Configure build label propagation
As part of getting started with Kubernetes monitoring, you might want to configure build label propagation.
Build label propagation enables you to provide build and version metadata information to the injected OneAgent about the newly deployed pods. This information is then visible on the Properties and tags section of your entities pages.
How it works
You can reference the value of a metadata field in an environment variable.
1env:2 - name: MY_POD_NAMESPACE3 valueFrom:4 fieldRef:5 fieldPath: metadata.namespace
Then OneAgent injects into the newly deployed pods and collects the metadata provided via environment variables.
Enable build label propagation
To enable build label propagation, you need to set feature.dynatrace.com/label-version-detection
to true
in DynaKube. Note that since enabling build label propagation requires webhook injection, it only works with applicationMonitoring
and cloudNativeFullStack
deployments.
1apiVersion: dynatrace.com/v1beta12kind: DynaKube3metadata:4 name: dynakube5 namespace: dynatrace6 annotations:7 feature.dynatrace.com/label-version-detection: "true"8...9 oneAgent:10 cloudNativeFullStack: {}
Default behavior
- The
DT_RELEASE_VERSION
environment variable gets the value frommetadata.labels['app.kubernetes.io/version']
. - The
DT_RELEASE_PRODUCT
environment variable gets the value frommetadata.labels['app.kubernetes.io/part-of']
For example, if your application has the following pod:
1apiVersion: v12kind: Pod3metadata:4 ...5 labels:6 app.kubernetes.io/version: "1.0.0"7 app.kubernetes.io/part-of: "store"8spec:9...
the value of the labels is added to the environment variables of the injected containers:
1apiVersion: v12kind: Pod3metadata:4 ...5 labels:6 app.kubernetes.io/version: "1.0.0"7 app.kubernetes.io/part-of: "Store"8spec:9...10 containers:11 - name: app12 ...13 env:14 - name: "DT_RELEASE_VERSION"15 valueFrom:16 fieldRef:17 fieldPath: metadata.labels['app.kubernetes.io/version']18 - name: "DT_RELEASE_PRODUCT"19 valueFrom:20 fieldRef:21 fieldPath: metadata.labels['app.kubernetes.io/part-of']
If the DT_RELEASE_VERSION
or DT_RELEASE_PRODUCT
environment variables are already set on the container before the OneAgent injection, they will not be overwritten.
Configuration options
You can annotate your namespace to provide further mappings or overrule the defaults for pods within that namespace.
Each annotation key is mapped to a specific environment variable.
- Each annotation value is the reference path in
fieldPath
. - The available information for
fieldPath
is the same as forfieldRef
Example to overwrite the default values for version
and product
, and enable stage
and build-version
1annotations:2 mapping.release.dynatrace.com/version: "metadata.annotations['my-version']"3 mapping.release.dynatrace.com/product: "metadata.labels['app.kubernetes.io/name']"4 mapping.release.dynatrace.com/stage: "metadata.namespace"5 mapping.release.dynatrace.com/build-version: "metadata.labels['release.dynatrace.com/stage']"
Each of these annotations configures a different environment variable:
| Holds the If this annotation is missing, mapping falls back to the default behavior. |
| Holds the |
| Holds the |
The values aren't validated by Dynatrace Operator or the webhook, so make sure they are valid.
