Synthetic monitor executions API v2 - GET basic info of an execution
  • Reference
  • Published Jun 27, 2022
Gets basic results of an on-demand execution of a synthetic monitor.
The request produces an application/json payload.
GETSaaShttps://{your-environment-id}.live.dynatrace.com/api/v2/synthetic/executions/{executionId}
GETEnvironment ActiveGateCluster ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/synthetic/executions/{executionId}
Authentication
To execute this request, you need an access token with one of the following scopes:
  • syntheticExecutions.read
  • ExternalSyntheticIntegration
  • ReadSyntheticData
To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
executionIdinteger
The identifier of the on-demand execution.
pathRequired
Response
Response codes
CodeTypeDescription
200SyntheticOnDemandExecution
Success. The response contains basic information about the on-demand execution.
400ErrorEnvelope
Failed. The input is invalid.
404ErrorEnvelope
Execution with the given ID doesn't exist.
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The SyntheticOnDemandExecution object
Describes the status of an on-demand execution.
ElementTypeDescription
batchIdstring
The identifier of the batch.
customizedScriptObjectNode
Customized script properties for this on-demand batch execution.
dataDeliveryTimestampinteger
The timestamp when whole data set has been collected on server, in UTC milliseconds.
executionIdstring
The identifier of the execution.
executionStagestring
Execution stage.
The element can hold these values
  • DATA_RETRIEVED
  • EXECUTED
  • NOT_TRIGGERED
  • TIMED_OUT
  • TRIGGERED
  • WAITING
executionTimestampinteger
The timestamp when execution was finished, in UTC milliseconds.
fullResultsExecutionFullResults
Contains extended monitor's execution details.
locationIdstring
The identifier of the location from where the monitor is to be executed.
metadataobject
Metadata map for the execution batch.
monitorIdstring
The identifier of the monitor.
nextExecutionIdstring
Next execution id for sequential mode.
processingModestring
The processing mode of the execution.
  • DISABLE_PROBLEM_DETECTION
  • EXECUTIONS_DETAILS_ONLY
  • NONE
  • STANDARD
  • UNKNOWN
schedulingTimestampinteger
The scheduling timestamp, in UTC milliseconds.
simpleResultsExecutionSimpleResults
Contains basic results of the monitor's on-demand execution.
sourcestring
The source of the triggering request.
  • API
  • UI
userIdstring
The name of the user who triggered the on-demand execution.
The ObjectNode object
The ExecutionFullResults object
errorCodestring
Error code.
executionStepCountinteger
Number executed steps.
executionStepsExecutionStep[]
Details about the monitor's step execution.
failedStepNamestring
Failed step name.
failedStepSequenceIdinteger
Failed step sequence id.
failureMessagestring
Failure message.
statusstring
Execution status.
The ExecutionStep object
Contains detailed information about the monitor's step execution.
monitorTypestring
Defines the actual set of fields depending on the value. See one of the following objects:
  • BROWSER -> BMAction
  • HTTP -> MonitorRequestExecutionResult
  • BROWSER
  • HTTP
The ExecutionSimpleResults object
chromeErrorboolean
Informs whether is Chrome error.
engineIdinteger
Synthetic engine id on which monitor was executed.
errorCodestring
Error code.
executedStepsinteger
Number of the executed steps by Synthetic engine
Failure message.
hostNameResolutionTimeinteger
A hostname resolution time measured in milliseconds.
httperrorboolean
Informs whether is HTTP error.
peerCertificateExpiryDateinteger
DEPRECATED
An expiry date of the first SSL certificate from the certificate chain.
publicLocationboolean
Flag informs whether request was executed on public location.
redirectionTimeinteger
Total number of milliseconds spent on handling all redirect requests, measured in milliseconds.
redirectsCountinteger
Number of redirects.
responseBodySizeLimitExceededboolean
A flag indicating that the response payload size limit of 10MB has been exceeded.
responseSizeinteger
Request's response size in bytes.
responseStatusCodeinteger
Response status code.
startTimestampinteger
Start timestamp.
statusstring
Execution status.
tcpConnectTimeinteger
A TCP connect time measured in milliseconds.
timeToFirstByteinteger
A time to first byte measured in milliseconds.
tlsHandshakeTimeinteger
A TLS handshake time measured in milliseconds.
totalTimeinteger
A total time measured in milliseconds.
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"batchId": "22396514015719218",
"customizedScript": {
"requests": [
"sequenceId": "1",
"url": "https://www.somepage.org",
"validation": {
"rules": [
"passIfFound": "true",
"type": "httpStatusesList",
"value": "=201"
"dataDeliveryTimestamp": "1629891701171",
"executionId": "7002396514015719218",
"executionStage": "DATA_RETRIEVED",
"executionTimestamp": "1629891695487",
"locationId": "SYNTHETIC_LOCATION-9BB04DAEBA71B8CA",
"metadata": {
"key": "value",
"version": "1.255.20221022"
"monitorId": "HTTP_CHECK-6349B98E1CD87352",
"processingMode": "STANDARD",
"schedulingTime": "1629891686877",
"simpleResults": [
"engineId": "1993198092",
"executedSteps": "1",
"healthStatus": "HEALTHY",
"hostNameResolutionTime": "50",
"publicLocation": "false",
"redirectionTime": "576",
"responseBodySizeLimitExceeded": "false",
"responseSize": "1530652",
"responseStatusCode": "200",
"startTimestamp": "1629891693487",
"tcpConnectTime": "127",
"tlsHandshakeTime": "167",
"totalTime": "955"
"source": "API",
"userId": "someUserIdentifier"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Related topics
  • Synthetic Monitoring Classic
