MongoDB (local or remote monitoring) extension
  • Latest Dynatrace
  • Extension
Monitor your MongoDB servers either locally or remotely!
Get started
Overview
Connect your MongoDB servers either remotely and locally. A collective batch of data is gathered every minute by this extension and sent to the Dynatrace platform for detailed analysis.
Use cases
  • Monitor database traffic for optimization plan.
  • Monitor database operations with a comprehensive dashboard.
  • Take pre-emptive measures to avoid service degradations.
Requirements
  • Depending on your deployment, one of the following is true
    • Dynatrace OneAgent is installed on your MongoDB Server.
    • Dynatrace ActiveGate is installed and with network access to your MongoDB Server.
  • A MongoDB user with serverStatus@admin, listDatabases, and dbStats permissions. The MongoDB Built In Cluster Monitor Role has these permissions already set up.
Activation and setup
  1. Enable the extension via the Dynatrace Hub.
  2. Choose to monitor remotely via an ActiveGate group or locally via the OneAgent.
  3. Enter the configuration and credentials.
  4. Review the data in the included dashboard.
Details
Along with the username and password you can configure the extension to:
  • Use a different Authentication Database (sets the authSource property in the connection string).
  • Add a path to a CA PEM File (sets the tlsCAFile argument of the MongoClient).
  • Add a path to a Client Certificate (sets the tlsCertificateKeyFile of the MongoClient).
    These file paths need to be accessible on all ActiveGates in the group or locally on the OneAgent Host
  • Select between MongoDB Auth Mechanisms: SCRAM-SHA-1, SCRAM-SHA-256, PLAIN, DEFAULT.
    If no mechanism is specified, PyMongo will automatically use a default value depending on MongoDB version.
    • MongoDB version 3.6 SCRAM-SHA-1
    • MongoDB version 4.0+ SCRAM-SHA-1 or SCRAM-SHA-256
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The MongoDB (local or remote monitoring) extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
The extension gathers a batch of data every minute. The number of metric data points produced per minute is:
per connected process/port: (17 + 5 * <number of databases>)
Dynatrace Platform Subscription
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
When the extension runs locally on a OneAgent-monitored host, its metrics are eligible for the included metrics per host unit.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
Feature sets
replicaSet
Metric nameMetric keyDescription
Replica Set - Oplog Sizemongodb.rs.oplog_sizeThe range between the earliest and latest oplog entires
Replica Set - Oplog Windowmongodb.rs.oplog_windowThe time window covered by the oplog (Replication headroom)
default
Current connectionsmongodb.current_connections—
Available connectionsmongodb.available_connections—
Insert operationsmongodb.insert_operations2.count—
Query operationsmongodb.query_operations2.count—
Update operationsmongodb.update_operations2.count—
Delete operationsmongodb.delete_operations2.count—
Getmore operationsmongodb.getmore_operations2.count—
Command operationsmongodb.command_operations2.count—
Resident memorymongodb.resident_memory—
Virtual memorymongodb.virtual_memory—
Current queuemongodb.current_queue—
Active clientsmongodb.active_clients—
Regular assertsmongodb.regular_asserts2.count—
Warning assertsmongodb.warning_asserts2.count—
Message assertsmongodb.message_asserts2.count—
User assertsmongodb.user_asserts2.count—
Rollover assertsmongodb.rollover_asserts2.count—
Page Faultsmongodb.page_faultsThe total number of page faults
Uptimemongodb.uptimeThe number of seconds that the MongoDB process has been active.
Objectsmongodb.db.objects—
Indexesmongodb.db.indexes—
Data sizemongodb.db.db_data_size—
Storage sizemongodb.db.db_storage_size—
Index sizemongodb.db.db_index_size—
locks
Locks - Current Global Queuemongodb.locks.global_current_queueThe number of operations queued because of a lock.
Locks - Global Total Timemongodb.locks.global_total_timeThe time, in microseconds, since the database last started and created the globalLock. This is roughly equivalent to total server uptime.
Locks - Current Global Acquired Locksmongodb.locks.global_acquireNumber of times the lock was acquired in the specified mode.
Locks - Current Global Aqcuired Waitsmongodb.locks.global_acquire_waitNumber of times the lock acquisitions encountered waits because the locks were held in a conflicting mode.
Locks - Global Time Acquired (Microseconds)mongodb.locks.global_time_acquireCumulative wait time in microseconds for the lock acquisitions.
Locks - Current Global Deadlocksmongodb.locks.global_deadlocksNumber of times the lock acquisitions encountered deadlocks.
wiredTiger
Cache - Pages Requestedmongodb.cache.pages_requestedNumber of pages reqeusted from the cache
Cache - Pages Readmongodb.cache.pages_readNumber of pages read into the cache
Hub
Explore in Dynatrace Hub
Related tags
DatabasePythonNoSQLMongoDBApplication Observability
