VMware (remote monitoring) extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
Monitor the health and performance of your VMware vSphere infrastructure.
Get started
Overview
Use VMware to connect to the vCenter and gather metrics, events, and alerts about your vSphere clusters, ESXi hosts, virtual machines, datastores, and disks.
Use cases
Use this extension to:
  • Monitor the health and performance of your VMware.
  • Ensure optimal splitting of resources between the virtual machines.
  • Detect problems and pinpoint the root cause in your virtualization and application layer.
Requirements
Time synchronization
Differences in system time can lead to missing VMware metrics. For Dynatrace to properly display monitoring data, synchronize time settings on all monitored host environments and vCenters with an NTP server.
  • Active VMware vCenter
  • ActiveGate with EEC Performance Profile of High or Dedicated deployed on a Linux or Windows environment. For more information about the performance profiles, see Dedicated performance profile configuration (Dynatrace Classic).
    When you use the dedicated performance profile, the REST Interface is disabled by default. To ingest vCenter Triggered Alarms and vCenter Custom Attributes & Tags, you need to manually turn on the REST Interface in the ActiveGate's custom.properties file by setting the following:
    [collector]
    restInterface = true
  • ActiveGate connected to the vSphere
  • A user with read-only permissions in vSphere
Compatibility information
This extension uses pyVmomi, the Python SDK for the VMware vSphere Management API.
pyVmomi has its own compatibility information. To learn more, see pyVmomi Compatibility Policy.
  • Extension versions 3.14.2 and below use pyvmomi==8.0.3.0.1.
  • Extension versions 3.14.7+ use pyvmomi==9.0.0.0.
The VMware vSphere platform has been deprecating some metrics. Metric availability may vary based on vSphere version.
Details
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The VMware (remote monitoring) extension ingests custom metrics, which consume Davis Data Units (DDUs).
This extension uses logs (for more information, see vSphere Events) and custom metrics.
If you are concerned about license usage due to the number of metrics collected and their potential cardinality in larger VMware vSphere deployments, contact your Dynatrace account team.
The amount of custom metrics will vary depending on the number of resources running in your vCenter, and the number of resources will naturally increase and decrease as resources are created and deleted.
Consider the average number of resources you will have deployed long-term.
  • Total number of clusters
  • Total number of datastores
  • Total number of ESXi hosts deployed. Per ESXi host, consider the average number of:
    • Disks
    • Datastores
    • NICs
  • Average number of VMs deployed. Per VM, consider the average number of:
    • Disks
    • Datastores
    • Volumes
    • NICs
With these values, the formula for datapoints used by the extension per minute is as follows:
(7 x <total number of clusters>) + (70 + (14 x <avg number of disks per host>) + (1 x <avg number of datastores per host>) + (5 x <avg number of NICs per host>)) * <number of hosts deployed> + (58 + (9 x <avg number of disks per VM) + (3 x <avg number of datastores per VM>) + (2 x <avg number of volumes per VM>) + (3 x <avg number of NICs per VM>)) * <number of VMs deployed> + (11 x <total number of datastores>)
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
Dynatrace classic license
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For logs, regular DDU consumption applies. See DDU consumption for Log Management and Analytics or DDUs for Log Monitoring Classic.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
Feature sets
VM Snapshots
Metric nameMetric keyDescription
Current Snapshot Agevmware.vm.current_snapshot.ageAge of the current snapshot. VMware does not recommend using a given snapshot for more than 24 to 72 hours.
VM Memory
Ballooned Memoryvmware.vm.mem.balloonedThe size of the balloon driver in the VM, in MB. The host will inflate the balloon driver to reclaim physical memory from the VM. This is a sign that there is memory pressure on the host.
Compressed Memoryvmware.vm.mem.compressedThe amount of compressed memory currently consumed by VM, in Kb.
Swapped Memoryvmware.vm.mem.swappedThe portion of memory, in MB, that is granted to this VM from the host's swap space. This is a sign that there is memory pressure on the host.
Memory Capacity Contentionvmware.vm.mem.capacity.contention.averagePercentage of time VMs are waiting to access swapped, compressed or ballooned memory
Memory Latencyvmware.vm.mem.latency.averagePercentage of time the virtual machine spent waiting to swap in or decompress guest physical memory
ESXi Host Disk Latency - Basic
Command latencyvmware.host.disk.totalLatency.averageAverage amount of time taken during the collection interval to process a SCSI command issued by the guest OS to the virtual machine
ESXi Host CPU
CPU Capacity Contentionvmware.host.cpu.capacity.contention.averagePercent of time the VM is unable to run because it is contending for access to the physical CPU(s)
CPU Capacity Usagevmware.host.cpu.capacity.usage.averageCPU usage as a percent during the interval
CPU Idlevmware.host.cpu.idle.summationTotal time that the CPU spent in an idle state
CPU Co-stopvmware.host.cpu.costop.summationTime the virtual machine is ready to run, but is unable to run due to co-scheduling constraints
CPU Latencyvmware.host.cpu.latency.averagePercent of time the virtual machine is unable to run because it is contending for access to the physical CPU(s)
CPU Readyvmware.host.cpu.ready.summationTime that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval
CPU Ready Percentvmware.host.cpu.ready.percentTime that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval
CPU Swap Waitvmware.host.cpu.swapwait.summationCPU time spent waiting for swap-in
CPU Total Hzvmware.host.cpu.total_hzTotal CPU Hz available to Host (num of CPU Cores * Hz for Each Core)
CPU Used Hzvmware.host.cpu.used_hzUsed CPU Hz of Host
CPU Waitvmware.host.cpu.wait.summationTotal CPU time spent in wait state
CPU Usage in MHz (avg)vmware.host.cpu.usagemhz.averageCPU usage in megahertz during the interval
CPU Usage in MHz (min)vmware.host.cpu.usagemhz.minimumCPU usage in megahertz during the interval
CPU Usage (min)vmware.host.cpu.usage.minimumCPU usage as a percentage during the interval
Running (1 min average)vmware.host.rescpu.runav1.latestCPU running average over 1 minute
Running (1 min peak)vmware.host.rescpu.runpk1.latestCPU running average over 1 minute
Active (1 min peak)vmware.host.rescpu.actpk1.latestCPU active peak over 1 minute
CPU Active (1 min average)vmware.host.rescpu.actav1.latestCPU Active (1 min average)
ESXi Host Disk
Host Disk Capacityvmware.host.disk.capacity—
ESXi Host Network
Network Usage (min)vmware.host.net.usage.minimumNetwork utilization (combined transmit-rates and receive-rates) during the interval
Network Usage (max)vmware.host.net.usage.maximumNetwork utilization (combined transmit-rates and receive-rates) during the interval
ESXi Host Memory - Min
Memory Consumed (min) %vmware.host.mem.usage.minimumPercentage of host physical memory that has been consumed
Memory Granted (min)vmware.host.mem.granted.minimumAmount of host physical memory or physical memory that is mapped for a virtual machine or a host
Ballooned memory (min)vmware.host.mem.vmmemctl.minimumAmount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest
Memory cache consumed (min)vmware.host.mem.llSwapUsed.minimumStorage space consumed on the host swap cache for storing swapped guest physical memory pages
Memory Swap In (min)vmware.host.mem.swapIn.minimum—
Memory Swap Out (min)vmware.host.mem.swapOut.minimum—
Memory Consumed (Min)vmware.host.mem.consumed.minimum—
Memory Active (Min)vmware.host.mem.active.minimum—
VM Datastore/Storage
Storage Committedvmware.vm.storage.committedTotal storage space, in bytes, committed to this virtual machine across all datastores.
Storage Uncommittedvmware.vm.storage.uncommittedAdditional storage space, in bytes, potentially used by this virtual machine on all datastores.
Datastore Read Latencyvmware.vm.datastore.totalReadLatency.average—
Datastore Write Latencyvmware.vm.datastore.totalWriteLatency.average—
default
—vmware.info.datastore_info—
—vmware.info.host_relations—
Host Availabilityvmware.host.availability100% if Connected and Powered On, else 0%
VM Availabilityvmware.vm.availability100% if Connected and Powered On, else 0%
ESXi Host Sensors
Sensor Statevmware.host.sensor.stateHardware sensor state within the ESXi Host. 0=Green 1=Gray 2=Yellow 3=Red
VM Volume
Backing Device Capacityvmware.vm.device.capacity—
Volume Capacityvmware.vm.volume.capacityTotal capacity of the disk, in bytes. This is part of the virtual machine configuration.
Volume Free Spacevmware.vm.volume.free_spaceFree space on the disk, in bytes. This is retrieved by VMware Tools.
ESXi Host Disk Latency - Advanced
Disk Highest Latencyvmware.host.disk.maxTotalLatency.latestHighest latency value across all disks used by the host
Physical Device Read Latencyvmware.host.disk.deviceReadLatency.averageAverage amount of time, in milliseconds, to read from the physical device
Physical Device Write Latencyvmware.host.disk.deviceWriteLatency.averageAverage amount of time, in milliseconds, to write to the physical device
Queue Write Latencyvmware.host.disk.queueWriteLatency.averageAverage amount of time spent in the VMkernel queue, per SCSI write command, during the collection interval
Total Write latency (StoragePath)vmware.host.storagePath.totalWriteLatency.averageThe average time a write issued on the storage path takes
ESXi Host Info
Number of CPU Coresvmware.host.cpu.num_cores—
Memory Sizevmware.host.mem.sizeTotal amount of physical memory on the host in bytes.
Memory Used (MB)vmware.host.mem.used_mbPhysical memory usage on the host in MB
ESXi Host Uptimevmware.host.uptimeNumber of seconds the ESXi host has been up
VM Disk
Disk Highest latencyvmware.vm.disk.maxTotalLatency.latestHighest latency value across all disks used by the host
Total Write latencyvmware.vm.disk.totalWriteLatency.averageAverage amount of time taken during the collection interval to process a SCSI write command issued by the guest OS to the virtual machine
Read Requestsvmware.vm.disk.numberReadAveraged.averageNumber of disk reads per second during the collection interval
Write Requestsvmware.vm.disk.numberWriteAveraged.averageNumber of disk writes per second during the collection interval
Read latencyvmware.vm.disk.totalReadLatency.averageThe average time a read from the virtual disk takes
Read ratevmware.vm.disk.read.averageAverage number of kilobytes read from the disk each second during the collection interval
Write ratevmware.vm.disk.write.averageAverage number of kilobytes written from the disk each second during the collection interval
Read Requestsvmware.vm.virtualDisk.numberReadAveraged.average—
Write Requestsvmware.vm.virtualDisk.numberWriteAveraged.average—
Read Ratevmware.vm.virtualDisk.read.average—
Write Ratevmware.vm.virtualDisk.write.average—
Read Latencyvmware.vm.virtualDisk.totalReadLatency.average—
Write Latencyvmware.vm.virtualDisk.totalWriteLatency.average—
Throughput Contentionvmware.vm.virtualDisk.throughput.cont.average—
Base VM Metrics
CPU Usagevmware.vm.cpu.usage.averageCPU usage as a percentage during the interval
CPU Ready Percentvmware.vm.cpu.ready.percentTime that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval
CPU Readyvmware.vm.cpu.ready.summationTime that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval
CPU Swap Waitvmware.vm.cpu.swapwait.summationCPU time spent waiting for swap-in
CPU Usage in MHzvmware.vm.cpu.usagemhz.maximumCPU usage in megahertz during the interval
Disk Usagevmware.vm.disk.usage.averageAggregated disk I/O rate. For hosts, this metric includes the rates for all virtual machines running on the host during the collection interval.
VM Memory Used % (avg)vmware.vm.mem.usage.averagePercentage of vm memory that has been consumed
Active Memory Usedvmware.vm.mem.active.averageAmount of guest physical memory that is being actively read or written by guest. Activeness is estimated by ESXi
Memory Compression Ratevmware.vm.mem.compressionRate.averageRate of guest physical memory page compression by ESXi
Memory Decompression Ratevmware.vm.mem.decompressionRate.averageRate of guest physical memory decompression
Memory Swap In Ratevmware.vm.mem.swapinRate.averageRate at which guest physical memory is swapped in from the swap space
Memory Swap Out Ratevmware.vm.mem.swapoutRate.averageRate at which guest physical memory is swapped out to the swap space
Data transmit ratevmware.vm.net.transmitted.averageRate at which data was transmitted during the interval
Data receive ratevmware.vm.net.received.averageRate at which data was received during the interval
Datastore Max Total Latencyvmware.vm.datastore.maxTotalLatency.latest—
ESXi Host Status
System Overall Statusvmware.host.overall.statusThe overall alarm status of the host. 0=Green 1=Gray 2=Yellow 3=Red
Connection Statusvmware.host.connected.status0=Connected to the server. For ESX Server, this is always the setting. 1=The user has explicitly taken the host down. 2=Virtual Center is not receiving heartbeats from the server.
Power Statusvmware.host.powered.statusThe host power state. See the description in the enums for the PowerState data object type. 0=The host is powered on. A host that is entering standby mode entering is also in this state. 1=The host was specifically put in standby mode, either explicitly by the user, or automatically by DPM. 2=The host was specifically powered off by the user through VirtualCenter. 3=The host is disconnected, or notResponding, we can't have knowledge of its power state
ESXi Host License
Host License Expiration Timevmware.host.license.expirationTime until the license expires on this host
ESXi Host Memory - Max
Memory Granted (max)vmware.host.mem.granted.maximumAmount of host physical memory or physical memory that is mapped for a virtual machine or a host
Ballooned memory (max)vmware.host.mem.vmmemctl.maximumAmount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest
Memory cache consumed (max)vmware.host.mem.llSwapUsed.maximumStorage space consumed on the host swap cache for storing swapped guest physical memory pages
Memory Swap In (max)vmware.host.mem.swapIn.maximum—
Memory Swap Out (max)vmware.host.mem.swapOut.maximum—
Memory Consumed (Max)vmware.host.mem.consumed.maximum—
Memory Active (Max)vmware.host.mem.active.maximum—
VM CPU - Max
CPU Usagevmware.vm.cpu.usage.maximumCPU usage as a percentage during the interval
CPU Max Usagevmware.vm.cpu.max_usageCurrent upper-bound on CPU usage
VM Reservations
VM CPU Reservationvmware.vm.reservation.cpu—
VM Memory Reservationvmware.vm.reservation.memory—
Datastore Relationships
—vmware.info.datastore_relations—
ESXi Host Memory - Basic
Memory Consumed (max) %vmware.host.mem.usage.maximumPercentage of host physical memory that has been consumed
VM Info
VM CPU Coresvmware.vm.cpu.num_cores—
VM Memory Sizevmware.vm.mem.size—
ESXi Host Memory
Memory Swap In Ratevmware.host.mem.swapinRate.averageRate at which guest physical memory is swapped in from the swap space
Memory Swap Out Ratevmware.host.mem.swapoutRate.averageRate at which guest physical memory is swapped out to the swap space
Memory Granted (avg)vmware.host.mem.granted.averageAmount of host physical memory or physical memory that is mapped for a virtual machine or a host
Ballooned memory (avg)vmware.host.mem.vmmemctl.averageAmount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest
Memory cache consumed (avg)vmware.host.mem.llSwapUsed.averageStorage space consumed on the host swap cache for storing swapped guest physical memory pages
Memory Latencyvmware.host.mem.latency.averagePercentage of time the virtual machine spent waiting to swap in or decompress guest physical memory
Memory Capacity Contentionvmware.host.mem.capacity.contention.averagePercentage of time VMs are waiting to access swapped, compressed or ballooned memory
Datastore Metrics
Datastore Capacityvmware.datastore.capacity—
Datastore Free Spacevmware.datastore.freeSpace—
Average Read Requests (per second)vmware.datastore.datastore.numberReadAveraged.averageAverage number of read commands issued per second to the datastore during the collection interval
Average Write Requests (per second)vmware.datastore.datastore.numberWriteAveraged.averageAverage number of write commands issued per second to the datastore during the collection interval
Read Ratevmware.datastore.datastore.read.averageRate of reading data from the datastore
Write Ratevmware.datastore.datastore.write.averageRate of writing data to the datastore
Throughput Usagevmware.datastore.datastore.throughput.usage.averageDatastore Throughput Usage
Throughput Contentionvmware.datastore.datastore.throughput.contention.averageDatastore Throughput Contention
Datastore Uncommittedvmware.datastore.uncommitted—
Disk Provisionedvmware.datastore.disk.provisioned.latestAmount of storage set aside for use by a datastore or a virtual machine
VM Status
Guest Heartbeat Statusvmware.vm.guest.statusThe guest heartbeat. The heartbeat status is classified as: 0=Green : Guest operating system is responding normally. 1=Gray : VMware Tools are not installed or not running. 2=Yellow : Intermittent heartbeat. May be due to guest load. 3=Red : No heartbeat. Guest operating system may have stopped responding.
Power Statusvmware.vm.power.statusCurrent power state of the virtual machine. Status Codes: 0=Powered On 1=Suspended 2=Powered Off
Fault Tolerance Statusvmware.vm.fault.tolerance.statusThe fault tolerance state of the VM. 0 = Enabled, 1 = Starting, 2 = notConfigured, 3 = Running, 4 = Disabled, 5 = needSecondary
Consolation Neededvmware.vm.consolidation.neededIndicates whether a disk associated with the virtual machine requires consolidation. Status codes: 0=false 1=true
VM Memory - Max
Memory Grantedvmware.vm.mem.granted.maximumAmount of host physical memory or physical memory that is mapped for a virtual machine or a host
Ballooned memoryvmware.vm.mem.vmmemctl.maximumAmount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest
Memory Consumedvmware.vm.mem.consumed.maximumAmount of host physical memory consumed for backing up guest physical memory pages
VM Memory Used % (max)vmware.vm.mem.usage.maximumPercentage of vm memory that has been consumed
Memory Max Usagevmware.vm.mem.max_usageCurrent upper-bound on memory usage.
Cluster Metrics
Total CPU Processorsvmware.cluster.cpu.cores—
Cluster CPU Capacityvmware.cluster.cpu.capacity—
Cluster CPU Usedvmware.cluster.cpu.used—
Cluster Memory Capacityvmware.cluster.mem.capacity—
Cluster Memory Usedvmware.cluster.mem.used—
Cluster Storage Capacityvmware.cluster.storage.capacity—
Cluster Storage Usedvmware.cluster.storage.used—
Base ESXi Host Metrics
CPU Usagevmware.host.cpu.usage.averageCPU usage as a percentage during the interval
Disk I/O Ratevmware.host.disk.usage.averageAggregated disk I/O rate. For hosts, this metric includes the rates for all virtual machines running on the host during the collection interval.
Disk Bus Resetsvmware.host.disk.busResets.summation.countNumber of SCSI-bus reset commands issued during the collection interval
Disk Commandsvmware.host.disk.commands.summationNumber of SCSI commands issued during the collection interval
Disk Commands Abortedvmware.host.disk.commandsAborted.summationNumber of SCSI commands aborted during the collection interval
Queue Command Latencyvmware.host.disk.queueLatency.averageAverage amount of time spent in the VMkernel queue, per SCSI command, during the collection interval
Disk Read Requestsvmware.host.disk.numberRead.summationNumber of disk reads during the collection interval
Disk Write Requestsvmware.host.disk.numberWrite.summationNumber of disk writes during the collection interval
Disk Read Ratevmware.host.disk.read.averageAverage number of kilobytes read from the disk each second during the collection interval
Disk Write Ratevmware.host.disk.write.averageAverage number of kilobytes written to disk each second during the collection interval
Read Latencyvmware.host.disk.totalReadLatency.averageAverage amount of time taken during the collection interval to process a SCSI read command issued from the guest OS to the virtual machine
Write latencyvmware.host.disk.totalWriteLatency.averageAverage amount of time taken during the collection interval to process a SCSI write command issued by the guest OS to the virtual machine
Memory Compression Ratevmware.host.mem.compressionRate.averageRate of guest physical memory page compression by ESXi
Memory Decompression Ratevmware.host.mem.decompressionRate.averageRate of guest physical memory decompression
Host Memory Consumed %vmware.host.mem.usage.averagePercentage of host physical memory that has been consumed
Memory Active (Avg)vmware.host.mem.active.average—
Memory Consumed (Avg)vmware.host.mem.consumed.average—
Memory Swap In (avg)vmware.host.mem.swapIn.average—
Memory Swap Out (avg)vmware.host.mem.swapOut.average—
Network Usagevmware.host.net.usage.averageNetwork utilization (combined transmit-rates and receive-rates) during the interval
Data transmit ratevmware.host.net.transmitted.averageRate at which data was transmitted during the interval
Data receive ratevmware.host.net.received.averageRate at which data was received during the interval
Data Receive Ratevmware.host.net.bytesRx.averageAverage amount of data received per second
Data Transmit Ratevmware.host.net.bytesTx.averageAverage amount of data transmitted per second
Host Network Interface Speedvmware.host.nic.link_speedLink Speed of Physical Network Interface Card
Received Packets Droppedvmware.host.net.droppedRx.summation.countNumber of receives dropped
Transmitted Packets Droppedvmware.host.net.droppedTx.summation.countNumber of transmits dropped
VM CPU
CPU Capacity Contentionvmware.vm.cpu.capacity.contention.averagePercent of time the VM is unable to run because it is contending for access to the physical CPU(s)
CPU Capacity Usagevmware.vm.cpu.capacity.usage.averageCPU usage as a percent during the interval
CPU Core Count Contention (Ready)vmware.vm.cpu.corecount.contention.averageTime the VM vCPU is ready to run, but is unable to run due to co-scheduling constraints
CPU Idlevmware.vm.cpu.idle.summationTotal time that the CPU spent in an idle state
CPU Co-stopvmware.vm.cpu.costop.summationTime the virtual machine is ready to run, but is unable to run due to co-scheduling constraints
CPU Latencyvmware.vm.cpu.latency.averagePercent of time the virtual machine is unable to run because it is contending for access to the physical CPU(s)
CPU Waitvmware.vm.cpu.wait.summationTotal CPU time spent in wait state
CPU Demandvmware.vm.cpu.demand.averageThe amount of CPU resources a virtual machine would use if there were no CPU contention or CPU limit
Active (1 min peak)vmware.vm.rescpu.actpk1.latestCPU active peak over 1 minute
Running (1 min peak)vmware.vm.rescpu.runpk1.latestCPU running peak over 1 minute
CPU Active (1 min average)vmware.vm.rescpu.actav1.latestCPU Active (1 min average)
CPU Running (1 min average)vmware.vm.rescpu.runav1.latestCPU Running (1 min average)
ESXi Host CPU - Max
CPU Usage in MHz (max)vmware.host.cpu.usagemhz.maximumCPU usage in megahertz during the interval
CPU Usage (max)vmware.host.cpu.usage.maximumCPU usage as a percentage during the interval
VM Network
Received Packets Droppedvmware.vm.net.droppedRx.summation.countNumber of receives dropped
Transmitted Packets Droppedvmware.vm.net.droppedTx.summation.countNumber of transmits dropped
Network Utilizationvmware.vm.net.usage.maximumNetwork utilization (combined transmit-rates and receive-rates)
Data received Ratevmware.vm.net.bytesRx.averageAverage amount of data received per second
Data Transmit Ratevmware.vm.net.bytesTx.averageAverage amount of data transmitted per second
FAQ
What vSphere events are included in the extension?
The following events are included in the VMware (remote monitoring) extension and are ingested as log messages.
The ingested severities apply to version 4.4.0 and above.
  • Alarm Events:
Event TypeIngested Severity
AlarmActionTriggeredEvent
WARN
  • ESXi Host Events:
EnteredMaintenanceModeEvent
INFO
HostCnxFailedEvent
ERROR
HostCnxFailedNoConnectionEvent
ERROR
HostCnxFailedTimeoutEvent
ERROR
HostConnectedEvent
INFO
HostConnectionLostEvent
ERROR
HostDisconnectedEvent
WARN
HostShutdownEvent
WARN
HostSyncFailedEvent
ERROR
DasHostFailedEvent
ERROR
com.vmware.vc.HA.HostStateChangedEvent
WARN
  • DRS VM Events:
DrsVmMigratedEvent
INFO
DrsVmPoweredOnEvent
INFO
  • VM Events:
VmDisconnectedEvent
WARN
VmGuestShutdownEvent
INFO
VmMigratedEvent
INFO
VmPoweredOffEvent
INFO
VmPoweredOnEvent
INFO
VmFailedMigrateEvent
ERROR
com.vmware.vc.ha.VmRestartedByHAEvent
WARN
Alarm events may be ingested as either logs or events. For large environments, we recommend using event-based alarms. If you're using version older than 3.14.2, log-based alarms aren't supported when lowering the Task Size parameter due to performance constraints. However, with version 3.14.2+, log-based alarms can be used with a lowered task size.
Hub
Explore in Dynatrace Hub
Monitor the health and performance of VMware vSphere clusters, ESXi hosts, virtual machines, and datastores using metrics, logs, and events.
Related tags
VirtualizationPythonvSphereVMwareInfrastructure Observability
