Connection Pools WebSphere Liberty extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
  • Published Oct 27, 2025
Collect the connection pool performance, usage and availability metrics for Websphere Liberty.
Get started
Overview
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Use cases
This extension collects connection pool performance, usage and availability metrics for Websphere Liberty.
Compatibility information
  • Websphere process that runs on a supported Linux or Windows operating system.
  • OneAgent version 1.273+
  • Dynatrace version 1.273+
Activation and setup
  1. Install OneAgent on the virtual machine or server of your Websphere process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the Liberty Connection Pool Overview dashboard.
Feature sets
Connection count
Metric nameMetric keyDescription
Managed connectionsliberty.connectionPool.managedConnectionCount—
In use connectionsliberty.connectionPool.connectionHandleCount—
Free connectionsliberty.connectionPool.freeConnectionCount—
Timing
In use timeliberty.connectionPool.inUseTime—
Wait timeliberty.connectionPool.waitTime—
Hub
Explore in Dynatrace Hub
Application server method of pooling and sharing connections to a database.
Related tags
ApplicationJMXConnection poolIBMInfrastructure Observability
