Third-party synthetic API - POST third-party monitors to Dynatrace
  • Reference
  • Published May 15, 2020
Pushes third-party synthetic monitors, locations, and monitor execution results to Dynatrace.
The request consumes an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/v1/synthetic/ext/tests
POSTEnvironment ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v1/synthetic/ext/tests
Authentication
To execute this request, you need an access token with ExternalSyntheticIntegration scope.
To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
body3rdPartySyntheticTests
The JSON body of the request. Contains third-party synthetic monitors, locations, and results.
bodyRequired
Request body objects
The 3rdPartySyntheticTests object
ElementTypeDescriptionRequired
locations3rdPartySyntheticLocation[]
The list of third-party synthetic locations.
Required
messageTimestampinteger
The timestamp of the message creation, in UTC milliseconds.
Required
syntheticEngineIconUrlstring
The URL of the third-party synthetic monitor icon.
Optional
syntheticEngineNamestring
The type of the third-party synthetic monitor.
Required
testResults3rdPartySyntheticTestResult[]
The list of results of third-party synthetic monitor execution.
Optional
tests3rdPartySyntheticMonitor[]
The list of third-party synthetic monitors.
Required
The 3rdPartySyntheticLocation object
The third-party Synthetic location.
idstring
The ID of the location.
Required
ipstring
The IP address of the location.
Optional
namestring
The name of the location, displayed in the UI.
Required
The 3rdPartySyntheticTestResult object
The results of third-party synthetic monitor execution.
idstring
The ID of the third-party synthetic monitor.
Required
locationResults3rdPartySyntheticLocationTestResult[]
Results of third-party monitor executions per location.
Required
totalStepCountinteger
Number of steps in the monitor. Defaults to number of SyntheticTestSteps.
Optional
The 3rdPartySyntheticLocationTestResult object
idstring
Required
responseTimeMillisinteger
The overall response time of the monitor from this location, in milliseconds.
If absent, it is calculated as the sum of response times of all steps.
Optional
startTimestampinteger
The timestamp of text execution start, in UTC milliseconds.
Required
stepResultsSyntheticMonitorStepResult[]
Results of individual monitor steps.
Required
successboolean
If the test was successful (true) or failed (false) - will influence availability timeseries.
Required
successRatenumber
The overall availability of the monitor from this location, percent.
If absent, calculated as the number of successful steps compared to the overall number of steps.
Optional
The SyntheticMonitorStepResult object
The result of the individual step of a synthetic monitor.
errorSyntheticMonitorError
The error message of a synthetic monitor step.
Optional
idinteger
ID of the step. It is unique within the test definition.
Required
The response time of the step, in milliseconds.
Absent when no meaningful response time is available (as may be the case for certain error conditions such as a misconfigured step script).
Optional
The timestamp of test step execution, UTC milliseconds.
Required
The SyntheticMonitorError object
codeinteger
The error code.
Required
messagestring
The error message.
Required
The 3rdPartySyntheticMonitor object
The third-party synthetic monitor.
deletedboolean
The flag of the deleted monitor. Default is false.
If true, set the enabled parameter to false.
Optional
descriptionstring
A description of the monitor.
Optional
drilldownLinkstring
The URL to the results of monitor execution.
Optional
editLinkstring
The URL to edit the monitor in the original UI.
Optional
enabledboolean
The monitor is enabled (true) or disabled (false). Default is true.
If true, set the deleted parameter to false.
Optional
expirationTimestampinteger
The timestamp of the monitor expiration, in UTC milliseconds.
Optional
idstring
The ID of the monitor.
Required
locationsSyntheticTestLocation[]
Locations from which the synthetic monitor runs.
Required
noDataTimeoutinteger
The timeout of the monitor, in seconds. If no result is reported within this time, the availability state switches to unmonitored. Default is doubled frequency of the monitor.
Optional
scheduleIntervalInSecondsinteger
The frequency of the monitor, in seconds. The monitor is repeated with the specified interval at the third-party source.
Dynatrace expects results of a monitor execution with the specified interval. If you report results to Dynatrace less often, adjust the noDataTimeout value accordingly.
Required
stepsSyntheticTestStep[]
Steps of the third-party monitor.
Optional
testSetupstring
The information on monitor setup, for example browser.
Optional
titlestring
The name of the monitor.
Required
The SyntheticTestLocation object
Synthetic test location.
enabledboolean
The location is enabled/disabled. Default is true, enabling the location.
Optional
idstring
Required
The SyntheticTestStep object
The step of a synthetic monitor.
idinteger
The ID of the step.
Required
titlestring
The name of the step, displayed in the UI.
Required
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"locations": [
"id": "string",
"ip": "string",
"name": "string"
"messageTimestamp": 1,
"syntheticEngineIconUrl": "string",
"syntheticEngineName": "string",
"testResults": [
"id": "string",
"locationResults": [
"id": "string",
"responseTimeMillis": 1,
"startTimestamp": 1,
"stepResults": [
"error": {
"code": 1,
"message": "string"
"id": 1,
"startTimestamp": 1
"success": true,
"successRate": 1
"totalStepCount": 1
"tests": [
"deleted": true,
"description": "string",
"drilldownLink": "string",
"editLink": "string",
"enabled": true,
"expirationTimestamp": 1,
"id": "string",
"locations": [
"enabled": true,
"id": "string"
"noDataTimeout": 1,
"scheduleIntervalInSeconds": 1,
"steps": [
"id": 1,
"title": "string"
"testSetup": "string",
"title": "string"
Response
Response codes
CodeTypeDescription
204-
Success. The information is accepted and stored.
400ErrorEnvelope
Failed. The input is invalid.
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
The element can hold these values
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Example
In this example, the request pushes the following data from third-party synthetic engine My third-party synthetic to Dynatrace:
  • Three locations: Linz1, Linz2, and Linz3.
  • Two monitors: example of synthetic monitor - 1 and example of synthetic monitor - 2, each containing three steps and running from two locations.
  • One result per step, per location, for each monitor.
Monitors have the following parameters:
example of synthetic monitor - 1example of synthetic monitor - 2
Frequency300 seconds (5 minutes)300 seconds (5 minutes)
LocationsLinz1
Linz2
Linz2
Linz3
StepsStep1-1
Step1-2
Step1-3
Step2-1
Step2-2
Step3-3
The example of synthetic monitor - 1 monitor has the following response times in milliseconds:
Linz1Linz2
Step1-177902075
Step1-220734079
Step1-386503937
The example of synthetic monitor - 2 monitor has the following response times in milliseconds:
Linz2Linz3
Step2-122009123
Step2-269039722
Step2-348211717
The API token is passed in the Authorization header.
Since the request body is lengthy, it is truncated in this example Curl section. See the full body in the Request body section. You can download the request body JSON to perform a sample request in your environment. Be sure to replace the timestamps with recent ones or the results will be too old.
Curl
curl -X POST \
https://mySampleEnv.live.dynatrace.com/api/v1/synthetic/ext/tests \
-H 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890' \
-H 'Content-Type: application/json' \
-d '{ <truncated - see the Request body section >}'
Request URL
Request body
"syntheticEngineName": "My third-party synthetic",
"syntheticEngineIconUrl": "https://static.thenounproject.com/png/1745-200.png",
"messageTimestamp": 1543572265528,
"locations": [
"id": "Linz1",
"ip": "127.0.0.1",
"name": "Linz1"
"id": "Linz2",
"ip": "127.0.0.2",
"name": "Linz2"
"id": "Linz3",
"ip": "127.0.0.3",
"name": "Linz3"
"tests": [
"id": "3rdPartySyntheticMonitor1",
"title": "example of synthetic monitor - 1",
"scheduleIntervalInSeconds": 300,
"locations": [
"id": "Linz1"
"id": "Linz2"
"steps": [
"id": 1,
"title": "Step1-1"
"id": 2,
"title": "Step1-2"
"id": 3,
"title": "Step1-3"
"id": "3rdPartySyntheticMonitor2",
"title": "example of synthetic monitor - 2",
"locations": [
"id": "Linz2"
"id": "Linz3"
"steps": [
"id": 1,
"title": "Step2-1"
"id": 2,
"title": "Step2-2"
"id": 3,
"title": "Step2-3"
"testResults": [
"totalStepCount": 3,
"id": "Linz1",
"startTimestamp": 1543572262538,
"success": true,
"stepResults": [
"id": 1,
"responseTimeMillis": 7790
"id": 2,
"responseTimeMillis": 2073
"id": 3,
"responseTimeMillis": 8650
"id": "Linz2",
"startTimestamp": 1543572262548,
"success": true,
"stepResults": [
"id": 1,
"responseTimeMillis": 2075
"id": 2,
"responseTimeMillis": 4079
"id": 3,
"responseTimeMillis": 3937
"id": "Linz2",
"success": true,
"stepResults": [
"id": 1,
"responseTimeMillis": 2200
"id": 2,
"responseTimeMillis": 6903
"id": 3,
"responseTimeMillis": 4821
"id": "Linz3",
"startTimestamp": 1543572262558,
"success": true,
"stepResults": [
"id": 1,
"responseTimeMillis": 9123
"id": 2,
"responseTimeMillis": 9722
"id": 3,
"responseTimeMillis": 1717
Response code
204
Result
Highlight shows parameters, submitted in the request.
