UPS Device extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
  • Published Oct 27, 2025
Monitor your Uninterruptible Power Supplies (UPS) over SNMP.
Monitor UPS health and battery status to prevent outages and ensure infrastructure reliability.
Get started
Overview
This extension collects important UPS infrastructure metrics to monitor the health and reliability of devices. Metrics are collected through SNMP get polling.
Use cases
  • Check UPS battery conditions such as charge or time remaining.
  • Detect device anomalies and avoid data center outages.
Requirements
Simply activate the extension in your environment using the in-product Hub, provide the necessary device configuration and you’re all set up.
Compatibility information
  • Most UPS vendors and models (UPS-MIB supported)
Details
The extension package contains:
  • SNMP Data Source configuration,
  • Overview dashboard
  • Custom Topology types extracted from metric dimensions
  • UPS Device
The following SNMP MIB files are used for monitoring:
  • UPS-MIB
  • FC1213-MIB
Feature sets
ups-alarm
Metric nameMetric keyDescription
UPS Alarms Presentsnmp.ups.AlarmsPresentThe present number of active alarm conditions.
ups-input-table
UPS Line Input Frequencysnmp.ups.line.InputFrequencyThe present input frequency (0.1 Hertz).
UPS Line Input Voltagesnmp.ups.line.InputVoltageThe magnitude of the present input voltage (RMS Volts).
UPS Line Input Currentsnmp.ups.line.InputCurrentThe magnitude of the present input current (0.1 RMS AMP)
UPS Line Input True Powersnmp.ups.line.InputTruePowerThe magnitude of the present input true power (Watts).
ups-output-table
UPS Line Output Voltagesnmp.ups.line.OutputVoltageThe present output voltage (RMS Volts).
UPS Line Output Currentsnmp.ups.line.OutputCurrentThe present output current (0.1 RMS AMPS).
UPS Line Output Powersnmp.ups.line.OutputPowerThe present output true power (WATTS).
UPS Line Output Percent Loadsnmp.ups.line.OutputPercentLoadThe percentage of the UPS power capacity presently being used on this output line, i.e., the greater of the percent load of true power capacity and the percent load of VA.
ups-battery
UPS Battery Statussnmp.ups.BatteryStatusThe indication of the capacity remaining in the UPS system's batteries - unknown(1), batteryNormal(2), batteryLow(3), batteryDepleted(4)
UPS Seconds On Batterysnmp.ups.SecondsOnBatteryIf the unit is on battery power, the elapsed time since the UPS last switched to battery power, or the time since the network management subsystem was last restarted, whichever is less. Zero shall be returned if the unit is not on battery power.
UPS Estimated Minutes Remainingsnmp.ups.EstimatedMinutesRemainingAn estimate of the time to battery charge depletion under the present load conditions if the utility power is off and remains off, or if it were to be lost and remain off.
UPS Estimated Charge Remainingsnmp.ups.EstimatedChargeRemainingAn estimate of the battery charge remaining expressed as a percent of full charge.
UPS Battery Voltage (0.1 Volt DC)snmp.ups.BatteryVoltageThe magnitude of the present battery voltage (0.1 Volt DC).
UPS Battery Current (0.1 Amp DC)snmp.ups.BatteryCurrentThe present battery current (0.1 Amp DC).
UPS Battery Temperature (C)snmp.ups.BatteryTemperatureThe ambient temperature at or near the UPS Battery casing (degrees Centigrade).
ups-input
UPS Input Line Badssnmp.ups.InputLineBads.countA count of the number of times the input entered an out-of-tolerance condition as defined by the manufacturer.
UPS Input Num Linessnmp.ups.InputNumLinesThe number of input lines utilized in this device.
ups-alarm-table
UPS Alarm Timesnmp.ups.alarm.AlarmTimeThe value of sysUpTime when the alarm condition was detected.
system
UPS sys Up Timesnmp.ups.sysUpTimeThe time (in hundredths of a second) since the network management portion of the system was last re-initialized.
ups-bypass-table
UPS Line Bypass Voltagesnmp.ups.line.BypassVoltageThe present bypass voltage (RMS Volts).
UPS Line Bypass Currentsnmp.ups.line.BypassCurrentThe present bypass current (0.1 RMS AMPS).
UPS Line Bypass Powersnmp.ups.line.BypassPowerThe present true power conveyed by the bypass (WATTS).
ups-bypass
UPS Bypass Frequency (0.1 Hertz)snmp.ups.BypassFrequencyThe present bypass frequency (0.1 Hertz).
UPS Bypass Num Linessnmp.ups.BypassNumLinesThe number of bypass lines utilized in this device. This entry indicates the number of rows in the bypass table.
ups-output
UPS Output Frequencysnmp.ups.OutputFrequencyThe present output frequency (0.1 Hertz).
UPS Output Num Linessnmp.ups.OutputNumLinesThe number of output lines utilized in this device. This variable indicates the number of rows in the output table.
Hub
Explore in Dynatrace Hub
Related tags
NetworkSNMPPowers supplyAPCLiebertInfrastructure Observability
