Credential vault API - POST a set of credentials
  • Reference
Creates a new set of credentials for synthetic monitors.
The request consumes and produces an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/v2/credentials
POSTEnvironment ActiveGateCluster ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/credentials
Authentication
Api-Token:
To execute this request, you need an access token with credentialVault.write scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
Refer to JSON models to find all JSON models that depend on the type of the model.
ParameterTypeDescriptionInRequired
bodyCredentials
The JSON body of the request. Contains parameters of the new credentials set.
bodyRequired
Request body objects
The Credentials object
A set of credentials for synthetic monitors.
The actual set of fields depends on the type of credentials. Find the list of actual objects in the description of the type field or see Credential vault API - JSON models.
ElementTypeDescriptionRequired
allowContextlessRequestsboolean
Allow ad-hoc functions to access the credential details (requires the APP_ENGINE scope).
Optional
allowedEntitiesCredentialAccessData[]
The set of entities allowed to use the credential.
Optional
descriptionstring
A short description of the credentials set.
Optional
idstring
The ID of the credentials set.
Optional
namestring
The name of the credentials set.
Required
ownerAccessOnlyboolean
The credentials set is available to every user (false) or to owner only (true).
Optional
scopestring
DEPRECATED
The scope of the credentials set.
The element can hold these values
  • APP_ENGINE
  • EXTENSION
  • EXTENSION_AUTHENTICATION
  • SYNTHETIC
Optional
scopesstring[]
The set of scopes of the credentials set.
Limitations: CredentialsScope.APP_ENGINE is only available on the new Dynatrace SaaS platform - it's not available on managed or non-Grail SaaS environments.
  • APP_ENGINE
  • EXTENSION
  • SYNTHETIC
Required
typestring
Defines the actual set of fields depending on the value. See one of the following objects:
  • CERTIFICATE -> CertificateCredentials
  • PUBLIC_CERTIFICATE -> PublicCertificateCredentials
  • USERNAME_PASSWORD -> UserPasswordCredentials
  • TOKEN -> TokenCredentials
  • SNMPV3 -> SNMPV3Credentials
  • AWS_MONITORING_KEY_BASED -> AWSKeyBasedCredentialsDto
  • AWS_MONITORING_ROLE_BASED -> AWSRoleBasedCredentials
  • CERTIFICATE
  • SNMPV3
  • TOKEN
  • USERNAME_PASSWORD
Required
The CredentialAccessData object
idstring-Optional
typestring-
  • APPLICATION
  • UNKNOWN
  • USER
Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"allowContextlessRequests": "false",
"allowedEntities": [
"id": "jane.doe@example.com",
"type": "USER"
"id": "john.smith@example.com",
"type": "USER"
"id": "my.with.credentials",
"type": "APPLICATION"
"description": "Sample set of credentials for API documentation",
"name": "Sample credentials",
"ownerAccessOnly": false,
"password": "1234abcd",
"scope": "SYNTHETIC",
"scopes": [
"SYNTHETIC",
"EXTENSION_AUTHENTICATION"
"type": "USERNAME_PASSWORD",
"user": "john.smith@example.com"
Response
Response codes
CodeTypeDescription
201CredentialsId
Success. The new credentials set has been created. The response contains the ID of the set.
400ErrorEnvelope
Failed. The input is invalid.
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The CredentialsId object
A short representation of the credentials set.
idstring
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"id": "CREDENTIALS_VAULT-C43F2C2E6395AD23"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Example
In this example, the request creates a new set of credentials of the USERNAME_PASSWORD type. The username of the credentials set is john.smith and the password is abcd1234.
The API token is passed in the Authorization header.
You can download or copy the example request body to try it out on your own.
Curl
curl -X POST \
https://mySampleEnv.live.dynatrace.com/api/config/v1/credentials/ \
-H 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890' \
-H 'Content-Type: application/json' \
-d '{
"name": "RESTtest",
"description": "Test credentials",
"password": "abcd1234",
"ownerAccessOnly": true,
"certificate": "john.smith"
Request URL
Request body
"name": "RESTtest",
"user": "john.smith"
Response body
"id": "CREDENTIALS_VAULT-1E6EA5075AF7E85D"
Response code
200
Related topics
  • Configure browser monitors in Classic
  • Configure HTTP monitors in Classic
