Integrate Dynatrace Lambda Layer on container images
  • Dynatrace Classic
  • How-to guide
  • 4-min read
As an addition to Lambda function deployment as a ZIP file, AWS Lambda offers Lambda function deployment as container images.
The container image must include the files and configuration required to run the function code. The same applies to the files and configuration of Dynatrace AWS Lambda Layer, once monitoring is enabled for the containerized Lambda function.
In a ZIP file function deployment, the Dynatrace artifacts are attached to the function with an AWS Lambda extension (which is a Lambda layer with an extension-specific folder layout).
A Lambda layer, like a function bundle, is a ZIP file extracted at function cold start time to the /opt folder of the AWS Lambda function instance.
See below for how to enable Dynatrace monitoring for a containerized Lambda function.
Step 1
Configuration
Step 2
Copy the Lambda layer configuration snippet
Step 3
Add Dynatrace AWS Lambda extension to the container image
Step 1 Configuration
  1. Go to Trace Python, Node.js, and Java Lambda functions and follow the Configure with environment variables instructions.
  2. Open the projects Dockerfile in an editor and copy the environment variables from the deployment screen. Each line must be prefixed with ENV and spaces around the equal signs must be removed.
ENV AWS_LAMBDA_EXEC_WRAPPER=/opt/dynatrace
ENV DT_TENANT=abcd1234
ENV DT_CLUSTER_ID=1234567890
ENV DT_CONNECTION_BASE_URL=https://abcd1234.live.dynatrace.com
ENV DT_CONNECTION_AUTH_TOKEN=dt0a01...
Step 2 Copy the Lambda layer configuration snippet
  1. In Dynatrace Hub, select AWS Lambda.
  2. Select Set up.
  1. On the Enable Monitoring for AWS Lambda Functions, copy the Lambda layer configuration snippet.
Step 3 Add OneAgent extension to the container image
  1. To download the contents of the Dynatrace AWS Lambda extension to the local file system, use the following code sample for dt-awslayertool or AWS CLI.
    To use the following code sample, substitute <YOUR_LAMBDA_LAYER_ARN_SNIPPET> with the copied Lambda layer snippet.
    dt-awslayertool pull <YOUR_LAMBDA_LAYER_ARN_SNIPPET> --extract DynatraceOneAgentExtension
    Example command
    The following example command downloads the layer arn:aws:lambda:us-east-1:725887861453:layer:Dynatrace_OneAgent_1_207_6_20201127-103507_nodejs:1 and extracts its contents to the local folder DynatraceOneAgentExtension.
    dt-awslayertool pull arn:aws:lambda:us-east-1:725887861453:layer:Dynatrace_OneAgent_1_207_6_20201127-103507_nodejs:1 --extract DynatraceOneAgentExtension
    To learn more about dt-awslayertool, see Github.
    To use the following code sample, substitute <YOUR_LAMBDA_LAYER_ARN_SNIPPET> with the copied Lambda layer snippet and <YOUR_LAMBDA_LAYER_REGION> with the Lambda layer region provided in the snippet.
    curl $(aws --region <YOUR_LAMBDA_LAYER_REGION> lambda get-layer-version-by-arn --arn <YOUR_LAMBDA_LAYER_ARN_SNIPPET> --query 'Content.Location' --output text) --output layer.zip
    unzip -d DynatraceOneAgentExtension layer.zip
    Example command
    The following code example downloads and extracts the content of arn:aws:lambda:us-east-1:725887861453:layer:Dynatrace_OneAgent_1_207_6_20201127-103507_nodejs:1 to the local folder DynatraceOneAgentExtension.
    curl $(aws --region us-east-1 lambda get-layer-version-by-arn --arn arn:aws:lambda:us-east-1:725887861453:layer:Dynatrace_OneAgent_1_207_6_20201127-103507_nodejs:1 --query 'Content.Location' --output text) --output layer.zip
    To learn more about AWS CLI, see AWS documentation.
  2. To copy the downloaded extension content into the container image and ensure that the shell script file /opt/dynatrace is executable, use the following Dockerfile commands.
    COPY DynatraceOneAgentExtension/ /opt/
    RUN chmod +x /opt/dynatrace
Sample Dockerfile with Dynatrace AWS Lambda extension enabled
This sample project creates a containerized Node.js Lambda function.
The project folder has the following files and folders:
containerized-lambda-sample
├── Dockerfile
├── DynatraceOneAgentExtension
└── index.js
The content of the Dynatrace AWS Lambda Layer is assumed to be downloaded and extracted (as outlined above) to the folder DynatraceOneAgentExtension.
The handler function is exported by the index.js file:
exports.handler = async () => {
return "hello world";
The Dockerfile with the modifications applied to integrate Dynatrace AWS Lambda extension to the containerized function:
FROM public.ecr.aws/lambda/nodejs:18
COPY index.js ${LAMBDA_TASK_ROOT}
# --- Begin of enable Dynatrace OneAgent monitoring section
# environment variables copied from Dynatrace AWS Lambda deployment screen
# (prefix with ENV and remove spaces around equal signs)
# copy Dynatrace OneAgent extension download and extracted to local disk into container image
# make /opt/dynatrace shell script executable
# --- End of enable Dynatrace OneAgent monitoring section
CMD [ "index.handler" ]
Limitations
Monitoring via Dynatrace AWS Lambda extension on container images is supported only for images created from an AWS base image for Lambda and only for the runtimes that we support for non-containerized functions.
Additional resources
For more information on the Lambda container images, see:
  • Creating Lambda container images
  • Working with Lambda layers and extensions in container images
Related tags
Infrastructure ObservabilityAWS
