HPE H3C Switch extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
Monitor your HPE H3C switches using SNMP.
Get started
Overview
The HPE H3C extension leverages SNMP to gather performance and health metrics from your H3C switches every minute.
Use cases
  • Quickly identify problematic interfaces that are dropping or corrupting packets.
  • Pinpoint hardware faults, misconfigurations or congestion issues affecting performance or reliability.
  • Track real-time and historical bandwidth usage to understand traffic patterns.
  • Monitor memory consumption on H3C switches to detect potential leaks or resource exhaustion.
Compatibility information
  • SNMP v2c or SNMP v3
  • Dynatrace version: 1.310 or higher
  • ActiveGate version: 1.310 or higher
Activation and setup
Activate the extension in your environment Web UI using the Dynatrace Hub. Provide the necessary device configuration, and Dynatrace will automatically deploy the extension and begin monitoring.
For more details, see Manage SNMP extensions (Dynatrace Classic).
Details
The extension package contains:
  • SNMP data source configuration for metric ingestion
  • Topology definitions for HPE H3C switches
  • Dashboards offering monitoring overviews
  • Infrastructure & Operations entries for each created entity
The extension is built on top of the SNMP data source that is part of the Dynatrace Extensions framework. For more details, see Extensions.
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The HPE H3C Switch extension ingests custom metrics, which consume Davis Data Units (DDUs).
Calculations are based on the assumption that you monitor all metrics for every feature set every minute. Metric data points per minute per switch:
4 + (8 * n_interfaces)
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
Dynatrace classic license
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
Feature sets
Advanced interfaces
Metric nameMetric keyDescription
—com.dynatrace.extension.network_device.if.in.multicast_pkts.count—
—com.dynatrace.extension.network_device.if.out.multicast_pkts.count—
—com.dynatrace.extension.network_device.if.in.broadcast_pkts.count—
—com.dynatrace.extension.network_device.if.out.broadcast_pkts.count—
—com.dynatrace.extension.network_device.if.in.ucast_pkts.count—
—com.dynatrace.extension.network_device.if.out.ucast_pkts.count—
default
—com.dynatrace.extension.network_device.sysuptime—
—com.dynatrace.extension.network_device.cpu_usage—
Used memorycom.dynatrace.extension.network_device.hp_switch.memory_usedThe amount of memory, in bytes, used by the HP Switch device
Total memorycom.dynatrace.extension.network_device.hp_switch.memory_totalThe amount of memory, in bytes, available on the HP Switch device
—com.dynatrace.extension.network_device.if.status—
Interfaces
—com.dynatrace.extension.network_device.if.bytes_in.count—
—com.dynatrace.extension.network_device.if.bytes_out.count—
Inbound errorscom.dynatrace.extension.network_device.if.in.errors.countNumber of inbound packets/transmission units with errors
Inbound discardscom.dynatrace.extension.network_device.if.in.discards.countNumber of inbound packets discarded
Outbound errorscom.dynatrace.extension.network_device.if.out.errors.countNumber of outbound packets/transmission units with errors
Outbound discardscom.dynatrace.extension.network_device.if.out.discards.countNumber of outbound packets discarded
—com.dynatrace.extension.network_device.if.lastchange—
Interface speedcom.dynatrace.extension.network_device.if.speedSpeed of the network interface in MegaBits per second.
Hub
Explore in Dynatrace Hub
Related tags
NetworkSNMPSwitches/RoutersHewlett PackardInfrastructure Observability
