Connection Pools C3P0 extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor C3P0 JDBC connection pool performance, usage, and availability in Java applications to detect leaks and exhaustion issues.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Get started
Overview
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Wildfly, and C3P0.
Use cases
  • Collect the connection pool performance, usage and availability metrics for C3P0.
Compatibility information
  • Java process that uses C3P0 connection pools that run on a supported Linux or Windows operating system.
  • OneAgent
Activation and setup
  1. Install OneAgent on the virtual machine or server of your JBoss process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the C3P0 Connection Pool Overview dashboard.
Feature sets
Base metrics
Metric nameMetric keyDescription
Max Pool Sizec3p0.connectionPool.maxPoolSize—
Num Connectionsc3p0.connectionPool.numConnections—
Num Busy Connectionsc3p0.connectionPool.numBusyConnections—
Num Unclosed Orphaned Connectionsc3p0.connectionPool.numUnclosedOrphanedConnections—
Added metrics
Num Idle Connectionsc3p0.connectionPool.numIdleConnections—
Num Active threadsc3p0.connectionPool.threadPoolNumActiveThreads—
Thread Pool Sizec3p0.connectionPool.threadPoolSize—
Hub
Explore in Dynatrace Hub
Related tags
ApplicationJMXConnection poolMachinery for changeInfrastructure Observability
