Differences between containerized and host-based ActiveGates
  • Latest Dynatrace
  • 1-min read
ActiveGate deployed on a host using an installer—depending on a selected purpose—consists of multiple processes delivering several functionalities. The container image covers only a subset of that, provided by the core ActiveGate process.
Purposes
An ActiveGate container image currently supports only a subset of routing and monitoring as well as private synthetic.
For a complete overview, see ActiveGate purposes and functionality.
InstallerContainer
OneAgent routing
Applicable
Applicable
API
Applicable
Applicable
Not applicable Logs
Infrastructure Monitoring
(VMware, CloudFoundry, DBInsights, Kubernetes)
Applicable
Applicable
Cloud monitoring
Applicable
Applicable Azure
Not applicable AWS
Extensions
Applicable
Not applicable
Synthetic monitors
Applicable
Applicable
ZRemote
Applicable
Not applicable
Auto-update
ActiveGate auto-update is supported only for host-based ActiveGates deployed using an installer.
In Kubernetes environments, ActiveGate updates are managed by the container runtime.
ActiveGate is updated automatically on pod restart whenever there is a new version available, unless the image already specifies a certain version.
Remote configuration management
Remote configuration management doesn't support containerized ActiveGates.
A containerized ActiveGate configuration is not persistently stored. It is declarative, using the Kubernetes native means of configuration, so any changes triggered by the remote configuration management mechanism would be lost upon container restart.
