Connection Pools JBoss extension (Dynatrace Classic)
  • Dynatrace Classic
  • Extension
Collect the connection pool performance, usage and availability metrics for JBoss, identify potential issues with the utilization of the connection pool, and monitor both Non-XA and XA connection pools.
Get started
Overview
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Use cases
  • Collect the connection pool performance, usage and availability metrics for JBoss.
  • Identify potential issues with the connection pool utilization.
  • Monitor both Non-XA and XA connection pools.
Compatibility information
  • Jboss process that runs on a supported Linux or Windows operating system.
  • Enabled statistics for JBoss EAP 6 / Application Server 7 and later.
  • OneAgent version 1.273+
  • Dynatrace version 1.273+
Activation and setup
  1. Install OneAgent on the virtual machine or server of your JBoss process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the JBoss Connection Pool Overview dashboard.
Details
This extension package contains :
  • JMX data source configuration for metric ingestion.
  • Topology and relationship definitions for JBoss Connection Pools and JBoss XA Connection Pools, as well as relationship definitions for connection pools and process group instances.
  • A dashboard offering a monitoring overview of JBoss Connection Pools.
  • A unified analysis page for each entity.
This extension is built on top of the new Extension 2.0 Framework.
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Connection Pools JBoss extension ingests custom metrics, which consume Davis Data Units (DDUs).
This extension queries for data every minute. To estimate the amount of metric datapoints produced by your extension configuration, use the following list which gives you a number of metrics per feature set and a multiplier value depending on the number of connection pools being monitored. Add all of these up, and you will have the number of datapoints produced every minute.
  • Connection pool time XA: 9 x number of connection pools.
  • Connection pool XA: 5 x number of connection pools.
  • Connection pool: 5 x number of connection pools.
  • Connection pool time: 9 x number of connection pools.
For example, a monitoring configuration that contains one connection pool where all feature sets are activated produces 28 metric datapoints per minute.
Since JMX Extensions run on OneAgent-monitored hosts, they are subjected to included metrics per host unit. For details, see Classic Licensing | Included metrics per host unit.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
For the example above: 28 * 60 * 24 * 365 = 14,716,800 metric data points per year.
Dynatrace classic license
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For the example above: 28 * 60 * 24 * 365 * 0.001 = 14,716.8 DDUs per year.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
FAQ
  • To troubleshoot this extension, use the guide(s) in the Dynatrace Community.
Feature sets
Connection pool
Metric nameMetric keyDescription
Max pool sizejboss.connectionPool.maxPoolSize—
Active countjboss.connectionPool.ActiveCount—
Available countjboss.connectionPool.AvailableCount—
Created countjboss.connectionPool.CreatedCount.count—
Destroyed countjboss.connectionPool.DestroyedCount.count—
Idle countjboss.connectionPool.IdleCount—
In use countjboss.connectionPool.InUseCount—
Timed outjboss.connectionPool.TimedOut.count—
Wait countjboss.connectionPool.WaitCount.count—
Total blocking timejboss.connectionPool.TotalBlockingTime.count—
Total creation timejboss.connectionPool.TotalCreationTime.count—
Total pool timejboss.connectionPool.TotalPoolTime.count—
Total get timejboss.connectionPool.TotalGetTime.count—
Total usage timejboss.connectionPool.TotalUsageTime.count—
Total blocking time (XA)jboss.connectionPool.TotalBlockingTimeXA.count—
Total get time (XA)jboss.connectionPool.TotalGetTimeXA.count—
Total creation time (XA)jboss.connectionPool.TotalCreationTimeXA.count—
Total usage time (XA)jboss.connectionPool.TotalUsageTimeXA.count—
Total pool time (XA)jboss.connectionPool.TotalPoolTimeXA.count—
Connection pool XA
Max pool size (XA)jboss.connectionPool.maxPoolSizeXA—
Active count (XA)jboss.connectionPool.ActiveCountXA—
Available count (XA)jboss.connectionPool.AvailableCountXA—
Created count (XA)jboss.connectionPool.CreatedCountXA.count—
Destroyed count (XA)jboss.connectionPool.DestroyedCountXA.count—
Idle count (XA)jboss.connectionPool.IdleCountXA—
In use count (XA)jboss.connectionPool.InUseCountXA—
Timed out (XA)jboss.connectionPool.TimedOutXA.count—
Wait count (XA)jboss.connectionPool.WaitCountXA.count—
Hub
Explore in Dynatrace Hub
Application server method of pooling and sharing connections to a database.
Related tags
ApplicationJMXConnection poolRed HatInfrastructure Observability
