GitHub Connector enables your Dynatrace environment to integrate with GitHub repositories. With this integration, you can automate issues and pull requests based on monitoring data and events within a dedicated workflow.
Set up and configure GitHub Connector.
Learn about available actions used by GitHub Connector integration for automating issues and pull requests on your monitoring data and events.
