The Data centers view is deprecated and will be removed in
Infrastructure & Operations v.1.24. After upgrading to 1.24 or later, this view is no longer available, and data centers are not represented as a standalone entity. To view host inventory and monitoring coverage across your data centers, use the Data center overview ready-made dashboard in
Dashboards.
The Data centers view in
Infrastructure & Operations monitors the health and performance of your data centers and availability zones.
Select a data center to view all monitored hosts within it.
Here's what each column in the Data centers view stands for.
Identify critical issues
Check the Unhealthy column and apply the Critical alert filter to quickly find data centers with problems. Selecting the alert indicator will take you to a filtered host list, focusing on the affected systems.
Monitor coverage
Review the Monitored column to ensure comprehensive tracking of all hosts. If you notice gaps in monitoring, you can use
Discovery & Coverage to extend your oversight and achieve full coverage.
