Defunct Process Monitoring extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor defunct processes stuck on your Linux servers.
A defunct process is a process that has completed but still shows in the process table. This is typically due to its parent process being corrupted or experiencing an issue.
The Defunct Process Monitoring OneAgent extension runs on your Linux hosts to report the number of defunct processes on your servers.
Get started
This extension runs on the OneAgent on your Linux hosts. To get started, install this extension and add a monitoring configuration.
  • You can configure the extension to run on a single host, a specified host group or management zone, or across your environment.
  • Choose the frequency you would like the extension to check for defunct processes, and set the ingestion type:
    • Metric: A single metric linux.defunct_processes is ingested per host, providing the number of defunct processes found.
    • Log: If a defunct process is found, a log is ingested per host, containing a log line for each defunct process.
    • Both: Both of the above.
Details
This extension works by making use of the ps -ef | grep defunct command on your hosts. This detects any processes running with the <defunct> mark attached to them.
The daily license consumption for this extension can be calculated as follows:
Custom Metrics per day = ((1440/frequency) * (# of configured hosts))
Log lines per day = (((1440/frequency) * (# of defunct processes)) * (# of configured hosts))
Feature sets
default
Metric nameMetric keyDescription
Defunct Process Countlinux.defunct_processesNumber of defunt processes on this host
Hub
Explore in Dynatrace Hub
Related tags
ComputePythonOS monitoringOtherInfrastructure Observability
