Connection Pools WebSphere extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
  • Published Sep 01, 2026
Monitor IBM WebSphere Application Server connection pools with usage, performance, and availability metrics for both legacy and J2C pools.
Spot connection pool exhaustion and contention before they slow your applications.
Get started
Overview
The Connection Pools WebSphere extension collects connection pool metrics from IBM WebSphere Application Server through the Performance Monitoring Infrastructure (PMI). The extension reads both the legacy connection pool module and the J2C (Java EE Connector Architecture) connection pool module. You get a single view of pool behavior across every WebSphere instance that OneAgent monitors.
Connection pools are critical to application performance. When a pool runs out of connections or falls under contention, threads queue for an available connection, and your applications experience increased latency and failures. The extension surfaces the key indicators of pool health, so you can manage capacity proactively and diagnose contention before it reaches your users.
Several OneAgent extensions provide insight into connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Use cases
  • Identify pools that approach capacity by tracking pool utilization, pool size, and free pool size.
  • Detect thread contention by monitoring the number of threads that wait for a connection.
  • Pinpoint bottlenecks in database connection management with connection wait time and in-use time.
  • Monitor legacy WebSphere connection pool modules and J2C connection pool modules from a single extension.
  • Correlate pool behavior with the process and host that run WebSphere to isolate the source of an issue.
Compatibility information
  • WebSphere Application Server process that runs on a supported Linux or Windows operating system.
  • Dynatrace version 1.341+
  • Supports the legacy connection pool module (connectionPoolModule) and the J2C connection pool module (j2cModule).
Activation and setup
  1. Install OneAgent on the virtual machine or server of your WebSphere process.
  2. Activate the OneAgent feature Enable Java PMI Extensions 2.0.
  3. In Dynatrace Hub, open the Connection Pools WebSphere tile and select Add to environment.
  4. Open the WebSphere Connection Pool Overview dashboard.
Details
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Connection Pools WebSphere extension ingests custom metrics, which consume Davis Data Units (DDUs).
This extension queries for data every minute. To estimate the number of metric data points produced by your extension configuration, use the following list that gives you a number of metrics per feature set and a multiplier value depending on which entity the metric is split by. Sum these values to get the total data points per minute.
  • Connection Pool (legacy) 6 x number of WebSphere connection pools
  • Connection Pool (j2c) 6 x number of J2C connection pools
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
Dynatrace classic license
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that the extension triggers. For more information, see DDU events.
Feature sets
Metric nameMetric keyDescription
Percent Usedwebsphere.connection_pool.percent_usedPercentage of the connection pool that is currently in use
Pool Sizewebsphere.connection_pool.pool_sizeTotal size of the connection pool
Free Pool Sizewebsphere.connection_pool.free_pool_sizeNumber of free connections available in the connection pool
Wait Timewebsphere.connection_pool.wait_timeAverage time in milliseconds spent waiting for a connection from the pool
In Use Timewebsphere.connection_pool.use_timeAverage time in milliseconds a connection is held in use before being returned to the pool
Waiting Threadswebsphere.connection_pool.waiting_threadsNumber of threads waiting for a connection from the pool
Hub
Explore in Dynatrace Hub
Related tags
ApplicationPMIConnection poolIBMInfrastructure Observability
