| Classic entity type | Classic entity name | Classic monitoring type | New Smartscape node type | New Smartscape node name | AWS - End of Life |
| AWS Auto Scaling Group | Built-in service |
| AWS Auto Scaling auto scaling group | No |
| AWS Availability Zone | Built-in service |
| AWS Availability Zone | No |
| AWS Dynamo DB Table | Built-in service |
| Amazon DynamoDB table | No |
| AWS EBS Volume | Built-in service |
| Amazon EBS volume | No |
| AWS EC2 Instance | Built-in service |
| Amazon EC2 instance | No |
| AWS Elastic Load Balancer | Built-in service |
| AWS Elastic Load Balancing classic load balancer | No |
| AWS Lambda | Built-in service |
| AWS Lambda function | No |
| AWS Relational Database Service | Built-in service |
| Amazon Relational Database Service (RDS) DB instance | No |
| Amazon API Gateway | Cloud service |
| Amazon API Gateway REST API | No |
| Amazon API Gateway v2 API (HTTP or WebSocket) | No |
| Amazon ApplicationELB | Cloud service |
| AWS Elastic Load Balancing v2 load balancer (application, network, gateway) | No |
| AWS Elastic Load Balancing v2 target group | No |
| Amazon AppStream | Cloud service |
| Amazon AppStream fleet | No |
| Amazon Athena | Cloud service |
| Amazon Athena workgroup | No |
| Amazon Aurora | Cloud service |
| Amazon Relational Database Service (RDS) DB cluster | No |
| Amazon CloudFront | Cloud service |
| Amazon CloudFront distribution | No |
| Amazon CloudWatch Logs | Cloud service |
| Amazon CloudWatch Logs log group | No |
| Amazon Connect | Cloud service |
| Amazon Connect instance | No |
| Amazon DynamoDB | Cloud service |
| Amazon DynamoDB Accelerator (DAX) | Cloud service |
| Amazon DynamoDB Accelerator (DAX) cluster | No |
| Amazon EBS | Cloud service |
| Amazon EC2 | Cloud service |
| Amazon EC2 Auto Scaling | Cloud service |
| Amazon ECS Container Insights | Cloud service |
| Amazon ECS cluster | No |
| Amazon Elastic Container Service (ECS) | Cloud service |
| Amazon ECS service | No |
| Amazon Elastic File System (EFS) | Cloud service |
| Amazon Elastic File System file system | No |
| Amazon Elastic Kubernetes Service (EKS) | Cloud service |
| Amazon EKS cluster | No |
| Amazon Elastic Map Reduce (EMR) | Cloud service |
| Amazon Elastic MapReduce cluster | No |
| Amazon ElastiCache (EC) | Cloud service |
| Amazon ElastiCache cache cluster | No |
| Amazon ElastiCache serverless cache | No |
| Amazon Elasticsearch Service (ES) | Cloud service |
| Amazon OpenSearch Service domain | No |
| Amazon EventBridge | Cloud service |
| Amazon EventBridge event bus | No |
| Amazon FSx | Cloud service |
| Amazon FSx file system (Lustre, Windows, OpenZFS, NetApp ONTAP) | No |
| Amazon Keyspaces | Cloud service |
| Amazon Keyspaces(for Apache Cassandra) keyspace | No |
| Amazon Keyspaces (for Apache Cassandra) table | No |
| Amazon Kinesis Data Analytics | Cloud service |
| Amazon Managed Service for Apache Flink application | No |
| Amazon Kinesis Data Firehose | Cloud service |
| Amazon Data Firehose delivery stream | No |
| Amazon Kinesis Data Streams | Cloud service |
| Amazon Kinesis data stream | No |
| Amazon Managed Streaming for Kafka | Cloud service |
| Amazon Managed Streaming for Apache Kafka (MSK) cluster | No |
| Amazon MQ | Cloud service |
| Amazon MQ broker | No |
| Amazon NetworkELB | Cloud service |
| Amazon RDS | Cloud service |
| Amazon Redshift | Cloud service |
| Amazon Redshift cluster | No |
| Amazon Route 53 | Cloud service |
| Amazon Route 53 health check | No |
| Amazon Route 53 hosted zone | No |
| Amazon S3 | Cloud service |
| Amazon S3 bucket | No |
| Amazon SageMaker Endpoint Instances | Cloud service |
| Amazon SageMaker endpoint | No |
| Amazon SageMaker Endpoints | Cloud service |
| Amazon Simple Notification Service (SNS) | Cloud service |
| Amazon Simple Notification Service (SNS) topic | No |
| Amazon Simple Queue Service (SQS) | Cloud service |
| Amazon Simple Queue Service (SQS) queue | No |
| Amazon VPC NAT Gateways | Cloud service |
| Amazon VPC NAT gateway | No |
| AWS App Runner | Cloud service |
| AWS App Runner service | No |
| AWS AppSync | Cloud service |
| AWS AppSync GraphQL API | No |
| AWS Certificate Manager Private Certificate Authority | Cloud service |
| AWS Private Certificate Authority private CA | No |
| AWS CloudHSM | Cloud service |
| AWS CloudHSM cluster | No |
| AWS CodeBuild | Cloud service |
| AWS CodeBuild project | No |
| AWS Database Migration Service (AWS DMS) | Cloud service |
| AWS Database Migration Service (DMS) replication instance | No |
| AWS DataSync | Cloud service |
| AWS DataSync task | No |
| AWS Direct Connect | Cloud service |
| AWS Direct Connect connection | No |
| AWS Elastic Beanstalk | Cloud service |
| AWS Elastic Beanstalk environment | No |
| AWS Glue | Cloud service |
| AWS Glue job | No |
| AWS Lambda | Cloud service |
| AWS Site-to-Site VPN | Cloud service |
| AWS Site-to-Site VPN vpn connection | No |
| AWS Step Functions | Cloud service |
| AWS Step Functions state machine | No |
| AWS Storage Gateway | Cloud service |
| AWS Storage Gateway gateway | No |
| AWS Transit Gateway | Cloud service |
| AWS Transit Gateway transit gateway | No |
| AWS WAF | Cloud service |
| AWS WAFv2 web ACL | No |
AWS/ACMPrivateCA | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/AmazonMQ | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/ApiGateway | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
AWS/ApplicationELB | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/AppRunner | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/AppStream | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/AppSync | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Athena | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
AWS/AutoScaling | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Billing | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Cassandra | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/Chatbot | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/CloudFront | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/CloudHSM | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/CloudSearch | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/CodeBuild | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/Cognito | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Connect | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/DataSync | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/DAX | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/DMS | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
AWS/DocDB | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/DX | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/DynamoDB | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/EBS | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
AWS/EC2 | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/EC2/API | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/EC2Spot | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/ECS | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/EFS | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/ElastiCache | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/ElasticBeanstalk | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/ElasticInference | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/ElasticMapReduce | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/ElasticTranscoder | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/ELB | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/ES | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/Events | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Firehose | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/FSx | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/GameLift | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Inspector | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/IoT | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/IoTAnalytics | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Kafka | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/Kinesis | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
AWS/KinesisAnalytics | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
AWS/KinesisVideo | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Lambda | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Lex | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/Logs | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/MediaConnect | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/MediaConvert | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/MediaPackage | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/MediaTailor | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
AWS/NATGateway | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
AWS/Neptune | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
AWS/NetworkELB | CloudWatch Metric Name | CloudWatch Dimensions | Classic - Metric Key in Dynatrace | Classic - AWS Service Type in Dynatrace | New - Metric Key in Dynatrace | New - Metric Feature Set |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Cloud service |
| Recommended |
| Built-in service |
| Recommended |
| Cloud service |
| Recommended |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Recommended |
| Built-in service |
| Autodiscovery |
| Built-in service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
| Cloud service |
| Autodiscovery |
