Connection Pools WebLogic extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
Collect the connection pool performance, usage and availability metrics for Oracle Weblogic.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Get started
Overview
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Apache Commons.
Use cases
  • Collect the connection pool performance, usage and availability metrics for Oracle Weblogic.
Compatibility information
  • Oracle Weblogic process that runs on a supported Linux or Windows operating system.
  • OneAgent version 1.273+
  • Dynatrace version 1.273+
Activation and setup
  1. Install OneAgent on the virtual machine or server of your Oracle Weblogic process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select Add to environment in the same tile to configure the extension.
  4. Open the Weblogic Connection Pool Overview dashboard.
Details
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Connection Pools WebLogic extension ingests custom metrics, which consume Davis Data Units (DDUs).
License consumption is based on the number of connection pools and server runtimes. The following formula provides approximate metric data points ingested per minute with all feature sets enabled. Note that this is only an approximation as the true numbers will depend heavily on the traffic you experience.
(22 * # of WebLogic Connection Pools and Server Runtimes) + (1 * # of WebLogic Connection Pools and Config Paths) + (3 * # of WebLogic Connection Pools, Server Runtimes, and JMS Server Runtimes) + (2 * # of Server runtimes)
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
Dynatrace classic license
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
Feature sets
cache
Metric nameMetric keyDescription
Statement cache sizeweblogic.connectionPool.prepStmtCacheCurrentSize—
Statement cache hitsweblogic.connectionPool.prepStmtCacheHitCount.count—
Statement cache missesweblogic.connectionPool.prepStmtCacheMissCount.count—
Threading
Stuck thread countweblogic.stuckThreads—
Hogging thread countweblogic.hoggingThreads—
connections
Active connectionsweblogic.connectionPool.activeConnectionsCurrentCount—
Current capacityweblogic.connectionPool.currCapacity—
Leaked connectionsweblogic.connectionPool.leakedConnectionCount.count—
Available connections (idle)weblogic.connectionPool.numAvailable—
Waiting for connectionsweblogic.connectionPool.waitingForConnectionCurrentCount—
Failed connection requestsweblogic.connectionPool.failedReserveRequestCount.count—
Reconnection failuresweblogic.connectionPool.failuresToReconnectCount.count—
Requests for connectionsweblogic.connectionPool.reserveRequestCount.count—
Messaging
Current message countweblogic.currentMessages—
Pending message countweblogic.pendingMessages—
Total message countweblogic.totalMessages—
capacity
Max capacityweblogic.connectionPool.maxCapacity—
Hub
Explore in Dynatrace Hub
Application server method of pooling and sharing connections to a database.
Related tags
ApplicationJMXConnection poolOracleInfrastructure Observability
