There are performance limitations related to the number of running containers. The total number of containers that can be monitored in parallel isn't strictly defined though; this depends on the type of monitored applications and host resources.
Docker containers on Linux can run in any of the following network modes: Host, Bridge, Container, Overlay, None, Macvlan. The default network mode is Bridge. From the available network modes, OneAgent is capable of reporting topology and network metrics for containers running in network modes: Host, Bridge, and Container. Topology for other network modes isn't reported. However, OneAgent is able to detect and report other network modes (with the exception of Macvlan).
The Container mode will only work if the linked network is also in one of the supported modes. The final referenced container must be in Bridge or Host mode. If the final referenced container is in one of the unsupported network modes (None, Overlay, Macvlan), the topology will not be reported.
Non-standard Docker binary file locations aren't supported on Linux.
Container monitoring isn't supported when OneAgent is deployed on Linux in non-privileged mode (in absence of ambient capabilities and with the DISABLE_ROOT_FALLBACK flag enabled).
Only UNIX sockets and unencrypted TCP connections are supported when accessing the Docker API. Encrypted TLS connections aren't supported at this time. Ensure that your Daemon Socket Options don't include the --tlsverify parameter.
If the Docker socket file isn't owned by the docker group, then OneAgent in non-root mode won't be able to read from the Docker API. For such deployments, Docker metrics won't be reported on the Docker overview page.
As Openshift doesn't allow OneAgent in non-root mode to access the Docker API, there are no metrics for Openshift containers on the Docker page. Use the Kubernetes overview page instead. See Monitor Kubernetes workloads and cloud applications for more information.
If Docker API metrics are still required, set OneAgent to root mode.
Workload and node resource metrics cannot be obtained when the container runtime 'docker' is used with a Kubernetes version greather than or equal to 1.24.
OneAgent version 1.145+
If you customize your OneAgent installation path, we support OneAgent installation only in a directory on drive C. Note that we don't support OneAgent installation in the root of drive C.
For containers deployed on hosts running the Windows operating system, we support only Windows Server Containers. Hyper-V containers aren't supported.
Docker service needs to be restarted for OneAgent to be able to properly monitor the containers on Windows.
The restart is required only during the initial OneAgent installation, it's not required with subsequent OneAgent updates.
Containers inside Windows Server Container can run in one of the following network modes: NAT, Transparent, Overlay, L2Bridge, L2Tunnel. The default network mode is NAT.
From the available network modes, OneAgent is capable of reporting topology for containers that run in NAT network mode. OneAgent is able to detect and report other network modes, but doesn't report their topologies.
For containers deployed on Windows, the network module of OneAgent needs to be running for OneAgent to properly report topology.
OneAgent isn't able to report on an inter-docker connection if the containers use only the internal container's addresses (if the connection doesn't go through NAT vNIC).
Network statistics are reported for the main process detected inside containers hosted on Windows. This might lead to measurement inaccuracies when there are more processes performing network operations inside a monitored container.
Dynatrace supports only the default Docker API endpoint path.
The monitoring of Windows Containers is only possible if OneAgent was installed directly on Windows. We currently don't support installing OneAgent through a container on Windows machines.
We assume there's one application per container. For containers with more than one application running inside (for example, Apache and MySQL in one container), we report the same listen ports for both applications (process groups). Network traffic either is assigned to one of the process groups or it's divided between the process groups.
Classic Full Stack auto-instrumentation security disclosure
During auto-instrumentation of containers, OneAgent provides access (via mount point) to specific directories on the root filesystem from inside the container. This is required to utilize OneAgent installation inside the container without creating copies of code modules for each container.
Config directory—provides shared OneAgent configuration and stores configuration specific to a process group
Data Storage directory—dedicated to storing large runtime data produced by OneAgent
Log directory—non-volatile logging from code modules and infrastructure modules
The root users inside instrumented containers have unrestricted access to the above directories on the host filesystem. This can potentially be used for container escape or resource exhaustion.
