Remote Desktop Protocol extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
Gather metrics and gain insights into the performance of user sessions over RDP.
Get started
Overview
The Microsoft Remote Desktop Protocol (RDP) provides remote display and input capabilities over network connections for Windows-based applications running on a server. RDP is designed to support different types of network topologies and multiple LAN protocols. RDP also forms the basis for enterprise level solutions like Azure Virtual Desktop (formerly Windows Virtual Desktop), a desktop and app virtualization service that runs on the cloud.
This extension is designed to run on RDP session hosts, alongside the OneAgent. It leverages Windows Event Logs and Performance Counters to gather details about ongoing RDP sessions, providing insights into sessions performance as well as the health of the session host. The data gathered is represented in Dynatrace as Real User Monitoring (RUM) Sessions and Actions, or Metrics.
This is intended for users who:
  • Manage the infrastructure responsible for delivering virtual desktops to their users over RDP
  • Want to understand the performance of the RDP protocol and health of their session hosts
  • Need insights into the dynamics of user activity in remote desktop environments
This extension enables you to:
  • Track basic RDP activity for users across different session hosts
  • Monitor the Network and Graphics performance of the RDP protocol on session hosts
  • Correlate poor user experience with insufficiencies in client, server, or network resources
Use cases
  • Network Performance - is the user accessing the remote host over a slow network? does the client have enough bandwidth? is the session host skipping frames due to network insufficiencies?
  • Graphics Performance - what is the frame quality of the user's session? does the session host skip frames due to network, client, or server insufficiencies? is frame encoding taking the appropriate amount of time?
  • Input Delays - is the RDP kernel registering delays from when the user interacted with an application until the application reacted to that input?
  • Capacity - are active users being impacted by large amounts of inactive sessions holding resources on the host? is your session host clearing these appropriately?
  • Security - is there a large amount of failed logins to the hosts? what are the accounts that result in authentication failures, and for what reason?
Requirements
Install OneAgent
Install OneAgent on your session hosts. Infrastructure-only mode is sufficient for this extension to function correctly.
Enable access to Windows Event Logs on Windows hosts
The extension requires access to programmatically read Windows Event Logs.
  1. Enabling access for Operational logs is done through the Windows registry. Navigate to the Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog location using a tool like regedit and ensure the following keys are present:
    • Microsoft-Windows-TerminalServices-RemoteConnectionManager/Operational
    • Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
    • Microsoft-Windows-RemoteDesktopServices-RdpCoreTS/Operational
    • Microsoft-Windows-RemoteDesktopServices-RdpCoreCDV/Operational
    The name of the key (folder) must be exactly like in the above list. It does not represent nested folders.
Setup steps using regedit
  1. Open regedit.exe from the Windows Start menu
  2. Navigate to the path Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog
  3. Inspect keys in the EventLog key
  4. If the keys mentioned above are not present, right-click the EventLog key to open the context menu
  5. Hover over New in the context menu, and select Key
  6. Rename the newly created key to one of the required keys
  7. Repeat steps 5 & 6 until all keys are present as shown in the below screenshot
EventLog Registry Entry in Regedit
  1. Enabling access for the Security log is done for individual accounts (using SID notation). This is most easily done using the wevtutil command. Run the following command from a terminal:
    wevtutil sl Security "/ca:O:BAG:SYD:(A;;0x1;;;S-1-5-32-573)(A;;0x1;;;S-1-5-20)(A;;0x1;;;S-1-5-11)"
    This enables read access to the log for the Authenticated Users (S-1-5-11), Network Service (S-1-5-20), and Event Log Readers (S-1-5-32-573) accounts.
Validate the setup of Windows Event Logs
After following the setup instructions, you can run the get-eventlog -List command from a Powershell terminal. The output will list all logs available for reading in an output similar to this:
Max(K) Retain OverflowAction Entries Log
20,480 0 OverwriteAsNeeded 136 Application
512 7 OverwriteOlder 0 Microsoft-Windows-RemoteDesktopServices-RdpCoreCDV/Operational
512 7 OverwriteOlder 334 Microsoft-Windows-RemoteDesktopServices-RdpCoreTS/Operational
512 7 OverwriteOlder 55 Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
512 7 OverwriteOlder 85 Microsoft-Windows-TerminalServices-RemoteConnectionManager/Operational
20,480 0 OverwriteAsNeeded 769 Security
20,480 0 OverwriteAsNeeded 1,026 System
Ensure that all logs are listed in the Log column, and all of them have a value greater than zero in the Entries column.
Compatibility information
Minimum supported OneAgent version: 1.280
Supported RDP clients:
  • Direct RDP connections (mstsc.exe)
  • Windows App
Session Input Delay and Process Input Delay are only supported for Windows Server 2019, or Windows 10 (1809), or later.
Activation and setup
After adding the extension to your environment, its monitoring configuration offers a few options for configuring its behavior, specifically around Real User Monitoring.
If the extension should create User Sessions and Actions, you must enable Report RUM data. Once this is enabled, the following options appear:
  • Application ID - the ID of a Custom Application for reporting the collected data
  • Detect Beacon URL
    • If enabled, the extension will attempt to read the OneAgent configuration files and detect a suitable URL for initializing the OpenKit framework and sending the RUM data through it.
    • If disabled, you must specify the RUM Beacon URL using the Beacon URL field.
  • Reduce DEM consumption - for long running sessions (> 30 min.), this option will reduce the amount of "Network Performance", "Graphics Performance", and "Session Input Delay" user actions (normally reported every minute) in order to reduce the amount of licenses utilized (1 session is consumed every 200 actions).
Opting in/out for metrics is done through the extension's feature sets, which are seen on the last step of the configuration process.
FAQ
How do I find my Beacon URL and Custom Application ID?
After creating a Custom Application, open its detail page, click the ... button, then select Edit. On the page that opens, navigate to Instrumentation wizard and find these details listed as Application ID and Beacon URL
I'm missing Session Input Delay and Process Input Delay data, what should I do?
While we noticed it happen particularly with Session and Process Input Delay performance counters, it is a known issue that Microsoft Performance Counters may break and require rebuilding.
Following Microsoft's guide, run the following commands as Administrator:
lodctr /R
WINMGMT.EXE /RESYNCPERF
Get-Service -Name "pla" | Restart-Service -Verbose
Get-Service -Name "winmgmt" | Restart-Service -Force -Verbose
Feature sets
Metric nameMetric keyDescription
Encoding timerdp.graphics.encoding_timeThe average time spent encoding frames. For RDP encoding time should be under 33 milliseconds.
Frame qualityrdp.graphics.frame_qualityThe quality of the output frame represented as a percentage of the quality of the source frame.
Frames skipped (client)rdp.graphics.frames_skipped_clientThe number of frames skipped per second due to insufficient client resources
Frames skipped (network)rdp.graphics.frames_skipped_networkThe number of frames skipped per second due to insufficient network resources
Frames skipped (server)rdp.graphics.frames_skipped_serverThe number of frames skipped per second due to insufficient server resources
Network performance
Base TCP RTTrdp.network.base_tcp_rttBase TCP round-trip time (RTT) detected in milliseconds
Base UDP RTTrdp.network.base_udp_rttBase UDP round-trip time (RTT) detected in milliseconds
Current TCP RTTrdp.network.current_tcp_rttCurrent TCP round-trip time (RTT) detected in milliseconds
Current UDP RTTrdp.network.current_udp_rttCurrent UDP round-trip time (RTT) detected in milliseconds
TCP bandwidthrdp.network.tcp_bandwidthCurrent TCP bandwidth detected in bits per second (bps)
UDP bandwidthrdp.network.udp_bandwidthCurrent UDP bandwidth detected in bits per second (bps)
Loss raterdp.network.loss_rateThe number of packets lost in transmission, expressed as a percentage of all packets.
Retransmission raterdp.network.retransmission_rateThe number of packets retransmitted due to loss or damage, expressed as a percentage of all packets
default
Total sessionsrdp.terminal.total_sessionsThe total number of RDP Sessions on the host. This includes both active and inactive sessions.
Terminal sessions
Active sessionsrdp.terminal.active_sessionsThe number of Active RDP Sessions on the host. Active Sessions are actively being used by users logged onto their Virtual Desktop.
Inactive sessionsrdp.terminal.inactive_sessionsThe number of Inactive RDP Sessions on the host. Inactive Sessions are not currently being used by users but have not been terminated, users still being able to resume.
Active usersrdp.terminal.active_usersThe number of Active Users on the RDP Host. Active Users are actively logged onto their Virutal Desktops.
Login failuresrdp.terminal.login_failures_countThe number of failed login attempts along with failure details.
Input delay
Session input delayrdp.session_input_delayThe longest time it takes for an input (user click/keypress) to reach the application inside an RDP session. The value is reported per session.
Process input delayrdp.process_input_delayThe longest time it takes for an input (user click/keypress) to reach the application inside an RDP session. The value is reported per process.
Hub
Explore in Dynatrace Hub
Related tags
ComputePythonConnectivityMicrosoftInfrastructure Observability
