Collect the connection pool performance, usage and availability metrics for Websphere Liberty.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
This extension collects connection pool performance, usage and availability metrics for Websphere Liberty.
Java Metric Extensions 2.0 (JMX).When activating your extension using a monitoring configuration, you can limit monitoring to one of the feature sets. To work properly, the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| In use time | liberty.connectionPool.inUseTime | — |
| Wait time | liberty.connectionPool.waitTime | — |
| Managed connections | liberty.connectionPool.managedConnectionCount | — |
| In use connections | liberty.connectionPool.connectionHandleCount | — |
| Free connections | liberty.connectionPool.freeConnectionCount | — |
