Permissions can be assigned on the bucket, table, and entity levels. Without permissions, your users can't fetch any data from a bucket or table.
To set up the bucket and table-level permissions
ALLOW storage:buckets:read WHERE <conditions>;ALLOW <table permission>;
All bucket permissions need to start with storage:buckets:read
. Their scope can be limited by a WHERE
clause that includes one of the three operators:
(equals), indicating an exact match.STARTSWITH
with an expression put in quotation marks.IN
, indicating a range.After the WHERE
clause, you can filter your stored buckets by a specific bucket name or a defined table name:
The example below shows how to access the default_logs
bucket.
ALLOW storage:buckets:read WHERE storage:bucket-name = "default_logs";
For more information, see IAM policy reference.
This only applies if Log Management & Analytics - Retain with Included Queries
is on your rate card.
For more information about retained log data and included query log data, see Retain with Included Queries.
Bucket permissions let you define user group access to
Log Management & Analytics - Query
consumption.Log Management & Analytics - Query
consumption.To define access, you use the storage:query-consumption
condition.
This condition has two possible values.
ON_DEMAND
: Queries can scan all retained data.
This is the default value: if not specified, users have access to all retained data.INCLUDED
: Queries can scan only included query data.This can be combined with the storage:bucket-name
condition to restrict access on a per-bucket level.
The following examples describe how to use bucket permissions to grant access to
Included query data in all buckets.
ALLOW storage:buckets:read WHERE storage:query-consumption="INCLUDED";
Included query data in a specific bucket (common_logs
ALLOW storage:buckets:read WHERE storage:bucket-name="common_logs" AND storage:query-consumption="INCLUDED";
Included query data in all buckets, and additionally all retained data in a specific bucket (common_logs
ALLOW storage:buckets:read WHERE storage:query-consumption="INCLUDED";ALLOW storage:buckets:read WHERE storage:bucket-name="common_logs" AND storage:query-consumption="ON_DEMAND";
All retained data in all buckets.
ALLOW storage:buckets:read WHERE storage:query-consumption="ON_DEMAND";
or
ALLOW storage:buckets:read;
All tables related to log monitoring have their corresponding permissions that need to be set.
Table name
Permission
Affected DQL functions/commands
You can restrict table permissions to certain buckets using the WHERE
clause. For example:
ALLOW storage:logs:read WHERE storage:bucket-name="default_logs";
You can define fine-grained permissions for records that are stored in Grail. The permissions are added to the existing table permissions by adding the WHERE
ALLOW storage:logs:read WHERE storage:dt.security_context="TeamA";
Supported fields:
Field name
IAM condition
Supported IAM tables
event.kind
storage:event.kind
events
, security.events
, bizevents
, system
event.type
storage:event.type
events
, security.events
, bizevents
, system
event.provider
storage:event.provider
events
, security.events
, bizevents
, system
k8s.namespace.name
storage:k8s.namespace.name
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
k8s.cluster.name
storage:k8s.cluster.name
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
host.name
storage:host.name
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
dt.host_group.id
storage:dt.host_group.id
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
metric.key
storage:metric.key
metrics
log.source
storage:log.source
logs
dt.security_context
events
, security.events
, bizevents
, system
, logs
, metrics
, spans
, entities
, smartscape
gcp.project.id
storage:gcp.project.id
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
aws.account.id
storage:aws.account.id
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
azure.subscription
storage:azure.subscription
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
azure.resource.group
storage:azure.resource.group
events
, security.events
, bizevents
, logs
, metrics
, spans
, smartscape
For details that are not available as a dedicated field, set the dt.security_context
field either at the data source or in the processing pipeline.
You can combine both bucket and record level in your table permissions. For example this statement will provide access to all logs in the unrestricted_logs
bucket and only specific records in the default_logs
bucket:
ALLOW storage:logs:read WHERE storage:bucket-name="unrestricted_logs";ALLOW storage:logs:read WHERE storage:bucket-name="default_logs" AND storage:dt.security_context="TeamA";
For efficiency reasons, record filters apply to fields that contain a single string. You might have cases where the fields you want to use for filtering contain multiple values, in conjunction with a "for any value" set semantic. Such case is possible provided both the dt.security_context
field and the IN
operator are used.
For example, the following statement will return results for records with dt.security_context
containing either the crn-70400
string, or an array with crn-70400
as one of its elements.
// will match both "crn-70400" and ["crn-70131", "crn-70400", "crn-70500"]ALLOW storage:logs:read WHERE storage:dt.security_context IN ("crn-70400");
Note that you must use the IN
operator to get "for any value" set semantic. Using =
or STARTSWITH
when dt.security_context
contains an array will always return false. Also note that the IN
"for any value" set semantic only applies to the dt.security_context
field. For any other field containing an array, the IN
operator will always return false. If you expect your record filters to contain an array, ensure the array is stored in dt.security_context
using OpenPipeline Processing or by setting it directly at the source.
As a Dynatrace administrator, I would like to ensure that each of my application teams can only access logs from their own Kubernetes namespace (records identifiable through k8s.namespace.name
) and logs that belong to the basic infrastructure (records identifiable through dt.host_group.id
Solution:
Create a policy for each team that grants them access to their logs.
Make sure that the user has access to all relevant buckets.
ALLOW storage:buckets:read WHERE … // Ensure that the user has access to all relevant bucketsALLOW storage:logs:read WHERE storage:k8s.namespace.name="namespace1";ALLOW storage:logs:read WHERE storage:dt.host_group.id STARTSWITH "shared_host_";
As a Dynatrace administrator, I would like to set up access for my application teams to access logs from lambda functions based on the team tag. For example team
= A
Solution:
Define the log processing rule with a security context that adds the dt.security_context
field based on the lambda tag.
Create a policy for each team that grants them access based on the security context field.
ALLOW storage:buckets:read WHERE … // Ensure that the user has access to all relevant bucketsALLOW storage:logs:read WHERE storage:dt.security_context="TeamA";
As an administrator, I want to control access to business events that contain financial data. They can be identified using the event.kind
field.
Solution:
Create a policy to grant access for specific users to records in bizevents
for the specific event.kind
(Opportunity Field History
ALLOW storage:buckets:read WHERE … // Ensure that the user has access to all relevant bucketsALLOW storage:bizevents:read WHERE storage:event.kind="Opportunity Field History";
As an administrator, I want to provide selected users access to billing events but not to any other system events.
Solution:
Create a policy to grant access to records in dt_system_events
for the specific event.type
with the value BILLING_EVENT
ALLOW storage:buckets:read WHERE storage:bucket-name="dt_system_events"ALLOW storage:system:read WHERE storage:event.kind="BILLING_EVENT"
The following configuration limitations apply to record permissions:
Permissions for entities allow you to define IAM policies that control data access on entities.
In contrast to monitoring data, entity permissions only allow filtering for the dt.security_context
field.
For more information, see Grant access to entities with security context.
You can use field permissions to hide fields that might contain sensitive data. For this purpose, we provide fieldsets. A field is considered sensitive when it's part of a fieldset. Once a field is part of a fieldset, only users with the right permissions can use it in DQL queries for filtering and grouping. For other users, it won't show up in the query results.
You require permission to access fieldsets in order to use sensitive fields. For example, if you want to use builtin-sensitive-spans
fields in DQL queries, you need the following permission:
ALLOW storage:fieldsets:read WHERE storage:fieldset-name="builtin-sensitive-spans"
The two predefined fieldsets are:
- drops all fields on spans that are considered sensitivebuiltin-request-attributes-spans
- drops all fields on spans that contain request attribute data that was marked sensitiveYou can manage your custom fieldsets via REST API
To do this
Go to Fieldsets and select this
Get all fieldsets
GET /fieldsets
Create a new fieldset
POST /fieldsets
Get fieldsets by UID
GET /fieldsets/{fieldsetUid}
Update a fieldset. All fields will be overwritten.
PUT /fieldsets/{fieldsetUid}
Delete a fieldset
DELETE /fieldsets/{fieldsetUid}
This call creates the fieldset sensitive-fields-retail
, removing the credit_card
and DOB
fields from DQL query results in the logs_retail
bucket.
POST https://myapps.mydomain.com/platform/storage/fieldsets/v1/fieldsets
{"name": "sensitive-fields-retail","description": "Sensitive fields retail","enabled": true,"scope": "BUCKET","fields": ["credit_card","DOB"],"buckets": ["logs_retail"]}
To unmask the credit_card
and DOB
fields, you need the following permission:
ALLOW storage:fieldsets:read WHERE storage:fieldset-name="sensitive-fields-retail"
Preview
To manage your lookup data stored in Grail, you require the following permissions:
storage:files:read
- to read lookup data data via DQL.
storage:files:write
- to upload lookup data via REST API.
storage:files:delete
- to delete lookup data via REST API.
All of these permissions support the storage:file-path
condition using one of the following operators:
(equals) - indicating an exact match.IN
- indicating a range.startsWith
- with an expression put in quotation marks.The following example shows how to provide full access to lookup data stored in /lookups/
ALLOW storage:files:read WHERE storage:file-path startsWith "/lookups/";ALLOW storage:files:write WHERE storage:file-path startsWith "/lookups/";ALLOW storage:files:delete WHERE storage:file-path startsWith "/lookups/";
You can use the folder-like structure to manage access to different subsets of your lookup files with permissions, as in the following example.
ALLOW storage:files:read WHERE storage:file-path startsWith "/lookups/public/";
To give read-only access to a specific file, you could also use a permission similar to the following.
ALLOW storage:files:read WHERE storage:file-path startsWith "/lookups/http_status_codes";
There are several predefined global policies, each set per table (logs, events, bizevents, security events, metrics, entities, spans), and three additional, general policies:
This policy provides access to all logs from Grail, and narrows the bucket permission with a WHERE
condition that limits the results to the log table.
This statement provides access to all built-in and custom buckets.
ALLOW storage:buckets:read WHERE storage:table-name= "logs";ALLOW storage:logs:read;
This permission statement gives you access to all tables and all buckets, therefore it needs to be used only in justified cases.
ALLOW storage:buckets:read;ALLOW storage:system:read,storage:events:read,storage:security.events:read,storage:logs:read,storage:metrics:read,storage:entities:read,storage:bizevents:read,storage:spans:read;
This policy retrieves all default monitoring data.
In the first line, this policy statement gives access to all default buckets. The WHERE
condition narrows the search to buckets whose name starts with default
. Subsequently, the next lines list all the needed table permissions.
This statement does not give access to custom buckets.
ALLOW storage:buckets:read WHERE storage:bucket-name STARTSWITH "default_";ALLOW storage:events:read,storage:logs:read,storage:metrics:read,storage:entities:read,storage:bizevents:read,storage:spans:read;
This permission statement first narrows the results to system buckets, whose name starts with dt
. Then, it gives you access to all tables that contain system data, for example audit events
, billing events
, and query execution events. It can be useful for system admins.
ALLOW storage:buckets:read WHERE storage:bucket-name STARTSWITH "dt_";ALLOW storage:system:read;
Ensure that you also have bucket permissions.
If there is an unconditional table permission in any other policy available for a user, the WHERE
clause is irrelevant and the user will always be able to view all records from that table.
Make sure to use the IN
keyword if you are testing for different values. For example
ALLOW storage:logs:read WHERE storage:dt.k8s.namespace.name IN ("ns1", "ns2")
This is important because there is a 100-statement limit per policy - IAM policy statement syntax and examples
Make sure to use the STARTSWITH
command if there are more than one values that start with the same substring.
Make sure to combine logs, events and metrics where applicable (to further save on the 100 statement policy IAM policy statement syntax and examples)
