Radware Alteon Load Balancer extension (Dynatrace Classic) Dynatrace Classic Extension Updated on Nov 16, 2026 Monitor your Radware Alteon Network Load Balancer devices and interfaces through SNMP.
Get started Overview This extension collects infrastructure metrics to monitor the health and performance of your Radware Alteon Load Balancer devices.
Use cases Monitor important device metrics such as uptime, CPU and memory usage, as well as additional hardware status metrics for temperature, fan, and power supply. Monitor device interfaces to report metrics including bytes, discards, and inbound and outbound errors. Collect additional device data, including virtual server utilization, HTTP and SSL statistics, throughput, and session counts. The full list of monitored metrics can be viewed under Feature Sets . Detect device anomalies and avoid outages. SNMP v2c or SNMP v3 Dynatrace version 1.318+ Activation and setup Activate the extension in your environment using the in-product Hub, provide the necessary device configuration, and you're all set up.
For details, see the SNMP extension data source documentation .
Details The extension package contains:
SNMP Data Source configuration Overview dashboard (Classic & Platform) Unified analysis screens Custom topology types extracted from metric dimensions:
Radware Alteon Device Radware Alteon Interface
SNMP MIB files used for monitoring:
IF-MIB ALTEON-CHEETAH-LAYER4-MIB ALTEON-CHEETAH-NETWORK-MIB ALTEON-CHEETAH-SWITCH-MIB ALTEON-ROOT-MIB
Licensing and costs There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Radware Alteon Load Balancer extension ingests custom metrics, which consume Davis Data Units (DDUs) .
Calculations are based on the assumption that you monitor all metrics for every feature set every minute. Metric data points per minute per device:
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
Dynatrace classic license In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events .
Feature sets Advanced interfaces — com.dynatrace.extension.network_device.if.lastchange —
Interfaces — com.dynatrace.extension.network_device.if.bytes_in.count — — com.dynatrace.extension.network_device.if.bytes_out.count — — com.dynatrace.extension.network_device.if.in.discards.count — — com.dynatrace.extension.network_device.if.out.discards.count — — com.dynatrace.extension.network_device.if.in.errors.count — — com.dynatrace.extension.network_device.if.out.errors.count —
SSL_Statistics_Virtual TCP sessions using SSL service radware_alteon.sslslbstat.cursessions The current number of different TCP sessions using SSL service. Total TCP sessions using SSL service radware_alteon.sslslbstat.totalsessions.count The total number of different TCP sessions using SSL service. TCP sessions using SSL service high water mark radware_alteon.sslslbstat.highestsessions.count The high water mark of current sessions of different TCP sessions using SSL service. SSL handshakes between clients and AAS per second radware_alteon.ssloff.newhandShake New SSL handshakes between clients and AAS per second. New SSL handshakes between Clients and AAS per second (sslOffPerEnhServNewhandShake) radware_alteon.ssloffper.enh.serv.newhandshake Number of New SSL handshakes between Clients and AAS per second for this virtual service. Number of expired SSL certificates per second for virtual service (sslOffPerEnhServExpiredCertificates) radware_alteon.ssloffper.enh.serv.expiredcertificates Number of expired SSL certificates per second for virtual service.
Hardware_Status_Physical Temperature sensor status radware_alteon.temperature.status The status of the temperature sensor. ok(1), exceed(2) Temperature warning threshold radware_alteon.temperature.threshold.warning The temperature warning threshold Temperature shutdown threshold radware_alteon.temperature.threshold.shutdown The temperature shutdown threshold Hardware fan status radware_alteon.fan.status Hardware fan status. ok(1), fail(2), unplug(3) Powersupply status radware_alteon.powersupply.status Powersupply status. singlePowerSupplyOk(1), firstPowerSupplyFailed(2), secondPowerSupplyFailed(3), doublePowerSupplyOk(4), unknownPowerSupplyFailed(5)
High_Availability_Physical High availability (HA) service group state radware_alteon.ha.group.state High availability (HA) service group state High availability (HA) mode radware_alteon.ha.curcfg.mode High availability (HA) mode
default — com.dynatrace.extension.network_device.sysuptime — — com.dynatrace.extension.network_device.cpu_usage — — com.dynatrace.extension.network_device.memory_total — — com.dynatrace.extension.network_device.memory_free — — com.dynatrace.extension.network_device.memory_used — — com.dynatrace.extension.network_device.if.status —
Software_Status_SP SP CPU utilization com.dynatrace.extension.network_device.sp.cpu_usage SP CPU utilization
Session_Table_Utilization_Virtual Session table maximum entries radware_alteon.slbstat.maint.maximumsessions The maximum number entries in the session table. Ipv6 session count radware_alteon.slbstat.maint.ip6currsessions.count The number of sessions for ipv6. Curent sessions in session table radware_alteon.slbstat.maint.curbindings The current number of sessions in the session table.
Backend_Server_Utilization_Virtual Real-server current sessions radware_alteon.slbstat.enh.rserver.currsessions Real-server current sessions. Real-server total sessions radware_alteon.slbstat.enh.rserver.totalsessions Real-server total sessions. Real-server highest sessions radware_alteon.slbstat.enh.rserver.highestsessions Real-server highest sessions. Real-server total rx/tx octets radware_alteon.slbstat.enh.rserver.hc.octets Real-server total rx/tx octets. Real server max concurrent connections radware_alteon.slbcur.cfg.realserver.maxconns The Maximum allowed number of concurrent connections per real server in the configuration. SP current memory radware_alteon.spmemusagestats.currentmemory The current memory of SP in kilobytes. Real-server group current sessions radware_alteon.slbstat.enh.group.currsessions The number of sessions that are currently handled by the real server group. Real-server group total sessions radware_alteon.slbstat.enh.group.totalsessions The total number of sessions that have been handled by the real server group. Real-server group highest sessions radware_alteon.slbstat.enh.group.highestsessions The highest sessions that have been handled by the real server group.
Virtual_Server_Utilization_Virtual Virtual server current sessions radware_alteon.slbstat.enh.vserver.currsessions The number of sessions that are currently handled by the virtual server. Virtual server total sessions radware_alteon.slbstat.enh.vserver.totalsessions The total number of sessions that are handled by the virtual server. Virtual server highest sessions handled radware_alteon.slbstat.enh.vserver.highestsessions The highest number of sessions that have been handled by the virtual server. Total octets received and transmitted by the virtual server radware_alteon.slbstat.enh.vserver.hc.octets The total octets received and transmitted by the virtual server. Sessions handled by the virtual server radware_alteon.slbstat.enh.vserver.sessions Number of Sessions handled by the virtual server per second. Real server runtime status per virtual server radware_alteon.slbstat.enh.vserver.real.status The runtime Real Server Status per Virtual service. (0)Up, (1)Down, (2)Admin-Down, (3)Warning, (4)Shutdown, (5)Error Backend server concurrent connections for virtual service radware_alteon.commng.enh.perservstats.servconn The number of concurrent backend server connections for virtual service. Virtual service client requests passed to AX radware_alteon.commng.enh.perservstats.clireq Number of client requests passed to AX for virtual service. Virtual service security policy peak bandwidth (secPolPerServBwPeak) radware_alteon.secpol.perserv.bw.peak Virtual service security policy stats - Bandwidth peak value. Virtual service security policy bandwidth ( secPolPerServBwCurVal) radware_alteon.secpol.perserv.bw.curval Virtual service security policy stats - Bandwidth current value. Virtual service security policy PPS current (secPolPerServPPSCurVal) radware_alteon.secpol.perserv.pps.curval Virtual service security policy stats - PPS current value. Virtual service security policy PPS peak (secPolPerServPPSPeak) radware_alteon.secpol.perserv.pps.peak Virtual service security policy stats - PPS peak value. Virtual service security policy CPS current (secPolPerServCPSCurVal) radware_alteon.secpol.perserv.cps.curval Virtual service security policy stats - CPS current value. Virtual service security policy CPS peak (secPolPerServCPSPeak) radware_alteon.secpol.perserv.cps.peak Virtual service security policy stats - CPS peak value. Virtual service security policy latency current (secPolPerServLatencyCurVal) radware_alteon.secpol.perserv.latency.curval Virtual service security policy stats - latency current value. Virtual service security policy latency peak (secPolPerServLatencyPeak) radware_alteon.secpol.perserv.latency.peak Virtual service security policy stats - latency peak value.
Per_Device_HTTP_Statistics_Virtual HTTP 2.0 connection count radware_alteon.httpstatsumm.http20connection.count HTTP 2.0 connection count. HTTP 1.1 connection count radware_alteon.httpstatsumm.http11connection.count HTTP 1.1 connection count. HTTP 1.0 connection count radware_alteon.httpstatsumm.http10connection.count HTTP 1.0 connection count. HTTP 2.0 connection peak count radware_alteon.httpstatsumm.http20connection.peak.count HTTP 2.0 connection peak count. HTTP 1.1 connection peak count radware_alteon.httpstatsumm.http11connection.peak.count HTTP 1.1 connection peak count. HTTP 1.0 connection peak count radware_alteon.httpstatsumm.http10connection.peak.count HTTP 1.0 connection peak count. HTTP 2.0 request count radware_alteon.httpstatsumm.http20connection.request.count HTTP 2.0 request count. HTTP 1.1 request count radware_alteon.httpstatsumm.http11connection.request.count HTTP 1.1 request count. HTTP 1.0 request count radware_alteon.httpstatsumm.http10connection.request.count HTTP 1.0 request count. HTTP transactions per second radware_alteon.httptranssumm.trans.rate HTTP transactions per second.
Throughput_Physical_Virtual Peak throughput of ports radware_alteon.peakthroughputusage.count Peak throughput of ports in bits per second. Current throughput of ports radware_alteon.curthroughputusage.count Current throughput of ports in bits per second.
