Settings API - Process group monitoring schema table
  • Published Dec 05, 2023
Process group monitoring (builtin:process-group.monitoring.state)
Enable or disable monitoring for certain process groups
Schema IDSchema groupsScope
builtin:process-group.monitoring.state-
PROCESS_GROUP - Process Group
Retrieve schema via Settings API
GETManagedhttps://{your-domain}/e/{your-environment-id}/api/v2/settings/schemas/builtin:process-group.monitoring.state
GETSaaShttps://{your-environment-id}.live.dynatrace.com/api/v2/settings/schemas/builtin:process-group.monitoring.state
GETEnvironment ActiveGatehttps://{your-activegate-domain}/e/{your-environment-id}/api/v2/settings/schemas/builtin:process-group.monitoring.state
Authentication
To execute this request, you need an access token with Read settings (settings.read) scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
PropertyTypeDescriptionRequired
Monitoring state
MonitoringState
enum
The element has these enums
  • MONITORING_OFF
  • MONITORING_ON
  • DEFAULT
Required
