set size (Windows) per container in bytes.
Byteautoavgmaxmin
builtin:containers.memory.usagePercent
Containers: Memory usage, % of limit
Resident set size (Linux) or private working set size (Windows) per container in percent relative to container memory limit. If no limit is set, this equals total physical memory.
Dashboards
Other dashboards metrics
builtin:dashboards.viewCount
Dashboard view count
Countautovalue
Infrastructure
Availability
builtin:host.availability.state
Host availability
Host availability state metric reported in 1 minute intervals
Countautovalue
CPU
builtin:host.cpu.gcpu.usage
z/OS General CPU usage
The percent of the general-purpose central processor (GCP) used
builtin:host.cpu.msu.avg
z/OS Rolling 4 hour MSU average
The 4h average of consumed million service units on this LPAR
MSUautoavgmaxmin
builtin:host.cpu.msu.capacity
z/OS MSU capacity
The over all capacity of million service units on this LPAR
MSUautoavgmaxmin
builtin:host.cpu.ziip.eligible
z/OS zIIP eligible time
The zIIP eligible time spent on the general-purpose central processor (GCP) after process start per minute
Secondautoavgcountmaxminsum
builtin:host.cpu.entConfig
AIX Entitlement configured
Capacity Entitlement is the number of virtual processors assigned to the AIX partition. It's measured in fractions of processor equal to 0.1 or 0.01. For more information about entitlement, see Assigning the appropriate processor entitled capacity in official IBM documentation.
Ratioautoavgmaxmin
builtin:host.cpu.entc
AIX Entitlement used
Percentage of entitlement used. Capacity Entitlement is the number of virtual cores assigned to the AIX partition. See for more information about entitlement, see Assigning the appropriate processor entitled capacity in official IBM documentation.
builtin:host.cpu.idle
CPU idle
Average CPU time, when the CPU didn't have anything to do
builtin:host.cpu.iowait
CPU I/O wait
Percentage of time when CPU was idle during which the system had an outstanding I/O request. It is not available on Windows.
builtin:host.cpu.load
System load
The average number of processes that are being executed by CPU or waiting to be executed by CPU over the last minute
Ratioautoavgmaxmin
builtin:host.cpu.load15m
System load15m
The average number of processes that are being executed by CPU or waiting to be executed by CPU over the last 15 minutes
Ratioautoavgmaxmin
builtin:host.cpu.load5m
System load5m
The average number of processes that are being executed by CPU or waiting to be executed by CPU over the last 5 minutes
Ratioautoavgmaxmin
builtin:host.cpu.other
CPU other
Average CPU time spent on other tasks: servicing interrupt requests (IRQ), running virtual machines under the control of the host's kernel (meaning the host is a hypervisor for VMs). It's available only for Linux hosts
builtin:host.cpu.physc
AIX Physical consumed
Total CPUs consumed by the AIX partition
Ratioautoavgmaxmin
builtin:host.cpu.steal
CPU steal
Average CPU time, when a virtual machine waits to get CPU cycles from the hypervisor. In a virtual environment, CPU cycles are shared across virtual machines on the hypervisor server. If your virtualized host displays a high CPU steal, it means CPU cycles are being taken away from your virtual machine to serve other purposes. It may indicate an overloaded hypervisor. It's available only for Linux hosts
builtin:host.cpu.system
CPU system
Average CPU time when CPU was running in kernel mode
builtin:host.cpu.usage
CPU usage %
Percentage of CPU time when CPU was utilized. A value close to 100% means most host processing resources are in use, and host CPUs can't handle additional work
builtin:host.cpu.user
CPU user
Average CPU time when CPU was running in user mode
DNS
builtin:host.dns.errorCount
Number of DNS errors by type
Countautoavgcountmaxminsum
builtin:host.dns.orphanCount
Number of orphaned DNS responses
Number of orphaned DNS responses on the host
builtin:host.dns.queryCount
Number of DNS queries
Number of DNS queries on the host
builtin:host.dns.queryTime
DNS query time sum
The time of all DNS queries on the host
Millisecondautoavgcountmaxminsum
builtin:host.dns.singleQueryTime
DNS query time
Average time of DNS query. Calculated with DNS query time sum divided by number of DNS queries for each host and DNS server pair.
builtin:host.dns.singleQueryTimeByDnsIp
DNS query time by DNS server
The weighted average time of DNS query by DNS server ip. Calculated with DNS query time sum divided by number of DNS queries. It weights the result taking into account number of requests from each host.
builtin:host.dns.singleQueryTimeByHost
DNS query time on host
The weighted average time of DNS query on a host. Calculated with DNS query time sum divided by number of DNS queries on a host. It weights the result taking into account number of requests to each dns server
Disk
builtin:host.disk.throughput.read
Disk throughput read
File system read throughput in bits per second
bit/sautoavgmaxmin
builtin:host.disk.throughput.write
Disk throughput write
File system write throughput in bits per second
bit/sautoavgmaxmin
builtin:host.disk.avail
Disk available
Amount of free space available for user in file system. On Linux and AIX it is free space available for unprivileged user. It doesn't contain part of free space reserved for the root.
Byteautoavgmaxmin
builtin:host.disk.bytesRead
Disk read bytes per second
Speed of read from file system in bytes per second
builtin:host.disk.bytesWritten
Disk write bytes per second
Speed of write to file system in bytes per second
builtin:host.disk.free
Disk available %
Percentage of free space available for user in file system. On Linux and AIX it is % of free space available for unprivileged user. It doesn't contain part of free space reserved for the root.
builtin:host.disk.inodesAvail
Inodes available %
Percentage of free inodes available for unprivileged user in file system. Metric not available on Windows.
builtin:host.disk.inodesTotal
Inodes total
Total amount of inodes available for unprivileged user in file system. Metric not available on Windows.
Countautoavgmaxmin
builtin:host.disk.queueLength
Disk average queue length
Average number of read and write operations in disk queue
Countautoavgmaxmin
builtin:host.disk.readOps
Disk read operations per second
Number of read operations from file system per second
builtin:host.disk.readTime
Disk read time
Average time of read from file system. It shows average disk latency during read.
builtin:host.disk.used
Disk used
Amount of used space in file system
Byteautoavgmaxmin
builtin:host.disk.usedPct
Disk used %
Percentage of used space in file system
builtin:host.disk.utilTime
Disk utilization time
Percent of time spent on disk I/O operations
builtin:host.disk.writeOps
Disk write operations per second
Number of write operations to file system per second
builtin:host.disk.writeTime
Disk write time
Average time of write to file system. It shows average disk latency during write.
Handles
builtin:host.handles.fileDescriptorsMax
File descriptors max
Maximum amount of file descriptors for use
Countautoavgmaxmin
builtin:host.handles.fileDescriptorsUsed
File descriptors used
Amount of file descriptors used
Countautoavgmaxmin
Kernel threads
builtin:host.kernelThreads.blocked
AIX Kernel threads blocked
Length of the swap queue. The swap queue contains the threads ready to run but swapped out with the currently running threads
Countautoavgmaxmin
builtin:host.kernelThreads.ioEventWait
AIX Kernel threads I/O event wait
Number of threads that are waiting for file system direct (cio) + Number of processes that are asleep waiting for buffered I/O
Countautoavgmaxmin
builtin:host.kernelThreads.ioMessageWait
AIX Kernel threads I/O message wait
Number of threads that are sleeping and waiting for raw I/O operations at a particular time. Raw I/O operation allows applications to direct write to the Logical Volume Manager (LVM) layer
Countautoavgmaxmin
builtin:host.kernelThreads.running
AIX Kernel threads runnable
Number of runnable threads (running or waiting for run time) (threads ready). The average number of runnable threads is seen in the first column of the vmstat command output
Countautoavgmaxmin
Memory
builtin:host.mem.avail.bytes
Memory available
The amount of memory (RAM) available on the host. The memory that is available for allocation to new or existing processes. Available memory is an estimation of how much memory is available for use without swapping.
Byteautoavgmaxmin
builtin:host.mem.avail.pct
Memory available %
The percentage of memory (RAM) available on the host. The memory that is available for allocation to new or existing processes. Available memory is an estimation of how much memory is available for use without swapping. Shows available memory as percentages.
builtin:host.mem.avail.pfps
Page faults per second
The measure of the number of page faults per second on the monitored host. This value includes soft faults and hard faults.
builtin:host.mem.swap.avail
Swap available
The amount of swap memory or swap space (also known as paging, which is the on-disk component of the virtual memory system) available.
Byteautoavgmaxmin
builtin:host.mem.swap.total
Swap total
Amount of total swap memory or total swap space (also known as paging, which is the on-disk component of the virtual memory system) for use.
Byteautovalue
builtin:host.mem.swap.used
Swap used
The amount of swap memory or swap space (also known as paging, which is the on-disk component of the virtual memory system) used.
Byteautoavgmaxmin
builtin:host.mem.kernel
Kernel memory
The memory used by the system kernel. It includes memory used by core components of OS along with any device drivers. Typically, the number will be very small.
Byteautoavgmaxmin
builtin:host.mem.recl
Memory reclaimable
The memory usage for specific purposes. Reclaimable memory is calculated as available memory (estimation of how much memory is available for use without swapping) minus free memory (amount of memory that is currently not used for anything). For more information on reclaimable memory, see this blog post.
Byteautoavgmaxmin
builtin:host.mem.total
Memory total
The amount of memory (RAM) installed on the system.
Byteautovalue
builtin:host.mem.usage
Memory used %
Shows percentage of memory currently used. Used memory is calculated by OneAgent as follows: used = total - available. So the used memory metric displayed in Dynatrace analysis views is not equal to the used memory metric displayed by system tools. At the same time, it's important to remember that system tools report used memory the way they do due to historical reasons, and that this particular method of calculating used memory isn't really representative of how the Linux kernel manages memory in modern systems. The difference in these measurements is in fact quite significant, too. Note: Calculated by taking 100% - "Memory available %".
builtin:host.mem.used
Memory used
Byteautoavgmaxmin
Network
builtin:host.net.nic.packets.dropped
NIC packets dropped
Network interface packets dropped on the host
Per secondautovalue
builtin:host.net.nic.packets.droppedRx
NIC received packets dropped
Network interface received packets dropped on the host
builtin:host.net.nic.packets.droppedTx
NIC sent packets dropped
Network interface sent packets dropped on the host
builtin:host.net.nic.packets.errors
NIC packet errors
Network interface packet errors on the host
Per secondautovalue
builtin:host.net.nic.packets.errorsRx
NIC received packet errors
Network interface received packet errors on a host
builtin:host.net.nic.packets.errorsTx
NIC sent packet errors
Network interface sent packet errors on the host
builtin:host.net.nic.packets.rx
NIC packets received
Network interface packets received on the host
builtin:host.net.nic.packets.tx
NIC packets sent
Network interface packets sent on the host
builtin:host.net.nic.bytesRx
NIC bytes received
Network interface bytes received on the host
builtin:host.net.nic.bytesTx
NIC bytes sent on host
Network interface bytes sent on the host
builtin:host.net.nic.connectivity
NIC connectivity
Network interface connectivity on the host
builtin:host.net.nic.linkUtilRx
NIC receive link utilization
Network interface receive link utilization on the host
builtin:host.net.nic.linkUtilTx
NIC transmit link utilization
Network interface transmit link utilization on the host
builtin:host.net.nic.retransmission
NIC retransmission
Network interface retransmission on the host
builtin:host.net.nic.retransmissionIn
NIC received packets retransmission
Network interface retransmission for received packets on the host
builtin:host.net.nic.retransmissionOut
NIC sent packets retransmission
Network interface retransmission for sent packets on the host
builtin:host.net.nic.traffic
Traffic
Network traffic on the host
bit/sautovalue
builtin:host.net.nic.trafficIn
Traffic in
Traffic incoming at the host
bit/sautoavgmaxmin
builtin:host.net.nic.trafficOut
Traffic out
Traffic outgoing from the host
bit/sautoavgmaxmin
builtin:host.net.packets.rxBaseReceived
Host retransmission base received
Host aggregated process retransmission base received per second
builtin:host.net.packets.rxBaseSent
Host retransmission base sent
Host aggregated process retransmission base sent per second
builtin:host.net.packets.rxReceived
Host retransmitted packets received
Host aggregated process retransmitted packets received per second
builtin:host.net.packets.rxSent
Host retransmitted packets sent
Host aggregated process retransmitted packets sent per second
builtin:host.net.sessions.local.errRst
Localhost session reset received
Host aggregated session reset received per second on localhost
builtin:host.net.sessions.local.errTmout
Localhost session timeout received
Host aggregated session timeout received per second on localhost
builtin:host.net.sessions.local.new
Localhost new session received
Host aggregated new session received per second on localhost
builtin:host.net.sessions.errRst
Host session reset received
Host aggregated process session reset received per second
builtin:host.net.sessions.errTmout
Host session timeout received
Host aggregated process session timeout received per second
builtin:host.net.sessions.new
Host new session received
Host aggregated process new session received per second
builtin:host.net.bytesRx
Host bytes received
Host aggregated process bytes received per second
builtin:host.net.bytesTx
Host bytes sent
Host aggregated process bytes sent per second
OS service
builtin:host.osService.availability
OS Service availability
This metric provides the status of the OS service. If the OS service is running, the OS module is reporting "1" as a value of the metric. In any other case, the metric has a value of "0"Note that this metric provides data only from Classic Windows services monitoring (supported only on Windows), currently replaced by the new OS Services monitoring. To learn more, see Classic Windows services monitoring.
Countautoavgmaxmin
Processes
builtin:host.osProcessStats.osProcessCount
OS Process count
This metric shows an average number of processes, over one minute, running on the host. The reported number of processes is based on processes detected by the OS module, read in 10 seconds cycles.
Countautoavgmaxmin
builtin:host.osProcessStats.pgiCount
PGI count
This metric shows the number of PGIs created by the OS module every minute. It includes every PGI, even those which are considered not important and are not reported to Dynatrace.
Countautoavgmaxmin
builtin:host.osProcessStats.pgiReportedCount
Reported PGI count
This metric shows the number of PGIs created and reported by the OS module every minute. It includes only PGIs, which are considered important and reported to Dynatrace. Important PGIs are those in which OneAgent recognizes the technology, have open network ports, generate significant resource usage, or are created via Declarative process grouping rules. To learn what makes process important, see Which are the most important processes?
Countautoavgmaxmin
z/OS
builtin:host.zos.gcpu_time
z/OS General CPU time
Total General CPU time per minute
builtin:host.zos.msu_hours
z/OS Consumed MSUs per SMF interval (SMF70EDT)
Number of consumed MSUs per SMF interval (SMF70EDT)
builtin:host.zos.ziip_time
z/OS zIIP time
Total zIIP time per minute
builtin:host.zos.ziip_usage
z/OS zIIP usage
Actively used zIIP as a percentage of available zIIP
Other infrastructure metrics
Host availability %
Host availability %
Percent (%)autoavg
builtin:host.uptime
Host uptime
Time since last host boot up. Requires OneAgent 1.259+. The metric is not supported for application-only OneAgent deployments.
Secondautoavgmaxmin
Kubernetes
Cluster
builtin:kubernetes.cluster.readyz
Kubernetes: Cluster readyz status
Current status of the Kubernetes API server reported by the /readyz endpoint (0 or 1).
autoavgmaxmin
Container
builtin:kubernetes.container.oom_kills
Kubernetes: Container - out of memory (OOM) kill count
This metric measures the out of memory (OOM) kills. The most detailed level of aggregation is container. The value corresponds to the status 'OOMKilled' of a container in the pod resource's container status. The metric is only written if there was at least one container OOM kill.
Countautovalue
builtin:kubernetes.container.restarts
Kubernetes: Container - restart count
This metric measures the amount of container restarts. The most detailed level of aggregation is container. The value corresponds to the delta of the 'restartCount' defined in the pod resource's container status. The metric is only written if there was at least one container restart.
Countautovalue
Node
builtin:kubernetes.node.conditions
Kubernetes: Node conditions
This metric describes the status of a Kubernetes node. The most detailed level of aggregation is node.
Countautoavgmaxmin
builtin:kubernetes.node.cpu_allocatable
Kubernetes: Node - CPU allocatable
This metric measures the total allocatable cpu. The most detailed level of aggregation is node. The value corresponds to the allocatable cpu of a node.
builtin:kubernetes.node.cpu_throttled
Kubernetes: Container - CPU throttled (by node)
This metric measures the total CPU throttling by container. The most detailed level of aggregation is node.
builtin:kubernetes.node.cpu_usage
Kubernetes: Container - CPU usage (by node)
This metric measures the total CPU consumed (user usage + system usage) by container. The most detailed level of aggregation is node.
builtin:kubernetes.node.limits_cpu
Kubernetes: Pod - CPU limits (by node)
This metric measures the cpu limits. The most detailed level of aggregation is node. The value is the sum of the cpu limits of all app containers of a pod.
builtin:kubernetes.node.limits_memory
Kubernetes: Pod - memory limits (by node)
This metric measures the memory limits. The most detailed level of aggregation is node. The value is the sum of the memory limits of all app containers of a pod.
Byteautoavgmaxmin
builtin:kubernetes.node.memory_allocatable
Kubernetes: Node - memory allocatable
This metric measures the total allocatable memory. The most detailed level of aggregation is node. The value corresponds to the allocatable memory of a node.
Byteautoavgmaxmin
builtin:kubernetes.node.memory_working_set
Kubernetes: Container - Working set memory (by node)
This metric measures the current working set memory (memory that cannot be reclaimed under pressure) by container. The OOM Killer is invoked if the working set exceeds the limit. The most detailed level of aggregation is node.
Byteautoavgmaxmin
builtin:kubernetes.node.pods
Kubernetes: Pod count (by node)
This metric measures the number of pods. The most detailed level of aggregation is node. The value corresponds to the count of all pods.
Countautoavgmaxmin
builtin:kubernetes.node.pods_allocatable
Kubernetes: Node - pod allocatable count
This metric measures the total number of allocatable pods. The most detailed level of aggregation is node. The value corresponds to the allocatable pods of a node.
Countautoavgmaxmin
builtin:kubernetes.node.requests_cpu
Kubernetes: Pod - CPU requests (by node)
This metric measures the cpu requests. The most detailed level of aggregation is node. The value is the sum of the cpu requests of all app containers of a pod.
builtin:kubernetes.node.requests_memory
Kubernetes: Pod - memory requests (by node)
This metric measures the memory requests. The most detailed level of aggregation is node. The value is the sum of the memory requests of all app containers of a pod.
Byteautoavgmaxmin
Persistentvolumeclaim
builtin:kubernetes.persistentvolumeclaim.available
Kubernetes: PVC - available
This metric measures the number of available bytes in the volume. The most detailed level of aggregation is persistent volume claim.
Byteautoavgmaxmin
builtin:kubernetes.persistentvolumeclaim.capacity
Kubernetes: PVC - capacity
This metric measures the capacity in bytes of the volume. The most detailed level of aggregation is persistent volume claim.
Byteautoavgmaxmin
builtin:kubernetes.persistentvolumeclaim.used
Kubernetes: PVC - used
This metric measures the number of used bytes in the volume. The most detailed level of aggregation is persistent volume claim.
Byteautoavgmaxmin
Resource Quota
builtin:kubernetes.resourcequota.limits_cpu
Kubernetes: Resource quota - CPU limits
This metric measures the cpu limit quota. The most detailed level of aggregation is resource quota. The value corresponds to the cpu limits of a resource quota.
builtin:kubernetes.resourcequota.limits_cpu_used
Kubernetes: Resource quota - CPU limits used
This metric measures the used cpu limit quota. The most detailed level of aggregation is resource quota. The value corresponds to the used cpu limits of a resource quota.
builtin:kubernetes.resourcequota.limits_memory
Kubernetes: Resource quota - memory limits
This metric measures the memory limit quota. The most detailed level of aggregation is resource quota. The value corresponds to the memory limits of a resource quota.
Byteautoavgmaxmin
builtin:kubernetes.resourcequota.limits_memory_used
Kubernetes: Resource quota - memory limits used
This metric measures the used memory limits quota. The most detailed level of aggregation is resource quota. The value corresponds to the used memory limits of a resource quota.
Byteautoavgmaxmin
builtin:kubernetes.resourcequota.pods
Kubernetes: Resource quota - pod count
This metric measures the pods quota. The most detailed level of aggregation is resource quota. The value corresponds to the pods of a resource quota.
Countautoavgmaxmin
builtin:kubernetes.resourcequota.pods_used
Kubernetes: Resource quota - pod used count
This metric measures the used pods quota. The most detailed level of aggregation is resource quota. The value corresponds to the used pods of a resource quota.
Countautoavgmaxmin
builtin:kubernetes.resourcequota.requests_cpu
Kubernetes: Resource quota - CPU requests
This metric measures the cpu requests quota. The most detailed level of aggregation is resource quota. The value corresponds to the cpu requests of a resource quota.
builtin:kubernetes.resourcequota.requests_cpu_used
Kubernetes: Resource quota - CPU requests used
This metric measures the used cpu requests quota. The most detailed level of aggregation is resource quota. The value corresponds to the used cpu requests of a resource quota.
builtin:kubernetes.resourcequota.requests_memory
Kubernetes: Resource quota - memory requests
This metric measures the memory requests quota. The most detailed level of aggregation is resource quota. The value corresponds to the memory requests of a resource quota.
Byteautoavgmaxmin
builtin:kubernetes.resourcequota.requests_memory_used
Kubernetes: Resource quota - memory requests used
This metric measures the used memory requests quota. The most detailed level of aggregation is resource quota. The value corresponds to the used memory requests of a resource quota.
Byteautoavgmaxmin
Workload
builtin:kubernetes.workload.conditions
Kubernetes: Workload conditions
This metric describes the status of a Kubernetes workload. The most detailed level of aggregation is workload.
Countautoavgmaxmin
builtin:kubernetes.workload.containers_desired
Kubernetes: Pod - desired container count
This metric measures the number of desired containers. The most detailed level of aggregation is workload. The value is the count of all containers in the pod's specification.
Countautoavgmaxmin
builtin:kubernetes.workload.cpu_throttled
Kubernetes: Container - CPU throttled (by workload)
This metric measures the total CPU throttling by container. The most detailed level of aggregation is workload.
builtin:kubernetes.workload.cpu_usage
Kubernetes: Container - CPU usage (by workload)
This metric measures the total CPU consumed (user usage + system usage) by container. The most detailed level of aggregation is workload.
builtin:kubernetes.workload.limits_cpu
Kubernetes: Pod - CPU limits (by workload)
This metric measures the cpu limits. The most detailed level of aggregation is workload. The value is the sum of the cpu limits of all app containers of a pod.
builtin:kubernetes.workload.limits_memory
Kubernetes: Pod - memory limits (by workload)
This metric measures the memory limits. The most detailed level of aggregation is workload. The value is the sum of the memory limits of all app containers of a pod.
Byteautoavgmaxmin
builtin:kubernetes.workload.memory_resident_set_size
[Deprecated] Kubernetes: Container - Memory RSS (by workload)
This metric measures the true resident set size (RSS) by container. RSS is the amount of physical memory used by the container's cgroup - either total_rss + total_mapped_file (cgroup v1) or anon + file_mapped (cgroup v2). The most detailed level of aggregation is workload. Deprecated - use builtin:kubernetes.workload.memory_working_set instead.
Byteautoavgmaxmin
Kubernetes: Container - Working set memory (by workload)
This metric measures the current working set memory (memory that cannot be reclaimed under pressure) by container. The OOM Killer is invoked if the working set exceeds the limit. The most detailed level of aggregation is workload.
Byteautoavgmaxmin
builtin:kubernetes.workload.pods_desired
Kubernetes: Workload - desired pod count
This metric measures the number of desired pods. The most detailed level of aggregation is workload. The value corresponds to the 'replicas' defined in a deployment resource and to the 'desiredNumberScheduled' for a daemon set resource's status as example.
Countautoavgmaxmin
builtin:kubernetes.workload.requests_cpu
Kubernetes: Pod - CPU requests (by workload)
This metric measures the cpu requests. The most detailed level of aggregation is workload. The value is the sum of the cpu requests of all app containers of a pod.
builtin:kubernetes.workload.requests_memory
Kubernetes: Pod - memory requests (by workload)
This metric measures the memory requests. The most detailed level of aggregation is workload. The value is the sum of the memory requests of all app containers of a pod.
Byteautoavgmaxmin
Other kubernetes metrics
builtin:kubernetes.containers
Kubernetes: Container count
This metric measures the number of containers. The most detailed level of aggregation is workload. The metric counts the number of all containers.
Countautoavgmaxmin
builtin:kubernetes.events
Kubernetes: Event count
This metric counts Kubernetes events. The most detailed level of aggregation is the event reason. The value corresponds to the count of events returned by the Kubernetes events endpoint. This metric depends on Kubernetes event monitoring. It will not show any datapoints for the period in which event monitoring is deactivated.
Countautovalue
builtin:kubernetes.nodes
Kubernetes: Node count
This metric measures the number of nodes. The most detailed level of aggregation is cluster. The value is the count of all nodes.
Countautoavgmaxmin
builtin:kubernetes.pods
Kubernetes: Pod count (by workload)
This metric measures the number of pods. The most detailed level of aggregation is workload. The value corresponds to the count of all pods.
Countautoavgmaxmin
builtin:kubernetes.workloads
Kubernetes: Workload count
This metric measures the number of workloads. The most detailed level of aggregation is namespace. The value corresponds to the count of all workloads.
Countautoavgmaxmin
Process
Availability
builtin:pgi.availability.state
Process availability
Process availability state metric reported in 1 minute intervals
Countautovalue
Other process metrics
Process availability %
This metric provides the percentage of time when a process is available. It is sent once per minute with a 10-second granularity - six samples are aggregated every minute. If the process is available for a whole minute, the value is 100%. A 0% value indicates that it is not running. It has a "Process" dimension (dt.entity.process_group_instance).
Percent (%)autoavg
Process
builtin:process.bytesReceived
Process traffic in
This metric provides size of incoming traffic of a process. It helps to identify processes generating high network traffic on a host. The result is expressed in kilobytes. It has a "PID" (process.pid), "Parent PID" (process.parent_pid), "process owner" (process.owner), "process executable name" (process.executable.name), "process executable path" (process.executable.path), "process command line" (process.command_line) and "Process group instance" (dt.entity.process_group_instance) dimensions This metric is collected only if the Process instance snapshot feature is turned on and triggered, and the time this metric is collected for is restricted to feature limits. To learn more, see Process instance snapshots.
kBautoavgcountmaxminsum
builtin:process.bytesSent
Process traffic out
This metric provides size of outgoing traffic of a process. It helps to identify processes generating high network traffic on a host. The result is expressed in kilobytes. It has a "PID" (process.pid), "Parent PID" (process.parent_pid), "process owner" (process.owner), "process executable name" (process.executable.name), "process executable path" (process.executable.path), "process command line" (process.command_line) and "Process group instance" (dt.entity.process_group_instance) dimensions This metric is collected only if the Process instance snapshot feature is turned on and triggered, and the time this metric is collected for is restricted to feature limits. To learn more, see Process instance snapshots.
builtin:process.cpu
Process average CPU
This metric provides the percentage of the CPU usage of a process. The metric value is the sum of CPU time every process worker uses divided by the total available CPU time. The result is expressed in percentage. A value of 100% indicates that the process uses all available CPU resources of the host. It has a "PID" (process.pid), "Parent PID" (process.parent_pid), "process owner" (process.owner), "process executable name" (process.executable.name), "process executable path" (process.executable.path), "process command line" (process.command_line) and "Process group instance" (dt.entity.process_group_instance) dimensions. This metric is collected only if the Process instance snapshot feature is turned on and triggered, and the time this metric is collected for is restricted to feature limits. To learn more, see Process instance snapshots.
Percent (%)autoavgcountmaxminsum
builtin:process.memory
Process memory
This metric provides the memory usage of a process. It helps to identify processes with high memory resource consumption and memory leaks. The result is expressed in bytes. It has a "PID" (process.pid), "Parent PID" (process.parent_pid), "process owner" (process.owner), "process executable name" (process.executable.name), "process executable path" (process.executable.path), "process command line" (process.command_line) and "Process group instance" (dt.entity.process_group_instance) dimensions This metric is collected only if the Process instance snapshot feature is turned on and triggered, and the time this metric is collected for is restricted to feature limits. To learn more, see Process instance snapshots.
Byteautoavgcountmaxminsum
Queue
Other queue metrics
builtin:queue.incoming_requests
Incoming messages
The number of incoming messages on the queue or topic
builtin:queue.outgoing_requests
Outgoing messages
The number of outgoing messages from the queue or topic
Security
Attack
builtin:security.attack.new
New attacks
Number of attacks that were recently created. The metric supports the management zone selector.
Countautovalue
Security problems
builtin:security.securityProblem.muted.new.global
New Muted Security Problems (global)
Number of vulnerabilities that were recently muted. The metric value is independent of any configured management zone (and thus global).
Countautovalue
builtin:security.securityProblem.open.new.global
New Open Security Problems (global)
Number of vulnerabilities that were recently created. The metric value is independent of any configured management zone (and thus global).
Countautovalue
builtin:security.securityProblem.open.new.managementZone
New Open Security Problems (split by Management Zone)
Number of vulnerabilities that were recently created. The metric value is split by management zone.
Countautovalue
builtin:security.securityProblem.open.global
Number of currently open vulnerabilities seen within the last minute. The metric value is independent of any configured management zone (and thus global).
Countautoavgmaxmin
builtin:security.securityProblem.open.managementZone
Number of currently open vulnerabilities seen within the last minute. The metric value is split by management zone.
Countautoavgmaxmin
builtin:security.securityProblem.resolved.new.global
New Resolved Security Problems (global)
Number of vulnerabilities that were recently resolved. The metric value is independent of any configured management zone (and thus global).
Countautovalue
Vulnerabilities
builtin:security.vulnerabilities.global.countAffectedProcessGroups.all
Vulnerabilities - affected process groups count (global)
Total number of unique affected process groups across all open vulnerabilities per technology. The metric value is independent of any configured management zone (and thus global).
Countautoavgmaxmin
builtin:security.vulnerabilities.global.countAffectedProcessGroups.notMuted
Vulnerabilities - affected not-muted process groups count (global)
Total number of unique affected process groups across all open, unmuted vulnerabilities per technology. The metric value is independent of any configured management zone (and thus global).
Countautoavgmaxmin
builtin:security.vulnerabilities.countAffectedEntities
Vulnerabilities - affected entities count
Total number of unique affected entities across all open vulnerabilities. The metric supports the management zone selector.
Countautovalue
Services
CPU
builtin:service.cpu.perRequest
CPU time
CPU time consumed by a particular request. To learn how Dynatrace calculates service timings, see Service analysis timings.
Microsecondautoavgcountmaxminsum
builtin:service.cpu.time
Service CPU time
CPU time consumed by a particular service. To learn how Dynatrace calculates service timings, see Service analysis timings.
Microsecondautovalue
Database connections
builtin:service.dbconnections.failure
Failed connections
Unsuccessful connection attempts compared to all connection attempts. To learn about database analysis, see Analyze database services.
Countautovalue
builtin:service.dbconnections.failureRate
Connection failure rate
Rate of unsuccessful connection attempts compared to all connection attempts. To learn about database analysis, see Analyze database services.
Percent (%)autovalue
builtin:service.dbconnections.success
Successful connections
Total number of database connections successfully established by this service. To learn about database analysis, see Analyze database services.
Countautovalue
builtin:service.dbconnections.successRate
Connection success rate
Rate of successful connection attempts compared to all connection attempts. To learn about database analysis, see Analyze database services.
builtin:service.dbconnections.total
Total number of connections
Total number of database connections that were attempted to be established by this service. To learn about database analysis, see Analyze database services.
Countautovalue
Errors
builtin:service.errors.client.count
Number of client side errors
Failed requests for a service measured on client side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.errors.client.rate
Failure rate (client side errors)
Percent (%)autoavg
builtin:service.errors.client.successCount
Number of calls without client side errors
Countautovalue
builtin:service.errors.fivexx.count
Number of HTTP 5xx errors
HTTP requests with a status code between 500 and 599 for a given key request measured on server side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.errors.fivexx.rate
Failure rate (HTTP 5xx errors)
Percent (%)autoavg
builtin:service.errors.fivexx.successCount
Number of calls without HTTP 5xx errors
Countautovalue
builtin:service.errors.fourxx.count
Number of HTTP 4xx errors
HTTP requests with a status code between 400 and 499 for a given key request measured on server side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.errors.fourxx.rate
Failure rate (HTTP 4xx errors)
Percent (%)autoavg
builtin:service.errors.fourxx.successCount
Number of calls without HTTP 4xx errors
Countautovalue
builtin:service.errors.server.count
Number of server side errors
Failed requests for a service measured on server side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.errors.server.rate
Failure rate (server side errors)
Percent (%)autoavg
builtin:service.errors.server.successCount
Number of calls without server side errors
Countautovalue
builtin:service.errors.total.count
Number of any errors
Failed requests for a service measured on server side or client side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.errors.total.rate
Failure rate (any errors)
Percent (%)autoavg
builtin:service.errors.total.successCount
Number of calls without any errors
Countautovalue
Key requests
builtin:service.keyRequest.count.client
Request count - client
Number of requests for a given key request - measured on the client side. This metric is written for each key request. To learn more about key requests, see Monitor key request.
Countautovalue
builtin:service.keyRequest.count.server
Request count - server
Number of requests for a given key request - measured on the server side. This metric is written for each key request. To learn more about key requests, see Monitor key request.
Countautovalue
builtin:service.keyRequest.count.total
Request count
Number of requests for a given key request. This metric is written for each key request. To learn more about key requests, see Monitor key request.
Countautovalue
builtin:service.keyRequest.cpu.perRequest
CPU per request
CPU time for a given key request. This metric is written for each key request. To learn more about key requests, see Monitor key request.
builtin:service.keyRequest.cpu.time
Service key request CPU time
builtin:service.keyRequest.errors.client.count
Failed requests for a given key request measured on client side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.keyRequest.errors.client.rate
Percent (%)autoavg
builtin:service.keyRequest.errors.client.successCount
Countautovalue
builtin:service.keyRequest.errors.fivexx.count
Rate of HTTP requests with a status code between 500 and 599 of a given key request. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.keyRequest.errors.fivexx.rate
Percent (%)autoavg
builtin:service.keyRequest.errors.fivexx.successCount
Countautovalue
builtin:service.keyRequest.errors.fourxx.count
Rate of HTTP requests with a status code between 400 and 499 of a given key request. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.keyRequest.errors.fourxx.rate
Percent (%)autoavg
builtin:service.keyRequest.errors.fourxx.successCount
Countautovalue
builtin:service.keyRequest.errors.server.count
Failed requests for a given key request measured on server side. To learn about failure detection, see Configure service failure detection.
Countautovalue
builtin:service.keyRequest.errors.server.rate
Percent (%)autoavg
builtin:service.keyRequest.errors.server.successCount
Countautovalue
builtin:service.keyRequest.response.client
Client side response time
Response time for a given key request - measured on the client side. This metric is written for each key request. To learn more about key requests, see Monitor key request.
Microsecondautoavgcountmaxmedianminpercentilesum
builtin:service.keyRequest.response.server
Server side response time
Response time for a given key request - measured on the server side. This metric is written for each request. To learn more about key requests, see Monitor key request.
builtin:service.keyRequest.response.time
Key request response time
Response time for a given key request. This metric is written for each key request. To learn more about key requests, see Monitor key request.
builtin:service.keyRequest.successes.server.rate
Success rate (server side)
Percent (%)autoavg
builtin:service.keyRequest.dbChildCallCount
Number of calls to databases
Countautovalue
builtin:service.keyRequest.dbChildCallTime
Time spent in database calls
builtin:service.keyRequest.ioTime
IO time
builtin:service.keyRequest.lockTime
Lock time
builtin:service.keyRequest.nonDbChildCallCount
Number of calls to other services
Countautovalue
builtin:service.keyRequest.nonDbChildCallTime
Time spent in calls to other services
builtin:service.keyRequest.totalProcessingTime
Total processing time
Total processing time for a given key request. This time includes potential further asynchronous processing. This metric is written for each key request. To learn more about key requests, see Monitor key request.
builtin:service.keyRequest.waitTime
Wait time
Request
builtin:service.request.service_mesh.count
Unified service mesh request count
Number of service mesh requests received by a given service. To learn how Dynatrace detects services, see Service detection and naming.
Countautovalue
builtin:service.request.service_mesh.count_service_aggregation
Unified service mesh request count (by service)
Number of service mesh requests received by a given service. Reduced dimensions for faster charting. To learn how Dynatrace detects services, see Service detection and naming.
Countautovalue
builtin:service.request.service_mesh.failure_count
Unified service mesh request failure count
Number of failed service mesh requests received by a given service. To learn how Dynatrace detects service failures, see Configure service failure detection.
Countautovalue
builtin:service.request.service_mesh.failure_count_service_aggregation
Unified service mesh request failure count (by service)
Number of failed service mesh requests received by a given service. Reduced dimensions for faster charting. To learn how Dynatrace detects service failures, see Configure service failure detection.
Countautovalue
builtin:service.request.service_mesh.response_time
Unified service mesh request response time
Response time of a service mesh ingress measured in microseconds. To learn how Dynatrace calculates service timings, see Service analysis timings.
Millisecondautocountmaxmedianminpercentile
builtin:service.request.service_mesh.response_time_service_aggregation
Unified service mesh request response time (by service)
Response time of a service mesh ingress measured in microseconds. Reduced dimensions for faster charting. To learn how Dynatrace calculates service timings, see Service analysis timings.
builtin:service.request.count_chart
Unified service request count (by service, endpoint)
Number of requests received by a given service. Reduced dimensions for faster charting. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
builtin:service.request.count_service_aggregation
Unified service request count (by service)
Countautovalue
builtin:service.request.failure_count
Unified service failure count
Number of failed requests received by a given service. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
builtin:service.request.failure_count_chart
Unified service failure count (by service, endpoint)
Number of failed requests received by a given service. Reduced dimensions for faster charting. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
builtin:service.request.failure_count_service_aggregation
Unified service failure count (by service)
Countautovalue
builtin:service.request.response_time_chart
Unified service request response time (by service, endpoint)
Response time of a service measured in microseconds on the server side. Response time is the time until a response is sent to a calling application, process or other service. It does not include further asynchronous processing. Reduced dimensions for faster charting. To learn how Dynatrace calculates service timings, see Service analysis timings.
builtin:service.request.response_time_service_aggregation
Unified service request response time (by service)
Request count
builtin:service.requestCount.client
Number of requests received by a given service - measured on the client side. This metric allows service splittings. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
builtin:service.requestCount.server
Number of requests received by a given service - measured on the server side. This metric allows service splittings. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
builtin:service.requestCount.total
Request count
Number of requests received by a given service. This metric allows service splittings. To learn how Dynatrace detects and analyzes services, see Services.
Countautovalue
Response time
builtin:service.response.group.client
Response time for a given key request per request type - measured on the client side. This metric is written for each key request. To learn more about key requests, see Monitor key request.
builtin:service.response.group.server
Response time for a given key request per request type - measured on the server side. This metric is written for each key request. To learn more about key requests, see Monitor key request.
builtin:service.response.client
builtin:service.response.server
builtin:service.response.time
Response time
Time consumed by a particular service until a response is sent back to the calling application, process, service etc.To learn how Dynatrace calculates service timings, see Service analysis timings.
Success rate
builtin:service.successes.server.rate
Percent (%)autoavg
builtin:service.totalProcessingTime.group.totalProcessingTime
Total time consumed by a particular request type including asynchronous processing. Time includes the factor that asynchronous processing can still occur after responses are sent. To learn how Dynatrace calculates service timings, see Service analysis timings.
Other services metrics
Total time consumed by a particular service including asynchronous processing. Time includes the factor that asynchronous processing can still occur after responses are sent.To learn how Dynatrace calculates service timings, see Service analysis timings.
builtin:service.dbChildCallCount
Countautovalue
builtin:service.dbChildCallTime
builtin:service.ioTime
IO time
builtin:service.lockTime
Lock time
builtin:service.nonDbChildCallCount
Countautovalue
builtin:service.nonDbChildCallTime
builtin:service.waitTime
Wait time
Synthetic monitoring
Browser
builtin:synthetic.browser.actionDuration.custom
Action duration - custom action [browser monitor]
The duration of custom actions; split by monitor.
Millisecondautoavgcountmaxmedianminpercentilesum
builtin:synthetic.browser.actionDuration.custom.geo
Action duration - custom action (by geolocation) [browser monitor]
The duration of custom actions; split by monitor, geolocation.
builtin:synthetic.browser.actionDuration.load
Action duration - load action [browser monitor]
The duration of load actions; split by monitor.
builtin:synthetic.browser.actionDuration.load.geo
Action duration - load action (by geolocation) [browser monitor]
The duration of load actions; split by monitor, geolocation.
builtin:synthetic.browser.actionDuration.xhr
Action duration - XHR action [browser monitor]
The duration of XHR actions; split by monitor.
builtin:synthetic.browser.actionDuration.xhr.geo
Action duration - XHR action (by geolocation) [browser monitor]
The duration of XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.availability
Monitor availability [browser monitor]
builtin:synthetic.browser.availability.location.total
Availability rate (by location) [browser monitor]
The availability rate of browser monitors.
Percent (%)autoavg
builtin:synthetic.browser.availability.location.totalWoMaintenanceWindow
Availability rate - excl. maintenance windows (by location) [browser monitor]
The availability rate of browser monitors excluding maintenance windows.
Percent (%)autoavg
builtin:synthetic.browser.cumulativeLayoutShift.load
Cumulative layout shift - load action [browser monitor]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions; split by monitor.
builtin:synthetic.browser.cumulativeLayoutShift.load.geo
Cumulative layout shift - load action (by geolocation) [browser monitor]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.domInteractive.load
DOM interactive - load action [browser monitor]
The time taken until a page's status is set to "interactive" and it's ready to receive input. Calculated for load actions; split by monitor
builtin:synthetic.browser.domInteractive.load.geo
DOM interactive - load action (by geolocation) [browser monitor]
The time taken until a page's status is set to "interactive" and it's ready to receive input. Calculated for load actions; split by monitor, geolocation
builtin:synthetic.browser.errorCodes
Error details (by error code) [browser monitor]
The number of detected errors; split by monitor, error code.
Countautovalue
builtin:synthetic.browser.errorCodes.geo
Error details (by geolocation, error code) [browser monitor]
The number of detected errors; split by monitor executions.
Countautovalue
builtin:synthetic.browser.event.actionDuration.custom
Action duration - custom action (by event) [browser monitor]
The duration of custom actions; split by event.
builtin:synthetic.browser.event.actionDuration.custom.geo
Action duration - custom action (by event, geolocation) [browser monitor]
The duration of custom actions; split by event, geolocation.
builtin:synthetic.browser.event.actionDuration.load
Action duration - load action (by event) [browser monitor]
The duration of load actions; split by event.
builtin:synthetic.browser.event.actionDuration.load.geo
Action duration - load action (by event, geolocation) [browser monitor]
The duration of load actions; split by event, geolocation.
builtin:synthetic.browser.event.actionDuration.xhr
Action duration - XHR action (by event) [browser monitor]
The duration of XHR actions; split by event.
builtin:synthetic.browser.event.actionDuration.xhr.geo
Action duration - XHR action (by event, geolocation) [browser monitor]
The duration of XHR actions; split by event, geolocation.
builtin:synthetic.browser.event.cumulativeLayoutShift.load
Cumulative layout shift - load action (by event) [browser monitor]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions; split by event.
builtin:synthetic.browser.event.cumulativeLayoutShift.load.geo
Cumulative layout shift - load action (by event, geolocation) [browser monitor]
The score measuring the unexpected shifting of visible webpage elements. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.domInteractive.load
DOM interactive - load action (by event) [browser monitor]
The time taken until a page's status is set to "interactive" and it's ready to receive input. Calculated for load actions; split by event
builtin:synthetic.browser.event.domInteractive.load.geo
DOM interactive - load action (by event, geolocation) [browser monitor]
The time taken until a page's status is set to "interactive" and it's ready to receive input. Calculated for load actions; split by event, geolocation
builtin:synthetic.browser.event.errorCodes
Error details (by event, error code) [browser monitor]
The number of detected errors; split by event, error code.
Countautovalue
builtin:synthetic.browser.event.errorCodes.geo
Error details (by event, geolocation, error code) [browser monitor]
The number of detected errors; split by event, geolocation, error code.
Countautovalue
builtin:synthetic.browser.event.failure
Failed events count (by event) [browser monitor]
The number of failed monitor events; split by event.
Countautovalue
builtin:synthetic.browser.event.failure.geo
Failed events count (by event, geolocation) [browser monitor]
The number of failed monitor events; split by event, geolocation.
Countautovalue
builtin:synthetic.browser.event.firstByte.load
Time to first byte - load action (by event) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions; split by event.
builtin:synthetic.browser.event.firstByte.load.geo
Time to first byte - load action (by event, geolocation) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.firstByte.xhr
Time to first byte - XHR action (by event) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions; split by event.
builtin:synthetic.browser.event.firstByte.xhr.geo
Time to first byte - XHR action (by event, geolocation) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions; split by event, geolocation.
builtin:synthetic.browser.event.largestContentfulPaint.load
Largest contentful paint - load action (by event) [browser monitor]
The time taken to render the largest element in the viewport. Calculated for load actions; split by event.
builtin:synthetic.browser.event.largestContentfulPaint.load.geo
Largest contentful paint - load action (by event, geolocation) [browser monitor]
The time taken to render the largest element in the viewport. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.loadEventEnd.load
Load event end - load action (by event) [browser monitor]
The time taken to complete the load event of a page. Calculated for load actions; split by event.
builtin:synthetic.browser.event.loadEventEnd.load.geo
Load event end - load action (by event, geolocation) [browser monitor]
The time taken to complete the load event of a page. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.loadEventStart.load
Load event start - load action (by event) [browser monitor]
The time taken to begin the load event of a page. Calculated for load actions; split by event.
builtin:synthetic.browser.event.loadEventStart.load.geo
Load event start - load action (by event, geolocation) [browser monitor]
The time taken to begin the load event of a page. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.networkContribution.load
Network contribution - load action (by event) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions; split by event.
builtin:synthetic.browser.event.networkContribution.load.geo
Network contribution - load action (by event, geolocation) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.networkContribution.xhr
Network contribution - XHR action (by event) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions; split by event.
builtin:synthetic.browser.event.networkContribution.xhr.geo
Network contribution - XHR action (by event, geolocation) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions; split by event, geolocation.
builtin:synthetic.browser.event.responseEnd.load
Response end - load action (by event) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions; split by event.
builtin:synthetic.browser.event.responseEnd.load.geo
Response end - load action (by event, geolocation) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.responseEnd.xhr
Response end - XHR action (by event) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions; split by event.
builtin:synthetic.browser.event.responseEnd.xhr.geo
Response end - XHR action (by event, geolocation) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions; split by event, geolocation.
builtin:synthetic.browser.event.serverContribution.load
Server contribution - load action (by event) [browser monitor]
The time spent on server-side processing for a page. Calculated for load actions; split by event.
builtin:synthetic.browser.event.serverContribution.load.geo
Server contribution - load action (by event, geolocation) [browser monitor]
The time spent on server-side processing for a page. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.serverContribution.xhr
Server contribution - XHR action (by event) [browser monitor]
The time spent on server-side processing for a page. Calculated for XHR actions; split by event.
builtin:synthetic.browser.event.serverContribution.xhr.geo
Server contribution - XHR action (by event, geolocation) [browser monitor]
The time spent on server-side processing for a page. Calculated for XHR actions; split by event, geolocation.
builtin:synthetic.browser.event.speedIndex.load
Speed index - load action (by event) [browser monitor]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions; split by event.
builtin:synthetic.browser.event.speedIndex.load.geo
Speed index - load action (by event, geolocation) [browser monitor]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.success
Successful events count (by event) [browser monitor]
The number of successful monitor events; split by event.
Countautovalue
builtin:synthetic.browser.event.success.geo
Successful events count (by event, geolocation) [browser monitor]
The number of successful monitor events; split by event, geolocation.
Countautovalue
builtin:synthetic.browser.event.total
Total events count (by event) [browser monitor]
The total number of monitor events executions executions; split by event.
Countautovalue
builtin:synthetic.browser.event.total.geo
Total events count (by event, geolocation) [browser monitor]
The total number of monitor events executions; split by event, geolocation.
Countautovalue
builtin:synthetic.browser.event.totalDuration
Total duration (by event) [browser monitor]
The duration of all actions in an event; split by event.
builtin:synthetic.browser.event.totalDuration.geo
Total duration (by event, geolocation) [browser monitor]
The duration of all actions in an event; split by event, geolocation.
builtin:synthetic.browser.event.visuallyComplete.load
Visually complete - load action (by event) [browser monitor]
The time taken to fully render content in the viewport. Calculated for load actions; split by event.
builtin:synthetic.browser.event.visuallyComplete.load.geo
Visually complete - load action (by event, geolocation) [browser monitor]
The time taken to fully render content in the viewport. Calculated for load actions; split by event, geolocation.
builtin:synthetic.browser.event.visuallyComplete.xhr
Visually complete - XHR action (by event) [browser monitor]
The time taken to fully render content in the viewport. Calculated for XHR actions; split by event.
builtin:synthetic.browser.event.visuallyComplete.xhr.geo
Visually complete - XHR action (by event, geolocation) [browser monitor]
The time taken to fully render content in the viewport. Calculated for XHR actions; split by event, geolocation.
builtin:synthetic.browser.failure
Failed executions count [browser monitor]
The number of failed monitor executions; split by monitor.
Countautovalue
builtin:synthetic.browser.failure.geo
Failed executions count (by geolocation) [browser monitor]
The number of failed monitor executions; split by monitor, geolocation.
Countautovalue
builtin:synthetic.browser.firstByte.load
Time to first byte - load action [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions; split by monitor.
builtin:synthetic.browser.firstByte.load.geo
Time to first byte - load action (by geolocation) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.firstByte.xhr
Time to first byte - XHR action [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions; split by monitor.
builtin:synthetic.browser.firstByte.xhr.geo
Time to first byte - XHR action (by geolocation) [browser monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.largestContentfulPaint.load
Largest contentful paint - load action [browser monitor]
The time taken to render the largest element in the viewport. Calculated for load actions; split by monitor.
builtin:synthetic.browser.largestContentfulPaint.load.geo
Largest contentful paint - load action (by geolocation) [browser monitor]
The time taken to render the largest element in the viewport. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.loadEventEnd.load
Load event end - load action [browser monitor]
The time taken to complete the load event of a page. Calculated for load actions; split by monitor.
builtin:synthetic.browser.loadEventEnd.load.geo
Load event end - load action (by geolocation) [browser monitor]
The time taken to complete the load event of a page. Calculated for load actions; split by monitor, geolocation.
Millisecondautoavgcountmaxminsum
builtin:synthetic.browser.loadEventStart.load
Load event start - load action [browser monitor]
The time taken to begin the load event of a page. Calculated for load actions; split by monitor.
builtin:synthetic.browser.loadEventStart.load.geo
Load event start - load action (by geolocation) [browser monitor]
The time taken to begin the load event of a page. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.networkContribution.load
Network contribution - load action [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions; split by monitor.
builtin:synthetic.browser.networkContribution.load.geo
Network contribution - load action (by geolocation) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.networkContribution.xhr
Network contribution - XHR action [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions; split by monitor.
builtin:synthetic.browser.networkContribution.xhr.geo
Network contribution - XHR action (by geolocation) [browser monitor]
The time taken to request and receive resources (including DNS lookup, redirect, and TCP connect time). Calculated for XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.responseEnd.load
Response end - load action [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions; split by monitor.
builtin:synthetic.browser.responseEnd.load.geo
Response end - load action (by geolocation) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.responseEnd.xhr
Response end - XHR action [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions; split by monitor.
builtin:synthetic.browser.responseEnd.xhr.geo
Response end - XHR action (by geolocation) [browser monitor]
(AKA HTML downloaded) The time taken until the user agent receives the last byte of the response or the transport connection is closed, whichever comes first. Calculated for XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.serverContribution.load
Server contribution - load action [browser monitor]
The time spent on server-side processing for a page. Calculated for load actions; split by monitor.
builtin:synthetic.browser.serverContribution.load.geo
Server contribution - load action (by geolocation) [browser monitor]
The time spent on server-side processing for a page. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.serverContribution.xhr
Server contribution - XHR action [browser monitor]
The time spent on server-side processing for a page. Calculated for XHR actions; split by monitor.
builtin:synthetic.browser.serverContribution.xhr.geo
Server contribution - XHR action (by geolocation) [browser monitor]
The time spent on server-side processing for a page. Calculated for XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.speedIndex.load
Speed index - load action [browser monitor]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions; split by monitor.
builtin:synthetic.browser.speedIndex.load.geo
Speed index - load action (by geolocation) [browser monitor]
The score measuring how quickly the visible parts of a page are rendered. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.step.user_events.duration
User events duration (step) [browser monitor]
Duration of individual browser monitor step, measured from the start of the first user event of the step to the end of the last user event of the step. The metric source is the new RUM JavaScript.
builtin:synthetic.browser.step.user_events.total_duration
User events total duration (step) [browser monitor]
Total duration of individual browser monitor step, measured as a sum of durations of all user events in the step. The metric source is the new RUM JavaScript.
builtin:synthetic.browser.step.duration
Duration (step) [browser monitor]
Duration of individual browser monitor step, measured as a sum of durations of user action events in the step.
builtin:synthetic.browser.success
Successful executions count [browser monitor]
The number of successful monitor executions; split by monitor.
Countautovalue
builtin:synthetic.browser.success.geo
Successful executions count (by geolocation) [browser monitor]
The number of successful monitor executions; split by monitor, geolocation.
Countautovalue
builtin:synthetic.browser.total
Total executions count [browser monitor]
The total number of monitor executions executions; split by monitor.
Countautovalue
builtin:synthetic.browser.total.geo
Total executions count (by geolocation) [browser monitor]
The total number of monitor executions executions; split by monitor, geolocation.
Countautovalue
builtin:synthetic.browser.totalDuration
Total duration [browser monitor]
The duration of all actions in an event; split by monitor.
builtin:synthetic.browser.totalDuration.geo
Total duration (by geolocation) [browser monitor]
The duration of all actions in an event; split by monitor, geolocation.
builtin:synthetic.browser.user_events.duration
User events duration [browser monitor]
Duration of browser monitor, calculated as a sum of all steps-level user events durations. The metric source is the new RUM JavaScript.
builtin:synthetic.browser.user_events.total_duration
User events total duration [browser monitor]
Total duration of browser monitor, measured as a sum of all steps-level values of "User events total duration" metric. The metric source is the new RUM JavaScript.
builtin:synthetic.browser.visuallyComplete.load
Visually complete - load action [browser monitor]
The time taken to fully render content in the viewport. Calculated for load actions; split by monitor.
builtin:synthetic.browser.visuallyComplete.load.geo
Visually complete - load action (by geolocation) [browser monitor]
The time taken to fully render content in the viewport. Calculated for load actions; split by monitor, geolocation.
builtin:synthetic.browser.visuallyComplete.xhr
Visually complete - XHR action [browser monitor]
The time taken to fully render content in the viewport. Calculated for XHR actions; split by monitor.
builtin:synthetic.browser.visuallyComplete.xhr.geo
Visually complete - XHR action (by geolocation) [browser monitor]
The time taken to fully render content in the viewport. Calculated for XHR actions; split by monitor, geolocation.
builtin:synthetic.browser.duration
Duration [browser monitor]
Duration of browser monitor, calculated as a sum of all steps durations.
HTTP
Metric keyName and descriptionUnitAggregations
builtin:synthetic.http.availability
Monitor availability [HTTP monitor]
Countautoavgcountmaxminsum
builtin:synthetic.http.availability.location.total
Availability rate (by location) [HTTP monitor]
The availability rate of HTTP monitors.
Percent (%)autoavg
builtin:synthetic.http.availability.location.totalWoMaintenanceWindow
Availability rate - excl. maintenance windows (by location) [HTTP monitor]
The availability rate of HTTP monitors excluding maintenance windows.
Percent (%)autoavg
builtin:synthetic.http.dns.geo
DNS lookup time (by location) [HTTP monitor]
The time taken to resolve the hostname for a target URL for the sum of all requests.
builtin:synthetic.http.duration.geo
Duration (by location) [HTTP monitor]
The duration of the sum of all requests.
builtin:synthetic.http.execution.status
Execution count (by status) [HTTP monitor]
The number of monitor executions.
Countautovalue
builtin:synthetic.http.request.dns.geo
DNS lookup time (by request, location) [HTTP monitor]
The time taken to resolve the hostname for a target URL for individual HTTP requests.
builtin:synthetic.http.request.duration.geo
Duration (by request, location) [HTTP monitor]
The duration of individual HTTP requests.
builtin:synthetic.http.request.responseSize.geo
Response size (by request, location) [HTTP monitor]
The response size of individual HTTP requests.
builtin:synthetic.http.request.tcpConnectTime.geo
TCP connect time (by request, location) [HTTP monitor]
The time taken to establish the TCP connection to the server (including SSL) for individual HTTP requests.
builtin:synthetic.http.request.timeToFirstByte.geo
Time to first byte (by request, location) [HTTP monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for individual HTTP requests.
builtin:synthetic.http.request.tlsHandshakeTime.geo
TLS handshake time (by request, location) [HTTP monitor]
The time taken to complete the TLS handshake for individual HTTP requests.
builtin:synthetic.http.request.durationThreshold
Duration threshold (request) (by request) [HTTP monitor]
The performance threshold for individual HTTP requests.
builtin:synthetic.http.request.resultStatus
Result status count (by request, location) [HTTP monitor]
The number of request executions with success/failure result status.
builtin:synthetic.http.request.statusCode
Status code count (by request, location) [HTTP monitor]
The number of request executions that end with an HTTP status code.
Countautovalue
builtin:synthetic.http.responseSize.geo
Response size (by location) [HTTP monitor]
The response size of the sum of all requests.
builtin:synthetic.http.tcpConnectTime.geo
TCP connect time (by location) [HTTP monitor]
The time taken to establish the TCP connection to the server (including SSL) for the sum of all requests.
builtin:synthetic.http.timeToFirstByte.geo
Time to first byte (by location) [HTTP monitor]
The time taken until the first byte of the response is received from the server, relevant application caches, or a local resource. Calculated for the sum of all requests.
builtin:synthetic.http.tlsHandshakeTime.geo
TLS handshake time (by location) [HTTP monitor]
The time taken to complete the TLS handshake for the sum of all requests.
builtin:synthetic.http.durationThreshold
Duration threshold [HTTP monitor]
The performance threshold for the sum of all requests.
builtin:synthetic.http.resultStatus
Result status count (by location) [HTTP monitor]
The number of monitor executions with success/failure result status.
builtin:synthetic.http.statusCode
Status code count (by location) [HTTP monitor]
The number of monitor executions that end with an HTTP status code.
Countautovalue
Location
builtin:synthetic.location.node.component.healthStatus
Node health status count [synthetic]
The number of private Synthetic nodes and their health status.
builtin:synthetic.location.healthStatus
Private location health status count [synthetic]
The number of private Synthetic locations and their health status.
MultiProtocol
builtin:synthetic.multiProtocol.availability
Monitor availability [Network Availability monitor]
builtin:synthetic.multiProtocol.availability.excludingMaintenanceWindows
Monitor availability excluding maintenance windows [Network Availability monitor]
builtin:synthetic.multiProtocol.dns.resolutionTime
DNS request resolution time [Network Availability request]
builtin:synthetic.multiProtocol.icmp.packetsReceived
Number of successful ICMP packets [Network Availability request]
builtin:synthetic.multiProtocol.icmp.packetsSent
Number of ICMP packets [Network Availability request]
builtin:synthetic.multiProtocol.icmp.requestExecutionTime
ICMP request execution time [Network Availability request]
builtin:synthetic.multiProtocol.icmp.roundTripTime
ICMP round trip time [Network Availability request]
builtin:synthetic.multiProtocol.icmp.successRate
ICMP request success rate [Network Availability request]
builtin:synthetic.multiProtocol.request.availability
Request availability [Network Availability request]
builtin:synthetic.multiProtocol.request.availability.excludingMaintenanceWindows
Request availability excluding maintenance windows [Network Availability request]
builtin:synthetic.multiProtocol.request.executionTime
Request execution time [Network Availability request]
builtin:synthetic.multiProtocol.request.executions
Execution count (by status) [Network Availability request]
Countautovalue
builtin:synthetic.multiProtocol.step.availability
Step availability [Network Availability step]
builtin:synthetic.multiProtocol.step.availability.excludingMaintenanceWindows
Step availability excluding maintenance windows [Network Availability step]
builtin:synthetic.multiProtocol.step.executionTime
Step execution time [Network Availability step]
builtin:synthetic.multiProtocol.step.executions
Execution count (by status) [Network Availability step]
Countautovalue
builtin:synthetic.multiProtocol.step.successRate
Step success rate [Network Availability step]
builtin:synthetic.multiProtocol.tcp.connectionTime
TCP request connection time [Network Availability request]
builtin:synthetic.multiProtocol.executionTime
Monitor execution time [Network Availability monitor]
builtin:synthetic.multiProtocol.executions
Execution count (by status) [Network Availability monitor]
Countautovalue
builtin:synthetic.multiProtocol.successRate
Monitor success rate [Network Availability monitor]
Third party
builtin:synthetic.external.availability.location.total
Availability rate (by location) [third-party monitor]
The availability rate of third-party monitors.
Percent (%)autoavg
builtin:synthetic.external.availability.location.totalWoMaintenanceWindow
Availability rate - excl. maintenance windows (by location) [third-party monitor]
The availability rate of third-party monitors excluding maintenance windows.
Percent (%)autoavg
builtin:synthetic.external.errorDetails
Error count [third-party monitor]
The number of detected errors; split by monitor, step, error code.
Countautovalue
builtin:synthetic.external.errorDetails.geo
Error count (by location) [third-party monitor]
The number of detected errors; split by monitor, location, step, error code.
Countautovalue
builtin:synthetic.external.quality
Test quality rate [third-party monitor]
The test quality rate. Calculated by dividing successful steps by the total number of steps executed; split by monitor.
Percent (%)autoavgmaxmin
builtin:synthetic.external.quality.geo
Test quality rate (by location) [third-party monitor]
The test quality rate. Calculated by dividing successful steps by the total number of steps executed; split by monitor, location.
builtin:synthetic.external.responseTime
Response time [third-party monitor]
The response time of third-party monitors; split by monitor.
builtin:synthetic.external.responseTime.geo
Response time (by location) [third-party monitor]
The response time of third-party monitors; split by monitor, location.
builtin:synthetic.external.step.responseTime
Response time (by step) [third-party monitor]
The response time of third-party monitors; split by step.
builtin:synthetic.external.step.responseTime.geo
Response time (by step, location) [third-party monitor]
The response time of third-party monitors; split by step, location.
Technologies
.NET
builtin:tech.dotnet.gc.gen0Collections
.NET garbage collection (# Gen 0)
Number of completed GC runs that collected objects in Gen0 Heap within the given time range, https://dt-url.net/i1038bq
Countautovalue
builtin:tech.dotnet.gc.gen1Collections
.NET garbage collection (# Gen 1)
Number of completed GC runs that collected objects in Gen1 Heap within the given time range, https://dt-url.net/i1038bq
Countautovalue
builtin:tech.dotnet.gc.gen2Collections
.NET garbage collection (# Gen 2)
Number of completed GC runs that collected objects in Gen2 Heap within the given time range, https://dt-url.net/i1038bq
Countautovalue
builtin:tech.dotnet.gc.timePercentage
.NET % time in GC
Percentage time spend within garbage collection
builtin:tech.dotnet.jit.timePercentage
.NET % time in JIT
.NET % time in Just in Time compilation
builtin:tech.dotnet.managedThreads.avgNumOfActiveThreads
.NET average number of active threads
Countautoavgmaxmin
builtin:tech.dotnet.memory.LOHConsumption
.NET memory consumption (Large Object Heap)
.NET memory consumption for objects within Large Object Heap, https://dt-url.net/es238z7
Byteautoavgmaxmin
builtin:tech.dotnet.memory.gen0Consumption
.NET memory consumption (heap size Gen 0)
.NET memory consumption for objects within heap Gen0, https://dt-url.net/i1038bq
Byteautoavgmaxmin
builtin:tech.dotnet.memory.gen1Consumption
.NET memory consumption (heap size Gen 1)
.NET memory consumption for objects within heap Gen1, https://dt-url.net/i1038bq
Byteautoavgmaxmin
builtin:tech.dotnet.memory.gen2Consumption
.NET memory consumption (heap size Gen 2)
.NET memory consumption for objects within heap Gen2, https://dt-url.net/i1038bq
Byteautoavgmaxmin
builtin:tech.dotnet.perfmon."#BytesInAllHeaps"
Bytes in all heaps
builtin:tech.dotnet.perfmon."#Gen0Collections"
Gen 0 Collections
builtin:tech.dotnet.perfmon."#Gen1Collections"
Gen 1 Collections
builtin:tech.dotnet.perfmon."#Gen2Collections"
Gen 2 Collections
builtin:tech.dotnet.perfmon."#OfCurrentLogicalThreads"
Logical threads
builtin:tech.dotnet.perfmon."#OfCurrentPhysicalThreads"
Physical threads
builtin:tech.dotnet.perfmon."#TotalCommittedBytes"
Committed bytes
builtin:tech.dotnet.perfmon."#TotalReservedBytes"
Reserved bytes
builtin:tech.dotnet.perfmon."%TimeInGC"
Time in GC
builtin:tech.dotnet.perfmon.ContentionRate
Contention rate
Per secondautoavgcountmaxminsum
builtin:tech.dotnet.perfmon.CurrentQueueLength
Queue length
builtin:tech.dotnet.perfmon.Gen0HeapSize
Gen 0 Heap size
builtin:tech.dotnet.perfmon.Gen1HeapSize
Gen 1 Heap size
builtin:tech.dotnet.perfmon.Gen2HeapSize
Gen 2 Heap size
builtin:tech.dotnet.threadpool.ioCompletionThreads
.NET managed thread pool active io completion threads
Countautoavgmaxmin
builtin:tech.dotnet.threadpool.queuedWorkItems
.NET managed thread pool queued work items
Countautoavgmaxmin
builtin:tech.dotnet.threadpool.workerThreads
.NET managed thread pool active worker threads
Countautoavgmaxmin
Apache Hadoop
builtin:tech.Hadoop.hdfs.BlocksTotal
Blocks number
builtin:tech.Hadoop.hdfs.CacheCapacity
Cache capacity
builtin:tech.Hadoop.hdfs.CacheUsed
Cache used
builtin:tech.Hadoop.hdfs.CapacityRemaining
Remaining capacity
builtin:tech.Hadoop.hdfs.CapacityTotal
Total capacity
builtin:tech.Hadoop.hdfs.CapacityUsed
Used capacity
builtin:tech.Hadoop.hdfs.CapacityUsedNonDFS
Capacity used non DFS
builtin:tech.Hadoop.hdfs.CorruptBlocks
Corrupted blocks
builtin:tech.Hadoop.hdfs.EstimatedCapacityLostTotal
Estimated capacity total loses
builtin:tech.Hadoop.hdfs.FilesAppended
Appended files
builtin:tech.Hadoop.hdfs.FilesCreated
Created files
builtin:tech.Hadoop.hdfs.FilesDeleted
Deleted files
builtin:tech.Hadoop.hdfs.FilesRenamed
Renamed files
builtin:tech.Hadoop.hdfs.FilesTotal
Files number
builtin:tech.Hadoop.hdfs.NumDeadDataNodes
Dead DataNodes
builtin:tech.Hadoop.hdfs.NumDecomDeadDataNodes
Dead decommissioning DataNodes
builtin:tech.Hadoop.hdfs.NumDecomLiveDataNodes
Live decommissioning DataNodes
builtin:tech.Hadoop.hdfs.NumDecommissioningDataNodes
Number of decommissioning DataNodes
builtin:tech.Hadoop.hdfs.NumLiveDataNodes
Live DataNodes
builtin:tech.Hadoop.hdfs.NumStaleDataNodes
Number of stale dataNodes
builtin:tech.Hadoop.hdfs.NumberOfMissingBlocks
Number of missing blocks
builtin:tech.Hadoop.hdfs.PendingDeletionBlocks
Pending deletion blocks
builtin:tech.Hadoop.hdfs.PendingReplicationBlocks
Pending replication blocks
builtin:tech.Hadoop.hdfs.ScheduledReplicationBlocks
Scheduled replication blocks
builtin:tech.Hadoop.hdfs.TotalLoad
Total load
builtin:tech.Hadoop.hdfs.UnderReplicatedBlocks
Under replicated blocks
builtin:tech.Hadoop.hdfs.VolumeFailuresTotal
Volume failures total
builtin:tech.Hadoop.yarn.AllocatedContainers
Allocated containers
builtin:tech.Hadoop.yarn.AllocatedMB
Allocated memory
MBautoavgcountmaxminsum
builtin:tech.Hadoop.yarn.AllocatedVCores
Allocated CPU in virtual cores
builtin:tech.Hadoop.yarn.AppsCompleted
Completed applications
builtin:tech.Hadoop.yarn.AppsFailed
Failed applications
builtin:tech.Hadoop.yarn.AppsKilled
Killed applications
builtin:tech.Hadoop.yarn.AppsPending
Pending applications
builtin:tech.Hadoop.yarn.AppsRunning
Running applications
builtin:tech.Hadoop.yarn.AppsSubmitted
Submitted applications
builtin:tech.Hadoop.yarn.AvailableMB
Available memory
builtin:tech.Hadoop.yarn.AvailableVCores
Available CPU in virtual cores
builtin:tech.Hadoop.yarn.NumActiveNMs
Active NodeManagers
builtin:tech.Hadoop.yarn.NumDecommissionedNMs
Decommissioned NodeManagers
builtin:tech.Hadoop.yarn.NumLostNMs
Lost NodeManagers
builtin:tech.Hadoop.yarn.NumRebootedNMs
Rebooted NodeManagers
builtin:tech.Hadoop.yarn.NumUnhealthyNMs
Unhealthy NodeManagers
builtin:tech.Hadoop.yarn.PendingMB
Pending memory requests
builtin:tech.Hadoop.yarn.PendingVCores
Pending CPU in virtual cores requests
builtin:tech.Hadoop.yarn.ReservedMB
Reserved memory
builtin:tech.Hadoop.yarn.ReservedVCores
Reserved CPU in virtual cores requests
Apache Tomcat
builtin:tech.tomcat.connectionPool.maxActive
Max active
builtin:tech.tomcat.connectionPool.maxActiveGlobal
Max active (global)
builtin:tech.tomcat.connectionPool.maxTotal
Max total
builtin:tech.tomcat.connectionPool.maxTotalGlobal
Max total (global)
builtin:tech.tomcat.connectionPool.numActive
Num active
builtin:tech.tomcat.connectionPool.numActiveGlobal
Num active (global)
builtin:tech.tomcat.connectionPool.numIdle
Num idle
builtin:tech.tomcat.connectionPool.numIdleGlobal
Num idle (global)
builtin:tech.tomcat.connectionPool.numWaiters
Num waiters
builtin:tech.tomcat.connectionPool.numWaitersGlobal
Num waiters (global)
builtin:tech.tomcat.connectionPool.waitCount
Wait count
builtin:tech.tomcat.connectionPool.waitCountGlobal
Wait count (global)
builtin:tech.tomcat.tomcat.bytesReceivedPerSecond
Tomcat received bytes / sec
Byte/secondautoavgcountmaxminsum
builtin:tech.tomcat.tomcat.bytesSentPerSecond
Tomcat sent bytes / sec
builtin:tech.tomcat.tomcat.currentThreadsBusy
Tomcat busy threads
builtin:tech.tomcat.tomcat.currentThreadsIdle
Tomcat idle threads
builtin:tech.tomcat.tomcat.requestCountPerSecond
Tomcat request count / sec
Couchbase
builtin:tech.couchbase.cluster.basicStats.diskFetches
cluster basicStats diskFetches
builtin:tech.couchbase.cluster.count.membase
cluster count membase
builtin:tech.couchbase.cluster.count.memcached
cluster count memcached
builtin:tech.couchbase.cluster.samples.cmd_get
cluster samples cmd_get
builtin:tech.couchbase.cluster.samples.cmd_set
cluster samples cmd_set
builtin:tech.couchbase.cluster.samples.curr_items
cluster samples curr_items
builtin:tech.couchbase.cluster.samples.ep_cache_miss_rate
cluster samples ep_cache_miss_rate
builtin:tech.couchbase.cluster.samples.ep_num_value_ejects
cluster samples ep_num_value_ejects
Per minuteautoavgcountmaxminsum
builtin:tech.couchbase.cluster.samples.ep_oom_errors
cluster samples ep_oom_errors
builtin:tech.couchbase.cluster.samples.ep_tmp_oom_errors
cluster samples ep_tmp_oom_errors
builtin:tech.couchbase.cluster.samples.ops
cluster samples ops
builtin:tech.couchbase.cluster.samples.swap_used
cluster samples swap_used
builtin:tech.couchbase.cluster.status.healthy
cluster status healthy
builtin:tech.couchbase.cluster.status.unhealthy
cluster status unhealthy
builtin:tech.couchbase.cluster.status.warmup
cluster status warmup
builtin:tech.couchbase.cluster.storageTotals.hdd.free
cluster storageTotals hdd free
builtin:tech.couchbase.cluster.storageTotals.hdd.quotaTotal
cluster storageTotals hdd quotaTotal
builtin:tech.couchbase.cluster.storageTotals.hdd.total
cluster storageTotals hdd total
builtin:tech.couchbase.cluster.storageTotals.hdd.used
cluster storageTotals hdd used
builtin:tech.couchbase.cluster.storageTotals.hdd.usedByData
cluster storageTotals hdd usedByData
builtin:tech.couchbase.cluster.storageTotals.ram.percentageUsage
cluster storageTotals ram percentageUsage
builtin:tech.couchbase.cluster.storageTotals.ram.quotaTotal
cluster storageTotals ram quotaTotal
builtin:tech.couchbase.cluster.storageTotals.ram.quotaTotalPerNode
cluster storageTotals ram quotaTotalPerNode
builtin:tech.couchbase.cluster.storageTotals.ram.quotaUsed
cluster storageTotals ram quotaUsed
builtin:tech.couchbase.cluster.storageTotals.ram.quotaUsedPerNode
cluster storageTotals ram quotaUsedPerNode
builtin:tech.couchbase.cluster.storageTotals.ram.total
cluster storageTotals ram total
builtin:tech.couchbase.cluster.storageTotals.ram.used
cluster storageTotals ram used
builtin:tech.couchbase.cluster.storageTotals.ram.usedByData
cluster storageTotals ram usedByData
builtin:tech.couchbase.liveview.basicStats.diskFetches
liveview basicStats diskFetches
builtin:tech.couchbase.liveview.basicStats.diskUsed
liveview basicStats diskUsed
builtin:tech.couchbase.liveview.basicStats.memUsed
liveview basicStats memUsed
builtin:tech.couchbase.liveview.samples.cmd_get
liveview samples cmd_get
builtin:tech.couchbase.liveview.samples.cmd_set
liveview samples cmd_set
builtin:tech.couchbase.liveview.samples.couch_docs_data_size
liveview samples couch_docs_data_size
builtin:tech.couchbase.liveview.samples.couch_total_disk_size
liveview samples couch_total_disk_size
builtin:tech.couchbase.liveview.samples.disk_write_queue
liveview samples disk_write_queue
builtin:tech.couchbase.liveview.samples.ep_cache_miss_rate
liveview samples ep_cache_miss_rate
builtin:tech.couchbase.liveview.samples.ep_mem_high_wat
liveview samples ep_mem_high_wat
builtin:tech.couchbase.liveview.samples.ep_num_value_ejects
liveview samples ep_num_value_ejects
builtin:tech.couchbase.liveview.samples.ops
liveview samples ops
Custom device
builtin:tech.customDevice.count
Custom Device Count
Countautovalue
Elastic search
builtin:tech.elasticsearch.local.indices.docs.count
Documents count
builtin:tech.elasticsearch.local.indices.docs.deleted
Deleted documents
builtin:tech.elasticsearch.local.indices.fielddata.evictions
Field data evictions
builtin:tech.elasticsearch.local.indices.fielddata.memory_size_in_bytes
Field data size
builtin:tech.elasticsearch.local.indices.query_cache.cache_count
Query cache count
builtin:tech.elasticsearch.local.indices.query_cache.cache_size
Query cache size
builtin:tech.elasticsearch.local.indices.query_cache.evictions
Query cache evictions
builtin:tech.elasticsearch.local.indices.segments.count
Segment count
builtin:tech.elasticsearch.local.indices.shards.replication
Replica shards
builtin:tech.elasticsearch.local.indices.count
Indices count
builtin:tech.elasticsearch.local.active_primary_shards
Active primary shards
builtin:tech.elasticsearch.local.active_shards
Active shards
builtin:tech.elasticsearch.local.delayed_unassigned_shards
Delayed unassigned shards
builtin:tech.elasticsearch.local.initializing_shards
Initializing shards
builtin:tech.elasticsearch.local.number_of_data_nodes
Number of data nodes
builtin:tech.elasticsearch.local.number_of_nodes
Number of nodes
builtin:tech.elasticsearch.local.relocating_shards
Relocating shards
builtin:tech.elasticsearch.local.status-green
Status green
builtin:tech.elasticsearch.local.status-red
Status red
builtin:tech.elasticsearch.local.status-unknown
Status unknown
builtin:tech.elasticsearch.local.status-yellow
Status yellow
builtin:tech.elasticsearch.local.unassigned_shards
Unassigned shards
Generic
builtin:tech.generic.cpu.groupSuspensionTime
Process group total CPU time during GC suspensions
This metric provides statistics about CPU usage for process groups of garbage-collected technologies. The metric value is the sum of CPU time used during garbage collector suspensions for every process (including its workers) in a process group. It has a "Process Group" dimension.
builtin:tech.generic.cpu.groupTotalTime
This metric provides the total CPU time used by a process group. The metric value is the sum of CPU time every process (including its workers) of the process group uses. The result is expressed in microseconds. It can help to identify the most CPU-intensive technologies in the monitored environment. It has a "Process Group" dimension.
builtin:tech.generic.cpu.suspensionTime
Process total CPU time during GC suspensions
This metric provides statistics about CPU usage for garbage-collected processes. The metric value is the sum of CPU time used during garbage collector suspensions for all process workers. It has a "Process" dimension (dt.entity.process_group_instance).
builtin:tech.generic.cpu.totalTime
This metric provides the CPU time used by a process. The metric value is the sum of CPU time every process worker uses. The result is expressed in microseconds. It has a "Process" dimension (dt.entity.process_group_instance).
builtin:tech.generic.cpu.usage
Process CPU usage
This metric is the percentage of the CPU usage of a process. The metric value is the sum of CPU time every process worker uses divided by the total available CPU time. The result is expressed in percentage. A value of 100% indicates that the process uses all available CPU resources of the host.
builtin:tech.generic.gcpu.time
z/OS General CPU time
The time spent on the general-purpose central processor (GCP) after process start per minute
Secondautoavgcountmaxminsum
builtin:tech.generic.gcpu.usage
z/OS General CPU usage
The percent of the general-purpose central processor (GCP) used
builtin:tech.generic.handles.fileDescriptorsPercentUsed
Process file descriptors used per PID
This metric provides the file descriptor usage statistics. It is supported on Linux. The metric value is the highest percentage of the currently used file descriptor limit among process workers. It is sent once per minute with a 10-second granularity - (six samples are aggregated every minute). It offers two dimensions: "Process" (dt.entity.process_group_instance) and pid dimension corresponding to the PID with the highest percentage of available descriptors usage.
builtin:tech.generic.handles.fileDescriptorsPercentUsed.new
autoavgmaxmin
builtin:tech.generic.handles.fileDescriptorsMax
Process file descriptors max
This metric provides statistics about the file descriptor resource limits. It is supported on Linux. The metric value is the total limit of file descriptors that all process workers can open. It is sent once per minute with a 10-second granularity - (six samples are aggregated every minute).
Countautoavgmaxmin
builtin:tech.generic.handles.fileDescriptorsUsed
This metric provides statistics about file descriptor usage. It is supported on Linux. The metric value is the total number of file descriptors all process workers have opened. You can use it to detect processes that may cause the system to reach the limit of open file descriptors.
Countautoavgmaxmin
builtin:tech.generic.io.bytesRead
Process I/O read bytes
This metric provides statistics about the I/O read operations of a process. The metric value is a sum of I/O bytes read from the storage layer by all process workers per second. High values help to identify bottlenecks reducing process performance caused by the slow read speed of the storage device.
Byte/secondautoavgmaxmin
builtin:tech.generic.io.bytesTotal
Process I/O bytes total
This metric provides statistics about I/O operations for a process. The metric value is a sum of I/O bytes read and written by all process workers per second.
Byte/secondautovalue
builtin:tech.generic.io.bytesWritten
Process I/O write bytes
This metric provides statistics about the I/O write operations of a process. The metric value is a sum of I/O bytes written to the storage layer by all process workers per second. High values help to identify bottlenecks reducing process performance caused by the slow write speed of the storage device.
builtin:tech.generic.io.reqBytesRead
Process I/O requested read bytes
This metric provides statistics about the I/O read operations a process requests. It is supported only on Linux and AIX. The metric value is a sum of I/O bytes requested to be read from the storage by worker processes per second. It includes additional read operations, such as terminal I/O. It does not indicate the actual disk I/O operations, as some parts of the read operation might have been satisfied from the page cache.
builtin:tech.generic.io.reqBytesWrite
Process I/O requested write bytes
This metric provides statistics about the I/O write operations a process requests. It is supported on Linux and AIX. The metric value is a sum of I/O bytes requested to be written to the storage by PGI processes per second. It includes additional write operations, such as terminal I/O. It does not indicate the actual disk I/O operations, as some parts of the write operation might have been satisfied from the page cache.
builtin:tech.generic.mem.usage
Process memory usage
This metric is the percentage of memory used by a process. It helps to identify processes with high memory resource consumption and memory leaks. The metric value is the sum of the memory used by every process worker divided by the total available memory in the host.
builtin:tech.generic.mem.usage.new
builtin:tech.generic.mem.exhaustedMem
Process resource exhausted memory counter
This metric is a count of "Memory resource exhausted" events for a process. The metric value is the number of events all process workers generated in a minute. JVM generates the memory resource exhausted events when it is out of memory. This metric helps to identify Java processes with excessive memory usage.
Countautovalue
builtin:tech.generic.mem.pageFaults
Process page faults counter
This metric is the rate of page faults for a process. The metric value is the sum of page faults per time unit of every process worker. A page fault occurs when the process attempts to access a memory block not stored in the RAM, which means that the block has to be identified in the virtual memory and then loaded from the storage. Lower values are better. A high number of page faults may indicate reduced performance due to insufficient memory size.
Per secondautoavgmaxmin
builtin:tech.generic.mem.workingSetSize
Process memory
This metric is the memory usage of a process. It helps to identify processes with high memory resource consumption and memory leaks. The metric value represents the sum of every process worker's used memory size (including shared memory).
Byteautoavgmaxmin
builtin:tech.generic.network.packets.baseReRx
Retransmission base received
Number of retransmitted packets base received per second on host
builtin:tech.generic.network.packets.baseReRxAggr
builtin:tech.generic.network.packets.baseReTx
Retransmission base sent
Number of retransmitted packets base sent per second on host
builtin:tech.generic.network.packets.baseReTxAggr
builtin:tech.generic.network.packets.reRx
Retransmitted packets received
Number of retransmitted packets received per second on host
builtin:tech.generic.network.packets.reRxAggr
builtin:tech.generic.network.packets.reTx
Retransmitted packets sent
builtin:tech.generic.network.packets.reTxAggr
Number of retransmitted packets sent per second
builtin:tech.generic.network.packets.retransmission
Packet retransmissions
Packet retransmissions percent
builtin:tech.generic.network.packets.retransmissionIn
Incoming packet retransmissions
Incoming packet retransmissions percent
builtin:tech.generic.network.packets.retransmissionOut
Outgoing packet retransmissions
Outgoing packet retransmissions percent
builtin:tech.generic.network.packets.rx
Packets received
Number of packets received per second
builtin:tech.generic.network.packets.tx
Packets sent
Number of packets sent per second
builtin:tech.generic.network.sessions.connectivity
TCP connectivity
Percentage of successfully established TCP sessions
builtin:tech.generic.network.sessions.new
New session received
Number of new incoming TCP sessions per second
builtin:tech.generic.network.sessions.newAggr
Number of new sessions received per second
builtin:tech.generic.network.sessions.newLocal
Number of new sessions received per second on localhost
builtin:tech.generic.network.sessions.reset
Session reset received
Number of incoming TCP sessions with reset error per second
builtin:tech.generic.network.sessions.resetAggr
Number of session resets received per second
builtin:tech.generic.network.sessions.resetLocal
Number of session resets received per second on localhost
builtin:tech.generic.network.sessions.timeout
Session timeout received
Number of incoming TCP sessions with timeout error per second
builtin:tech.generic.network.sessions.timeoutAggr
Number of session timeouts received per second
builtin:tech.generic.network.sessions.timeoutLocal
Number of session timeouts received per second on localhost
builtin:tech.generic.network.traffic.traffic
Traffic
Summary of incoming and outgoing network traffic
bit/sautovalue
builtin:tech.generic.network.traffic.trafficIn
Traffic in
Incoming network traffic at PGI
bit/sautoavgmaxmin
builtin:tech.generic.network.traffic.trafficOut
Traffic out
Outgoing network traffic from PGI
bit/sautoavgmaxmin
builtin:tech.generic.network.bytesRx
Bytes received
Number of bytes received per second
builtin:tech.generic.network.bytesTx
Bytes sent
Number of bytes sent per second
builtin:tech.generic.network.latency
Ack-round-trip time
Average latency between outgoing TCP data and ACK
Millisecondautoavgmaxmin
builtin:tech.generic.network.load
Requests
Number of requests per second
builtin:tech.generic.network.responsiveness
Server responsiveness
Server responsiveness in microseconds
Microsecondautoavgcountmaxmedianminpercentilesum
builtin:tech.generic.network.roundTrip
Round-trip time
Average TCP session handshake RTT
builtin:tech.generic.network.throughput
Throughput
Used network bandwidth
builtin:tech.generic.count
Process count per process group
This metric provides the number of processes in a process group. It can tell how many instances of the technology are running in the monitored environment. It has a "Process Group" dimension.
Countautovalue
builtin:tech.generic.processCount
Worker processes
This metric is the number of process workers. Too few worker processes may lead to performance degradation, while too many may waste available resources. Configuration of workers should be suitable for the average workload and be able to scale up with higher demand.
Countautoavgmaxmin
builtin:tech.generic.threadsExhausted
Process resource exhausted threads counter
This metric is a count of "Thread resource exhausted" events for a process. The metric value is the number of events all process workers generated in a minute. JVM generates the thread resource exhausted events when it cannot create a new thread. This metric helps to identify Java processes with excessive memory usage.
Countautovalue
builtin:tech.generic.ziip
z/OS zIIP time
The time spent on the system z integrated information processor (zIIP) after process start per minute
builtin:tech.generic.ziipEligible
z/OS zIIP eligible time
The zIIP eligible time spent on the general-purpose central processor (GCP) after process start per minute
Go
builtin:tech.go.http.badGateways
Go: 502 responses
The number of responses that indicate invalid service responses produced by an application.
Countautovalue
builtin:tech.go.http.latency
Go: Response latency
The average response time from the application to clients.
builtin:tech.go.http.responses5xx
Go: 5xx responses
The number of responses that indicate repeatedly crashing apps or response issues from applications.
Countautovalue
builtin:tech.go.http.totalRequests
Go: Total requests
The number of all requests representing the overall traffic flow.
Countautovalue
builtin:tech.go.memory.heap.idle
Go: Heap idle size
The amount of memory not assigned to the heap or stack. Idle memory can be returned to the operating system or retained by the Go runtime for later reassignment to the heap or stack.
Byteautoavgmaxmin
builtin:tech.go.memory.heap.live
Go: Heap live size
The amount of memory considered live by the Go garbage collector. This metric accumulates memory retained by the most recent garbage collector run and allocated since then.
Byteautoavgmaxmin
builtin:tech.go.memory.heap.objCount
Go: Heap allocated Go objects count
The number of Go objects allocated on the Go heap.
Countautoavgmaxmin
builtin:tech.go.memory.pool.committed
Go: Committed memory
The amount of memory committed to the Go runtime heap.
Byteautoavgmaxmin
builtin:tech.go.memory.pool.used
Go: Used memory
The amount of memory used by the Go runtime heap.
Byteautoavgmaxmin
builtin:tech.go.memory.gcCount
Go: Garbage collector invocation count
The number of Go garbage collector runs.
Countautovalue
builtin:tech.go.native.cgoCalls
Go: Go to C language (cgo) call count
The number of Go to C language (cgo) calls.
Countautovalue
builtin:tech.go.native.sysCalls
Go: Go runtime system call count
The number of system calls executed by the Go runtime. This number doesn't include system calls performed by user code.
Countautovalue
builtin:tech.go.scheduling.g.avgNumOfActiveRoutines
Go: Average number of active Goroutines
The average number of active Goroutines.
Countautoavgmaxmin
builtin:tech.go.scheduling.g.avgNumOfInactiveRoutines
Go: Average number of inactive Goroutines
The average number of inactive Goroutines.
Countautoavgmaxmin
builtin:tech.go.scheduling.g.runningCount
Go: Application Goroutine count
The number of Goroutines instantiated by the user application.
Countautoavgmaxmin
builtin:tech.go.scheduling.g.systemCount
Go: System Goroutine count
The number of Goroutines instantiated by the Go runtime.
Countautoavgmaxmin
builtin:tech.go.scheduling.m.count
Go: Worker thread count
The number of operating system threads instantiated to execute Goroutines. Go doesn't terminate worker threads; it keeps them in a parked state for future reuse.
Countautoavgmaxmin
builtin:tech.go.scheduling.m.idlingCount
Go: Parked worker thread count
The number of worker threads parked by Go runtime. A parked worker thread doesn't consume CPU cycles until the Go runtime unparks the thread.
Countautoavgmaxmin
builtin:tech.go.scheduling.m.spinningCount
Go: Out-of-work worker thread count
The number of worker threads whose associated scheduling context has no more Goroutines to execute. When this happens, the worker thread attempts to steal Goroutines from another scheduling context or the global run queue. If the stealing fails, the worker thread parks itself after some time. This same mechanism applies to a high workload scenario. When an idle scheduling context exists, the Go runtime unparks a parked worker thread and associates it with the idle scheduling context. The unparked worker thread is now in the 'out of work' state and starts Goroutine stealing.
Countautoavgmaxmin
builtin:tech.go.scheduling.p.idleCount
Go: Idle scheduling context count
The number of scheduling contexts that have no more Goroutines to execute and for which Goroutine acquisition from the global run queue or other scheduling contexts has failed.
Countautoavgmaxmin
builtin:tech.go.scheduling.globalQSize
Go: Global Goroutine run queue size
The number of Goroutines in the global run queue. Goroutines are placed in the global run queue if the worker thread used to execute a blocking system call can't acquire a scheduling context. Scheduling contexts periodically acquire Goroutines from the global run queue.
Countautoavgmaxmin
JVM
builtin:tech.jvm.classes.loaded
JVM loaded classes
The number of classes that are currently loaded in the Java virtual machine, https://dt-url.net/l2c34jw
Countautoavgmaxmin
builtin:tech.jvm.classes.total
JVM total number of loaded classes
The total number of classes that have been loaded since the Java virtual machine has started execution, https://dt-url.net/d0y347x
Countautoavgmaxmin
builtin:tech.jvm.classes.unloaded
JVM unloaded classes
The total number of classes unloaded since the Java virtual machine has started execution, https://dt-url.net/d7g34bi
Countautoavgmaxmin
builtin:tech.jvm.memory.gc.activationCount
Garbage collection total activation count
The total number of collections that have occurred for all pools, https://dt-url.net/oz834vd
Countautovalue
builtin:tech.jvm.memory.gc.collectionTime
Garbage collection total collection time
The approximate accumulated collection elapsed time in milliseconds for all pools, https://dt-url.net/oz834vd
Millisecondautovalue
builtin:tech.jvm.memory.gc.suspensionTime
Garbage collection suspension time
Time spent in milliseconds between GC pause starts and GC pause ends, https://dt-url.net/zj434js
builtin:tech.jvm.memory.pool.collectionCount
Garbage collection count
The total number of collections that have occurred in that pool, https://dt-url.net/z9034yg
Countautovalue
builtin:tech.jvm.memory.pool.collectionTime
Garbage collection time
The approximate accumulated collection elapsed time in milliseconds in that pool, https://dt-url.net/z9034yg
builtin:tech.jvm.memory.pool.committed
JVM heap memory pool committed bytes
The amount of memory (in bytes) that is guaranteed to be available for use by the Java virtual machine, https://dt-url.net/1j034o0
Byteautoavgmaxmin
builtin:tech.jvm.memory.pool.max
JVM heap memory max bytes
The maximum amount of memory (in bytes) that can be used for memory management, https://dt-url.net/1j034o0
Byteautoavgmaxmin
builtin:tech.jvm.memory.pool.used
JVM heap memory pool used bytes
The amount of memory currently used by the memory pool (in bytes), https://dt-url.net/1j034o0
Byteautoavgmaxmin
builtin:tech.jvm.memory.runtime.free
JVM runtime free memory
An approximation to the total amount of memory currently available for future allocated objects, measured in bytes, https://dt-url.net/2mm34yx
Byteautoavgmaxmin
builtin:tech.jvm.memory.runtime.max
JVM runtime max memory
The maximum amount of memory that the virtual machine will attempt to use, measured in bytes, https://dt-url.net/lzq34mm
Byteautoavgmaxmin
builtin:tech.jvm.memory.runtime.total
JVM runtime total memory
The total amount of memory currently available for current and future objects, measured in bytes, https://dt-url.net/otu34eo
Byteautoavgmaxmin
builtin:tech.jvm.memory.memAllocationBytes
Process memory allocation bytes
Byteautovalue
builtin:tech.jvm.memory.memAllocationCount
Process memory allocation objects count
Countautovalue
builtin:tech.jvm.memory.memSurvivorsBytes
Process memory survived objects bytes
Byteautovalue
builtin:tech.jvm.memory.memSurvivorsCount
Process memory survived objects count
Countautovalue
builtin:tech.jvm.spark.aliveWorkers
Alive workers
builtin:tech.jvm.spark.aliveWorkers.gauge
Alive workers
builtin:tech.jvm.spark.apps
Master apps
builtin:tech.jvm.spark.apps.gauge
Master apps
builtin:tech.jvm.spark.driver.Count
Processing time - count
builtin:tech.jvm.spark.driver.Count.timer
builtin:tech.jvm.spark.driver.Mean
Processing time - mean
builtin:tech.jvm.spark.driver.Mean.timer
builtin:tech.jvm.spark.driver.OneMinuteRate
Processing time - one minute rate
builtin:tech.jvm.spark.driver.OneMinuteRate.timer
builtin:tech.jvm.spark.driver.activeJobs
Active jobs
builtin:tech.jvm.spark.driver.activeJobs.gauge
Active jobs
builtin:tech.jvm.spark.driver.allJobs
Total jobs
builtin:tech.jvm.spark.driver.allJobs.gauge
Total jobs
builtin:tech.jvm.spark.driver.failedStages
Failed stages
builtin:tech.jvm.spark.driver.failedStages.gauge
Failed stages
builtin:tech.jvm.spark.driver.runningStages
Running stages
builtin:tech.jvm.spark.driver.runningStages.gauge
Running stages
builtin:tech.jvm.spark.driver.waitingStages
Waiting stages
builtin:tech.jvm.spark.driver.waitingStages.gauge
Waiting stages
builtin:tech.jvm.spark.waitingApps
Waiting apps
builtin:tech.jvm.spark.waitingApps.gauge
Waiting apps
builtin:tech.jvm.spark.workers
Master workers
builtin:tech.jvm.spark.workers.gauge
Master workers
builtin:tech.jvm.threads.avgActiveThreadCount
JVM average number of active threads
Countautoavgmaxmin
builtin:tech.jvm.threads.avgInactiveThreadCount
JVM average number of inactive threads
Countautoavgmaxmin
builtin:tech.jvm.threads.count
JVM thread count
The current number of live threads including both daemon and non-daemon threads, https://dt-url.net/s02346y
Countautoavgmaxmin
builtin:tech.jvm.threads.totalCpuTime
JVM total CPU time
Kafka
builtin:tech.kafka.pg.kafka.controller.ControllerStats.LeaderElectionRateAndTimeMs.OneMinuteRate
Kafka broker - Leader election rate
builtin:tech.kafka.pg.kafka.controller.ControllerStats.UncleanLeaderElectionsPerSec.OneMinuteRate
Kafka broker - Unclean election rate
builtin:tech.kafka.pg.kafka.controller.KafkaController.ActiveControllerCount.Value
Kafka controller - Active cluster controllers
builtin:tech.kafka.pg.kafka.controller.KafkaController.OfflinePartitionsCount.Value
Kafka controller - Offline partitions
builtin:tech.kafka.pg.kafka.server.ReplicaManager.PartitionCount.Value
Kafka broker - Partitions
builtin:tech.kafka.pg.kafka.server.ReplicaManager.UnderReplicatedPartitions.Value
Kafka broker - Under replicated partitions
Nettracer
builtin:tech.nettracer.bytes_rx
Bytes received
Byteautoavgcountmaxminsum
builtin:tech.nettracer.bytes_tx
Bytes transmitted
Number of bytes transmitted
builtin:tech.nettracer.pkts_retr
Countautovalue
builtin:tech.nettracer.pkts_rx
Packets received
Countautovalue
builtin:tech.nettracer.pkts_tx
Packets transmitted
Number of packets transmitted
Countautovalue
builtin:tech.nettracer.retr_percentage
Retransmission
Percentage of retransmitted packets
builtin:tech.nettracer.rtt
Round trip time
Round trip time in milliseconds. Aggregates data from active sessions
builtin:tech.nettracer.traffic
Network traffic
Summary of incoming and outgoing network traffic in bits per second
bit/sautovalue
builtin:tech.nettracer.traffic_rx
Incoming traffic
Incoming network traffic in bits per second
bit/sautovalue
builtin:tech.nettracer.traffic_tx
Outgoing traffic
Outgoing network traffic in bits per second
bit/sautovalue
Nginx
builtin:tech.nginx.cache.freeSpace
Nginx Plus cache free space
MBautoavgmaxmin
builtin:tech.nginx.cache.hitRatio
Nginx Plus cache hit ratio
builtin:tech.nginx.cache.hits
Nginx Plus cache hits
builtin:tech.nginx.cache.misses
Nginx Plus cache misses
builtin:tech.nginx.cache.usedSpace
Nginx Plus cache used space
MBautoavgmaxmin
builtin:tech.nginx.serverZones.active
Active Nginx Plus server zones
Countautoavgmaxmin
builtin:tech.nginx.serverZones.inactive
Inactive Nginx Plus server zones
Countautoavgmaxmin
builtin:tech.nginx.serverZones.requests
Nginx Plus server zone requests
builtin:tech.nginx.serverZones.trafficIn
Nginx Plus server zone traffic in
builtin:tech.nginx.serverZones.trafficOut
Nginx Plus server zone traffic out
builtin:tech.nginx.upstream.healthy
Healthy Nginx Plus upstream servers
Countautoavgmaxmin
builtin:tech.nginx.upstream.requests
Nginx Plus upstream requests
builtin:tech.nginx.upstream.trafficIn
Nginx Plus upstream traffic in
builtin:tech.nginx.upstream.trafficOut
Nginx Plus upstream traffic out
builtin:tech.nginx.upstream.unhealthy
Unhealthy Nginx Plus upstream servers
Countautoavgmaxmin
Node.js
builtin:tech.nodejs.uvLoop.activeHandles
Node.js: Active handles
Average number of active handles in the event loop
Countautoavgmaxmin
builtin:tech.nodejs.uvLoop.count
Node.js: Event loop tick frequency
Average number of event loop iterations (per 10 seconds interval)
Countautoavgmaxmin
builtin:tech.nodejs.uvLoop.loopLatency
Node.js: Event loop latency
Average latency of expected event completion
Nanosecondautoavgmaxmin
builtin:tech.nodejs.uvLoop.processedLatency
Node.js: Work processed latency
Average latency of a work item being enqueued and callback being called
builtin:tech.nodejs.uvLoop.totalTime
Node.js: Event loop tick duration
Average duration of an event loop iteration (tick)
builtin:tech.nodejs.uvLoop.utilization
Node.js: Event loop utilization
Event loop utilization represents the percentage of time the event loop has been active
builtin:tech.nodejs.v8heap.gcHeapUsed
Node.js: GC heap used
Total size of allocated V8 heap used by application data (post-GC memory snapshot)
Byteautoavgmaxmin
builtin:tech.nodejs.v8heap.rss
Node.js: Process Resident Set Size (RSS)
Amount of space occupied in the main memory
Byteautoavgmaxmin
builtin:tech.nodejs.v8heap.total
Node.js: V8 heap total
Byteautoavgmaxmin
builtin:tech.nodejs.v8heap.used
Node.js: V8 heap used
Total size of allocated V8 heap used by application data (periodic memory snapshot)
Byteautoavgmaxmin
builtin:tech.nodejs.avgNumberOfActiveThreads
Node.js: Number of active threads
Average number of active Node.js worker threads
Countautoavgmaxmin
Oracle Database
builtin:tech.oracleDb.cd.cpu.background
Background CPU usage
builtin:tech.oracleDb.cd.cpu.foreground
Foreground CPU usage
builtin:tech.oracleDb.cd.cpu.idle
CPU idle
builtin:tech.oracleDb.cd.cpu.other
CPU other processes
builtin:tech.oracleDb.cd.io.bytesRead
Physical read bytes
Byteautovalue
builtin:tech.oracleDb.cd.io.bytesWritten
Physical write bytes
Byteautovalue
builtin:tech.oracleDb.cd.io.wait
Total wait time
Microsecondautovalue
builtin:tech.oracleDb.cd.memory.pga.size.allocated
Allocated PGA
Byteautoavgmaxmin
builtin:tech.oracleDb.cd.memory.pga.size.pgaAggregateLimit
PGA aggregate Limit
Byteautoavgmaxmin
builtin:tech.oracleDb.cd.memory.pga.size.pgaAggregateTarget
PGA aggregate target
Byteautoavgmaxmin
builtin:tech.oracleDb.cd.memory.pga.usedForWorkAreas
PGA used for work areas
builtin:tech.oracleDb.cd.memory.sga.cacheBuffer.sharedPoolFree
Shared pool free
builtin:tech.oracleDb.cd.memory.sga.redoBuffer.redoLogSpaceWaitTime
Redo log space wait time
builtin:tech.oracleDb.cd.memory.sga.redoBuffer.redoSizeIncrease
Redo size increase
Countautovalue
builtin:tech.oracleDb.cd.memory.sga.redoBuffer.redoWriteTime
Redo write time
builtin:tech.oracleDb.cd.memory.bufferCacheHit
Buffer cache hit
builtin:tech.oracleDb.cd.memory.sortsInMemory
Sorts in memory
builtin:tech.oracleDb.cd.queries.connMgmt
Time spent on connection management
builtin:tech.oracleDb.cd.queries.other
Time spent on other activities
builtin:tech.oracleDb.cd.queries.plSqlExec
PL SQL exec elapsed time
builtin:tech.oracleDb.cd.queries.sqlExec
SQL exec time
builtin:tech.oracleDb.cd.queries.sqlParse
Time spent on SQL parsing
builtin:tech.oracleDb.cd.sessions.active
Active sessions
Countautoavgmaxmin
builtin:tech.oracleDb.cd.sessions.all
All sessions
Countautoavgmaxmin
builtin:tech.oracleDb.cd.sessions.userCalls
User calls count
Countautovalue
builtin:tech.oracleDb.cd.slow.time.application
Application wait time
builtin:tech.oracleDb.cd.slow.time.cluster
Cluster wait time
builtin:tech.oracleDb.cd.slow.time.concurrency
Concurrency wait time
builtin:tech.oracleDb.cd.slow.time.cpu
CPU time
builtin:tech.oracleDb.cd.slow.time.elapsed
Elapsed time
builtin:tech.oracleDb.cd.slow.time.userIo
User I/O wait time
builtin:tech.oracleDb.cd.slow.bufferGets
Buffer gets
Countautovalue
builtin:tech.oracleDb.cd.slow.directWrites
Direct writes
Countautovalue
builtin:tech.oracleDb.cd.slow.diskReads
Disk reads
Countautovalue
builtin:tech.oracleDb.cd.slow.executions
Executions
Countautovalue
builtin:tech.oracleDb.cd.slow.parseCalls
Parse calls
Countautovalue
builtin:tech.oracleDb.cd.slow.rowsProcessed
Rows processed
Countautovalue
builtin:tech.oracleDb.cd.tablespaces.totalSpace
Total space
Byteautoavgmaxmin
builtin:tech.oracleDb.cd.tablespaces.usedSpace
Used space
Byteautoavgmaxmin
builtin:tech.oracleDb.cd.wait.count
Number of wait events
Countautovalue
builtin:tech.oracleDb.cd.wait.time
Total wait time
builtin:tech.oracleDb.pgi.cpu.background
builtin:tech.oracleDb.pgi.cpu.foreground
builtin:tech.oracleDb.pgi.cpu.idle
CPU idle
builtin:tech.oracleDb.pgi.cpu.other
CPU other processes
builtin:tech.oracleDb.pgi.io.bytesRead
Physical read bytes
Byteautovalue
builtin:tech.oracleDb.pgi.io.bytesWritten
Byteautovalue
builtin:tech.oracleDb.pgi.io.wait
Total wait time
builtin:tech.oracleDb.pgi.memory.pga.size.allocated
Allocated PGA
Byteautoavgmaxmin
builtin:tech.oracleDb.pgi.memory.pga.size.pgaAggregateLimit
PGA aggregate Limit
Byteautoavgmaxmin
builtin:tech.oracleDb.pgi.memory.pga.size.pgaAggregateTarget
Byteautoavgmaxmin
builtin:tech.oracleDb.pgi.memory.pga.usedForWorkAreas
builtin:tech.oracleDb.pgi.memory.sga.cacheBuffer.sharedPoolFree
Shared pool free
builtin:tech.oracleDb.pgi.memory.sga.redoBuffer.redoLogSpaceWaitTime
builtin:tech.oracleDb.pgi.memory.sga.redoBuffer.redoSizeIncrease
Redo size increase
Countautovalue
builtin:tech.oracleDb.pgi.memory.sga.redoBuffer.redoWriteTime
Redo write time
builtin:tech.oracleDb.pgi.queries.connMgmt
builtin:tech.oracleDb.pgi.queries.other
builtin:tech.oracleDb.pgi.queries.plSqlExec
builtin:tech.oracleDb.pgi.queries.sqlExec
SQL exec time
builtin:tech.oracleDb.pgi.queries.sqlParse
builtin:tech.oracleDb.pgi.sessions.active
Active sessions
Countautoavgmaxmin
builtin:tech.oracleDb.pgi.sessions.all
All sessions
Countautoavgmaxmin
builtin:tech.oracleDb.pgi.sessions.userCalls
User calls count
Countautovalue
builtin:tech.oracleDb.pgi.slow.time.application
builtin:tech.oracleDb.pgi.slow.time.cluster
Cluster wait time
builtin:tech.oracleDb.pgi.slow.time.concurrency
builtin:tech.oracleDb.pgi.slow.time.cpu
CPU time
builtin:tech.oracleDb.pgi.slow.time.elapsed
Elapsed time
builtin:tech.oracleDb.pgi.slow.time.userIo
User I/O wait time
builtin:tech.oracleDb.pgi.slow.bufferGets
Buffer gets
Countautovalue
builtin:tech.oracleDb.pgi.slow.directWrites
Direct writes
Countautovalue
builtin:tech.oracleDb.pgi.slow.diskReads
Disk reads
Countautovalue
builtin:tech.oracleDb.pgi.slow.executions
Executions
Countautovalue
builtin:tech.oracleDb.pgi.slow.parseCalls
Parse calls
Countautovalue
builtin:tech.oracleDb.pgi.slow.rowsProcessed
Rows processed
Countautovalue
builtin:tech.oracleDb.pgi.tablespaces.totalSpace
Total space
Byteautoavgmaxmin
builtin:tech.oracleDb.pgi.tablespaces.usedSpace
Used space
Byteautoavgmaxmin
builtin:tech.oracleDb.pgi.wait.count
Countautovalue
builtin:tech.oracleDb.pgi.wait.time
Total wait time
builtin:tech.oracleDb.pgi.bufferCacheHit
Buffer cache hit
builtin:tech.oracleDb.pgi.sortsInMemory
Sorts in memory
PHP
builtin:tech.php.phpGc.collectedCount
PHP GC collected count
builtin:tech.php.phpGc.durationMs
PHP GC collection duration
builtin:tech.php.phpGc.effectiveness
PHP GC effectiveness
Percent (%)autoavgcountmaxminsum
builtin:tech.php.phpOpcache.jit.bufferFree
PHP OPCache JIT buffer free
Byteautoavgmaxmin
builtin:tech.php.phpOpcache.jit.bufferSize
PHP OPCache JIT buffer size
Byteautoavgmaxmin
builtin:tech.php.phpOpcache.memory.free
PHP OPCache free memory
Byteautoavgmaxmin
builtin:tech.php.phpOpcache.memory.used
PHP OPCache used memory
Byteautoavgmaxmin
builtin:tech.php.phpOpcache.memory.wasted
PHP OPCache wasted memory
Byteautoavgmaxmin
builtin:tech.php.phpOpcache.restarts.hash
PHP OPCache restarts due to lack of keys
Countautoavgmaxmin
builtin:tech.php.phpOpcache.restarts.manual
PHP OPCache manual restarts
Countautoavgmaxmin
builtin:tech.php.phpOpcache.restarts.outOfMemory
PHP OPCache restarts due to out of memory
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.blocklistMisses
PHP OPCache blocklist misses
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.cachedKeys
PHP OPCache number of cached keys
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.cachedScripts
PHP OPCache number of cached scripts
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.hits
PHP OPCache hits
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.maxCachedCachedKeys
PHP OPCache max number of keys
Countautoavgmaxmin
builtin:tech.php.phpOpcache.statistics.misses
PHP OPCache misses
Countautoavgmaxmin
builtin:tech.php.phpOpcache.strings.bufferSize
PHP OPCache interned string buffer size
Countautoavgmaxmin
builtin:tech.php.phpOpcache.strings.numberOfStrings
PHP OPCache number of interned strings
Countautoavgmaxmin
builtin:tech.php.phpOpcache.strings.usedMemory
PHP OPCache interned string memory usage
Byteautoavgmaxmin
builtin:tech.php.threads.avgNumOfActiveThreads
PHP average number of active threads
Countautoavgmaxmin
builtin:tech.php.threads.avgNumOfInactiveThreads
PHP average number of inactive threads
Countautoavgmaxmin
Python
builtin:tech.python.gc.collected.gen0
Python GC collected items from gen 0
Countautoavgmaxmin
builtin:tech.python.gc.collected.gen1
Python GC collected items from gen 1
Countautoavgmaxmin
builtin:tech.python.gc.collected.gen2
Python GC collected items from gen 2
Countautoavgmaxmin
builtin:tech.python.gc.collection.gen0
Python GC collections number in gen 0
Countautoavgmaxmin
builtin:tech.python.gc.collection.gen1
Python GC collections number in gen 1
Countautoavgmaxmin
builtin:tech.python.gc.collection.gen2
Python GC collections number in gen 2
Countautoavgmaxmin
builtin:tech.python.gc.collectionTime.gen0
Python GC time in gen 0
Microsecondautoavgmaxmin
builtin:tech.python.gc.collectionTime.gen1
Python GC time in gen 1
builtin:tech.python.gc.collectionTime.gen2
Python GC time in gen 2
builtin:tech.python.gc.uncollectable.gen0
Python GC uncollectable items in gen 0
Countautoavgmaxmin
builtin:tech.python.gc.uncollectable.gen1
Python GC uncollectable items in gen 1
Countautoavgmaxmin
builtin:tech.python.gc.uncollectable.gen2
Python GC uncollectable items in gen 2
Countautoavgmaxmin
builtin:tech.python.heap.allocatedBlocks
Number of memory blocks allocated by Python
Countautoavgmaxmin
builtin:tech.python.activeThreads
Number of active Python threads
Countautoavgmaxmin
RabbitMQ
builtin:tech.rabbitmq.cluster_channels
cluster channels
builtin:tech.rabbitmq.cluster_connections
cluster connections
builtin:tech.rabbitmq.cluster_consumers
cluster consumers
builtin:tech.rabbitmq.cluster_exchanges
cluster exchanges
builtin:tech.rabbitmq.cluster_messages_ack
cluster ack messages
builtin:tech.rabbitmq.cluster_messages_deliver_get
cluster delivered and get messages
builtin:tech.rabbitmq.cluster_messages_publish
cluster published messages
builtin:tech.rabbitmq.cluster_messages_ready
cluster ready messages
builtin:tech.rabbitmq.cluster_messages_redeliver
cluster redelivered messages
builtin:tech.rabbitmq.cluster_messages_return_unroutable
cluster unroutable messages
builtin:tech.rabbitmq.cluster_messages_unacknowledged
cluster unacknowledged messages
builtin:tech.rabbitmq.cluster_nodes_failed
cluster node failed
builtin:tech.rabbitmq.cluster_nodes_ok
cluster node ok
builtin:tech.rabbitmq.cluster_queues_crashed
cluster crashed queues
builtin:tech.rabbitmq.cluster_queues_down
cluster queues down
builtin:tech.rabbitmq.cluster_queues_flow
cluster flow queues
builtin:tech.rabbitmq.cluster_queues_idle
cluster idle queues
builtin:tech.rabbitmq.cluster_queues_running
cluster running queues
builtin:tech.rabbitmq.topN_queue_ack
topn ack
builtin:tech.rabbitmq.topN_queue_consumers
topn consumers
builtin:tech.rabbitmq.topN_queue_deliver_get
topn deliver/get
builtin:tech.rabbitmq.topN_queue_messages_ready
topn ready messages
builtin:tech.rabbitmq.topN_queue_messages_unacknowledged
topn unacknowledged messages
builtin:tech.rabbitmq.topN_queue_publish
topn publish
Ruby
builtin:tech.ruby.gc.collectionCount
Ruby GC collection count
Countautovalue
builtin:tech.ruby.gc.collectionTime
Ruby GC collection time
builtin:tech.ruby.heap.allocated
Ruby MRI allocated heap size
Byteautoavgmaxmin
builtin:tech.ruby.heap.freeSlots
Ruby MRI heap free slots
Countautoavgmaxmin
builtin:tech.ruby.heap.liveSlots
Ruby MRI heap live slots
Countautoavgmaxmin
builtin:tech.ruby.memoryPool.committed
Ruby JVM committed memory
Byteautoavgmaxmin
builtin:tech.ruby.memoryPool.max
Ruby JVM max memory
Byteautoavgmaxmin
builtin:tech.ruby.memoryPool.used
Ruby JVM used memory
Byteautoavgmaxmin
builtin:tech.ruby.managedThreads
Number of managed Ruby threads
Countautoavgmaxmin
Varnish
builtin:tech.varnish.cache.hitRatio
Cache hit ratio
builtin:tech.varnish.cache.hitpasses
Cache hits for passes
builtin:tech.varnish.cache.hits
Cache hits
builtin:tech.varnish.cache.misses
Cache misses
builtin:tech.varnish.cache.passes
Cache passes
builtin:tech.varnish.connections.backend
Backend connections
builtin:tech.varnish.connections.failed
Backend connections failed
builtin:tech.varnish.connections.reused
Backend connections reused
builtin:tech.varnish.sessions.accepted
Sessions accepted
builtin:tech.varnish.sessions.dropped
Sessions dropped
builtin:tech.varnish.sessions.queued
Sessions queued
builtin:tech.varnish.threads.failed
Threads failed
builtin:tech.varnish.threads.max
Maximum number of threads
Countautoavgmaxmin
builtin:tech.varnish.threads.min
Minimum number of threads
Countautoavgmaxmin
builtin:tech.varnish.threads.total
Total number of threads
Countautoavgmaxmin
builtin:tech.varnish.requests
Requests
builtin:tech.varnish.traffic
Traffic
Web server
builtin:tech.webserver.connections.dropped
Dropped connections
Number of dropped connections
builtin:tech.webserver.connections.handled
Handled connections
Number of successfully finished and closed requests
builtin:tech.webserver.connections.reading
Reading connections
Number of connections which are receiving data from the client
Countautoavgmaxmin
builtin:tech.webserver.connections.socketWaitingTime
Socket backlog waiting time
Average time needed to queue and handle incoming connections
builtin:tech.webserver.connections.waiting
Waiting connections
Number of connections with no active requests
Countautoavgmaxmin
builtin:tech.webserver.connections.writing
Writing connections
Number of connections which are sending data to the client
Countautoavgmaxmin
builtin:tech.webserver.threads.active
Active worker threads
Number of active worker threads
Countautoavgmaxmin
builtin:tech.webserver.threads.idle
Idle worker threads
Number of idle worker threads
Countautoavgmaxmin
builtin:tech.webserver.threads.max
Maximum worker threads
Maximum number of worker threads
Countautoavgmaxmin
builtin:tech.webserver.requests
Requests
Number of requests
builtin:tech.webserver.traffic
Traffic
Amount of data transferred
WebSphere
builtin:tech.websphere.connectionPool.connectionPoolModule.FreePoolSize
Free pool size
builtin:tech.websphere.connectionPool.connectionPoolModule.PercentUsed
Percent used
builtin:tech.websphere.connectionPool.connectionPoolModule.PoolSize
Pool size
builtin:tech.websphere.connectionPool.connectionPoolModule.UseTime
In use time
Millisecondautoavgcountmaxminsum
builtin:tech.websphere.connectionPool.connectionPoolModule.WaitTime
Wait time
builtin:tech.websphere.connectionPool.connectionPoolModule.WaitingThreadCount
Number of waiting threads
builtin:tech.websphere.servletSessionsModule.LiveCount
Live sessions
builtin:tech.websphere.threadPoolModule.ActiveCount
Active threads
builtin:tech.websphere.threadPoolModule.PoolSize
Pool size
builtin:tech.websphere.webAppModule.RequestCountV2
Number of requests
z/OS
builtin:tech.zos.db2.cpu_usage
z/OS DB2 CPU usage
The percentage of the z/OS DB2 CPU usage
builtin:tech.zos.db2.cpu_usage_dbm1
z/OS DB2 DBM1 CPU usage
The percentage of z/OS DB2 DBM1 CPU usage
builtin:tech.zos.db2.cpu_usage_mstr
z/OS DB2 MSTR CPU usage
The percentage of the z/OS DB2 MSTR CPU usage
builtin:tech.zos.db2.latch_suspension_time
z/OS DB2 latch suspension time
DB2 latch suspension time in a one-minute interval
Microsecondautoavgcountmaxminsum
builtin:tech.zos.db2.num_active_connections
z/OS DB2 active connections
The calculated number of active z/OS DB2 connections
Countautoavgcountmaxminsum
builtin:tech.zos.db2.num_active_inbound_connections
z/OS DB2 active inbound connections
The calculated number of z/OS DB2 active inbound connections
builtin:tech.zos.db2.num_active_outbound_connections
z/OS DB2 active outbound connections
The calculated number of z/OS DB2 active outbound connections
builtin:tech.zos.db2.num_cache_hits
z/OS DB2 cache hits
The calculated number of inserts and requests into the dynamic statement cache
builtin:tech.zos.db2.num_closes
z/OS DB2 SQL close
The number of z/OS DB2 SQL close statements in a one-minute interval
builtin:tech.zos.db2.num_deadlocks
z/OS DB2 deadlock
The number of z/OS DB2 deadlocks in a one-minute interval
builtin:tech.zos.db2.num_deletes
z/OS DB2 SQL delete
The number of z/OS DB2 SQL delete statements in a one-minute interval
builtin:tech.zos.db2.num_edm_pool_requests
z/OS DB2 EDM pool requests
The calculated number of requests made to the z/OS DB2 Environmental Descriptor Manager (EDM) pools
builtin:tech.zos.db2.num_failed_connections
z/OS DB2 failed connections
The calculated number of z/OS DB2 unsuccessful connection attempts
builtin:tech.zos.db2.num_fetches
z/OS DB2 SQL fetch
The number of z/OS DB2 SQL fetch statements in a one-minute interval
builtin:tech.zos.db2.num_inserts
z/OS DB2 SQL insert
The number of z/OS DB2 SQL insert statements in a one-minute interval
builtin:tech.zos.db2.num_opens
z/OS DB2 SQL open
The number of z/OS DB2 SQL open statements in a one-minute interval
builtin:tech.zos.db2.num_selects
z/OS DB2 SQL select
The number of z/OS DB2 SQL select statements in a one-minute interval
builtin:tech.zos.db2.num_timedout_deadlocks
z/OS DB2 deadlock timeout
The number of z/OS DB2 deadlock timeouts in a one-minute interval
builtin:tech.zos.db2.num_updates
z/OS DB2 SQL update
The number of z/OS DB2 SQL update statements in a one-minute interval
builtin:tech.zos.db2.ziip_time
z/OS DB2 ZIIP time
The time spent by the z/OS DB2 on z Integrated Information Processor (zIIP) to optimize CPU usage
builtin:tech.zos.consumed_service_units
z/OS Consumed Service Units per minute
The calculated number of consumed Service Units per minute
Related tags
Dynatrace PlatformMetrics Classic
