If you already run Synthetic Monitoring in a Dynatrace Classic environment, upgrading to the Latest Dynatrace touches every layer of your setup, from how monitors and locations are represented, to how maintenance windows behave, to how dashboards and access rules are configured. Work through this upgrade guide with its sub-pages to complete the upgrade.
DPS license
Synthetic Monitoring requires a Dynatrace Platform Subscription (DPS) license. If you are on a Classic license, contact your Dynatrace account team before proceeding.
Permissions
| Permission area | What you need |
| Settings | settings.read and settings.write for Environment API changes. See Configure access for the full list. |
| Data access | storage:events:read, storage:metrics:read, storage:smartscape:read to run the DQL checks in this guide. |
| App access | app-engine:apps:run to use the Synthetic app for verification. |
This upgrade guide covers the following Synthetic Monitoring components:
| Component | Coverage |
| Browser monitors | Fully covered: activate the latest RUM JavaScript per monitor or at environment level. |
| HTTP monitors | Fully covered: entity references and maintenance windows must be updated. |
| Network availability monitors (NAM) | Fully covered: custom-device target filters must be replaced with IP addresses or hostnames. |
| Third-party Synthetic integrations | Covered: each active integration requires a replacement path (native NAM or external-test ingest). |
| Private locations | Fully covered: update Synthetic Engines to version 1.347+. Kubernetes and OpenShift locations also require redeployment or Synthetic metric adapter migration. |
| Classic concept | Target concept in Latest Dynatrace |
| Classic Synthetic entity | Smartscape Synthetic node |
| Classic Synthetic metrics and events | Metrics and events in Grail |
| Management zone used for access | IAM policy with a security-context boundary |
| Management zone used for filtering | Segment or equivalent DQL filter |
| Classic access token | Platform token for user-context access, or OAuth client for service-to-service automation |
Use the Check your upgrade readiness dashboard to see the current state of your Synthetic setup before and during the upgrade.
To open the dashboard, go to
Dashboards > All dashboards > Ready-made and select Check your upgrade readiness.
The Synthetic monitoring section of the dashboard covers:
Treat the readiness dashboard as an inventory aid, not as proof that the upgrade is complete. An empty result can mean that no recent data was found; it does not replace configuration inspection and execution tests.
Follow the steps below in the order listed. Each page ends with a Verify the upgrade section. The upgrade is complete when every applicable page has passed its verification.
