Monitor TIBCO EMS brokers, queues, and topics by collecting health and performance metrics to detect issues and optimize message processing performance. View a custom TIBCO EMS topology in SmartScape with dedicated screens for each entity.
The TIBCO EMS extension detects multiple EMS instances, connects with or without SSL, and collects health and performance data from brokers, queues, and topics. You can filter entities with rules, define custom alerts (for example, for queue buildup), and view a custom topology linked to SmartScape, with dedicated screens for each entity.
The included TIBCO EMS Overview dashboard lets you navigate all created entities. Additional sections appear in monitored hosts and process group instances for broker navigation.
Metrics, prefixed with EMS2, are available in the Data Explorer, and feature sets allow control over which metrics are monitored.
Prerequisites:
dtuser account must be able to execute tibemsadmin, usually installed under TIBCO_HOME/bin.show commands under tibemsadmin.tibemsadmin commands.tibemsadmin and ignore auto discovery.tibemsadmin64 as executable instead of only tibemsadmin.tibemsadmin.no for TCP or yes for SSL. Ensure the correct listener is enabled.yes to capture System Queues.*.*.
These rules monitor any queue or topic. You can add any other set of rules on top of them to make it work like a blacklist, where anything is monitored unless it's explicitly excluded by a preceding rule. Deleting these two default rules and adding only your monitoring rules makes it work like a whitelist, where no queue or topic is included in monitoring unless specified in a monitoring rule. Removing all rules altogether monitors everything as well.When activating your extension using a monitoring configuration, you can limit monitoring to one of the feature sets. To work properly, the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Queue inbound message rate | EMS2.QueueInboundMsgRate | Rate of messages coming in to the queue |
| Queue inbound message size rate | EMS2.QueueInboundMsgSizeRate | Rate of messages coming in to the queue by their size |
| Queue outbound message rate | EMS2.QueueOutboundMsgRate | Rate of messages removed from the queue |
| Queue outbound message size rate | EMS2.QueueOutboundMsgSizeRate | Rate of messages removed from the queue by their size |
| Topic outbound message size rate | EMS2.TopicOutboundMsgSizeRate | Rate of messages removed from the topic by size |
| Topic outbound message rate | EMS2.TopicOutboundMsgRate | Rate of messages removed from the topic |
| Topic inbound message size rate | EMS2.TopicInboundMsgSizeRate | Rate of messages coming in to the topic by size |
| Topic inbound message rate | EMS2.TopicInboundMsgRate | Rate of messages coming in to the topic |
| Instance status | EMS2.BrokerNodeStatus | Status of the broker instance |
| Inbound message count rate | EMS2.BrokerInboundMsgCountRate | Rate of inbound messages |
| Outbound message count rate | EMS2.BrokerOutboundMsgCountRate | Rate of outbound messages |
| Topics count | EMS2.BrokerTopicCount | Number of topics |
| Queues count | EMS2.BrokerQueueCount | Number of queues |
| Clients count | EMS2.BrokerClientCount | Number of clients |
| Sessions count | EMS2.BrokerSessionCount | Number of sessions |
| Producers count | EMS2.BrokerProducerCount | Number of producers |
| Consumers count | EMS2.BrokerConsumerCount | Number of consumers |
| Durables count | EMS2.BrokerDurableCount | Number of durables |
| Pending messages count | EMS2.BrokerPendingMsgCount | Number of pending messages |
| Pending messages size | EMS2.BrokerPendingMsgSize | Size of all pending messages |
| Memory usage | EMS2.BrokerMemoryUsage | — |
| Memory usage in KB | EMS2.BrokerMemoryUsageKB | — |
| Memory pooled | EMS2.BrokerMemoryPooled | — |
| Synchronous storage | EMS2.BrokerSynchronousStorage | — |
| Async storage | EMS2.BrokerAsyncStorage | — |
| Inbound message size rate | EMS2.BrokerInboundMsgSizeRate | Rate of inbound messages by size |
| Outbound message size rate | EMS2.BrokerOutboundMsgSizeRate | Rate of outbound messages by size |
| Storage read size rate | EMS2.BrokerStorageReadSizeRate | — |
| Storage read count rate | EMS2.BrokerStorageReadCountRate | — |
| Storage write size rate | EMS2.BrokerStorageWriteSizeRate | — |
| Storage write count rate | EMS2.BrokerStorageWriteCountRate | — |
| Uptime | EMS2.BrokerUptime | How long the broker has been up for |
| Pending messages | EMS2.DurablePendingMessages | Number of messages pending for this durable |
| Pending messages size | EMS2.DurablePendingSize | Total size of the messages pending for this durable |
| Queue receiver count | EMS2.QueueReceivers | Number of receivers |
| Queue Depth | EMS2.QueueDepth | Number of messages pending in queue |
| Queue pending message size | EMS2.QueueMsgSize | Size of messages pending in queue |
| Queue inbound total messages | EMS2.QueueInboundMsgTotal.count | Total number of incoming messages |
| Queue outbound total messages | EMS2.QueueOutboundMsgTotal.count | Total number of outbound messages |
| Topic message depth | EMS2.TopicMsgDepth | Number of messages pending in topic |
| Topic message Size | EMS2.TopicMsgSize | Size of the messages pending in topic |
Queues, topics, and durables with spaces in their names are not supported by the extension and may cause loss of data.
Message Queues
