SAP GUI and ABAP Platform extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor your SAP Application Server's user transactions, RFC, and jobs.
Get started
Overview
Monitor SAP ABAP platforms remotely via Dynatrace, analyzing key metrics and response times.
This extension queries SAP servers for key performance counters. The collected metrics are analyzed in Dynatrace, using ABAP platform health indicators including response time breakdowns of the response times between ABAP-specific application server activities, tasks, and database interaction, as adviced by the SAP expert community’s established best-practices.
Requirements
  • You have an environment ActiveGate with Dedicated Performance Profile.
    • Make sure the ActiveGate size is appropriate, especially if you configure several configurations which poll from a single ActiveGate. A monitoring configuration to an SAP application server with production load can consume up to 0.5 CPU cores and 1.5 GB RAM on the ActiveGate.
    • When setting up the dedicated profile, the RUM Beacon Forwarder is disabled by default. You must change the ActiveGate's custom.properties file as follows to turn it on.
      [beacon_forwarder]
      beacon_forwarder_enabled = true
  • You have SAP Java Connector on the ActiveGate host. To learn how to configure it, see SAP Java Connector configuration.
  • The ActiveGate requires remote access to the SAP application server (AS ABAP) over RFC protocol.
  • If the endpoint is configured to poll all clustered instances, the ActiveGate requires remote access to all the SAP AS instances.
  • A user account that has permission to execute the following monitoring functions
    Authorization ObjectDetails
    S_RFC
    • Activity: 16
    • RFC Type: FUNC
    • RFC Name:
      • /SDF/GET_DUMP_LOG
      • GET_SYSTEM_TIME_REMOTE
      • SWNC_GET_WORKLOAD_SNAPSHOT
      • TH_SERVER_LIST
      • TH_USER_LIST
      • RFC_METADATA_GET
      • RFCPING
      • RFC_GET_FUNCTION_INTERFACE
      • DDIF_FIELDINFO_GET
      • RFC_READ_TABLE
    /SDF/E2E
    • Activity: 03
    S_RZL_ADM
    • Activity: 03
    S_TOOLS_EX
    • AUTH: S_TOOLS_EX_A
    S_TCODE
    • TCD: SM51
    S_TABU_NAM
    • ACTVT: 03
    • TABLE: TBTCO
Compatibility information
SAP NetWeaver ABAP release 7.31+
Activation and setup
Activate the extension in your environment using the in-product Hub. Provide the necessary configuration and you’re all set up.
Details
Configure the SAP Java Connector on the ActiveGate host
  1. Download the 64-bit version of the SAP Java Connector to the ActiveGate.
  2. Place the sapjco3.jar file into the JCo folder, as configured below when adding a new monitoring endpoint (step 7 in extension installation).
  3. Depending on the OS running on the ActiveGate host, place sapjco3.dll (Windows) or libsapjco3.so (Linux) into the JCo directory.
  4. Make sure that the user account executing the plugin is permitted to read from the JCo folder.
  5. Windows only Make sure that the Windows-based ActiveGate host has the Visual C++ Redistributable Packages for Visual Studio 2013 installed. The SAP Java Connector depends on it.
Configuration Details
SettingDetails
Connect to SAP viaConnect directly to an SAP application server or via a message server. Once the list of SAP application servers is collected, the extension connects directly to the servers. If the message server is down, the availability of the SAP application servers behind the message server will not be collected. To detect and configure alerting for such a state, set up a missing data alert custom event that alerts on the condition if data is missing.
SAP Application Server AddressThe IP or host name of the SAP application server. Not used when connecting via a message server.
Instance IDThe instance ID to connect to (this is a numeric, two digit value). Not used when connecting via a message server.
System IDThe system ID to connect to. Only used when connecting via a message server.
Message Server Host Name or AddressThe IP or host name of the message server. Only used when connecting via a message server.
Message server port numberThe port that the message server is listening on. Only used when connecting via a message server.
Group/serverThe group/server configured on the message server. Only used when connecting via a message server.
Keystore pathPath to keystores if required for the connection, defined as SECUDIR.
UsernameThe username for the account connecting to the SAP application server.
PasswordThe password for the account.
Client NumberThe client number to use for the connection.
Poll all Clustered SAP InstancesInstead of creating one endpoint per SAP instance, this option polls all clustered SAP instances at once.
Use 'SAP Application Server Address' as the Application Server NameInstead of the entity using the name returned by the application server instance, use the value entered in SAP application server address. Not possible when Poll all Clustered SAP Instances is enabled.
Path to a JCo Destination Fileoptional If a specific destination file is required to connect to the SAP server, enter the path here. This will override all of the above settings except for the keystore path.
SAP JCo folderThe folder containing the sapjco3.jar and the native Java Connector file.
Task types to report onList of task types to report on, the rest will be combined. The possible task types are: NONE, DIALOG, UPDATE, SPOOL, BCKGRD, ENQUEUE, BUF.SYN, AUTOABA, UPDATE2, NATIVE_RFC, PLUGIN, AUTOTH, RPCTH, RFCVMC, DDLOGCLEANUP, DEL.THCALL, AUTOJAVA, LICENCESRV, AUTOCCMS, MSADM, SYS_STARTUP, BGRFCSDL, BGRFC, APC, OTHERS, DINOGUI, B.INPUT, HTTP, HTTPS, NNTP, SMTP, FTP, LCOM, HTTP/JSP, HTTPS/JSP, AUTO_RFC, WS-RFC, WS-HTTP, ESI, ALE, RFC and CPIC
Report User SessionsSelect this to create user sessions and user actions based on the customer-executed Tcodes. This functionality requires a custom application to be created.
The Application ID of the custom applicationTo create user sessions, fill in the Application ID you are prompted with after creating the custom application.
Inactivity time out (in minutes) when capturing user sessionsEnter a number between 5 and 25, default is 25.
Capture Usernames as part of the User SessionsSelect to capture usernames.
Use Terminal Name for End User LocationWhen capturing user sessions, use the IP resolved from the first 20 characters of the terminal name instead of the SAP returned user IP. This is useful when the application server does not know the client IP, for example when the users connect via SAP Router.Reduces overhead on SAP application server, but lowers the granularity in charts and delays data retrieval. During heavy load on the SAP application server this might cause the SAP server to not send all user actions to Dynatrace.
Report on RFC Client/Server MetricsSelect whether to only report on the servers communicating to/from the SAP Application server, or to additionally split up the metrics on individual function names.
Capture Usernames as part of the Per Function Call RFC MetricsInclude Usernames as a dimension when capturing RFC Metrics Per Function Call
Poll Less OftenReduces overhead on SAP application server, but lowers the granularity in charts and delays data retrieval. During heavy load on the SAP application server this might cause the SAP server to not send all user actions to Dynatrace.
Enable Debug LoggingSelect this only if a Dynatrace product expert requests it to investigate an issue.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly, the extension has to collect at least one metric after the activation.
Dialog Metrics
Metric nameMetric keyDescription
GUI User countsap.guiusercount
Dialog response timesap.guiresponsetime
Dialog stepssap.guidialogsteps
Dialog network timesap.guinetworktime
Task Metrics
Average task timesap.Task.avgtottime
Average timesap.avgtime
Dialog stepssap.Task.dialogsteps
CPU timesap.Task.cputime
Database timesap.Task.dbtime
Roll in timesap.Task.rollintime
Roll wait timesap.Task.rollwaittime
Load + generation timesap.Task.loadgentime
Database callssap.Task.dbcalls
User countsap.Task.usercount
Job Metrics
Job Countsap.job.count.gauge
Job Status Countsap.job.status_count.gauge
Job Avg Durationsap.job.avg_duration
Job Max Durationsap.job.max_duration
Job Avg Delaysap.job.avg_delay
Job Max Delaysap.job.max_delay
default
Availabilitysap.avail
Application Server Instance Metrics
Runtime errorssap.runtimeErrorsByCat
Connected userssap.sessions
CPU time/Response time ratiosap.cpuratio
Wait time/Response time ratiosap.waittimeratio
Load time/Response time ratiosap.loadtimeratio
Database time/Response time ratiosap.dbtimeratio
Threshold Metrics
50% boundarysap.fiftyline
10% boundarysap.tenline
2% boundarysap.twoline
RFC Metrics
RFC Incoming Execution Timesap.rfcIncomingExecutionTime
RFC Incoming Call Timesap.rfcIncomingCallTime
RFC Incoming Receive Bytessap.rfcIncomingReceive
RFC Incoming Send Bytessap.rfcIncomingSend
RFC Incoming Requestssap.rfcIncomingRequests
RFC Outgoing Execution Timesap.rfcOutgoingExecutionTime
RFC Outgoing Call Timesap.rfcOutgoingCallTime
RFC Outgoing Receive Bytessap.rfcOutgoingReceive
RFC Outgoing Send Bytessap.rfcOutgoingSend
RFC Outgoing Requestssap.rfcOutgoingRequests
FAQ
What is the Custom Metric Usage of this extension?
The formula for consumption of the extension depends on the enabled feature set.
  • Default: 2 * <# of App Servers>
  • Threshold Metrics 3 * <# of App Servers>
  • Application Server Instance Metrics: 21 * <# of App Servers>
  • Tasks Metrics: ((8 * <# of Tasks configured>) + 8) * <# of App Servers>
  • Dialog Metrics: 4 * <# of App Servers>
  • Jobs Metrics: 6 * < # of Jobs>
  • RFC Metrics:
    Depending on your configuration
    • Per Remote Destination: 10 * < # of Remote Destinations > * <# of App Servers>
    • Per Function Call: 10 * < # of Remote Destinations > * <# of Program Names> * <# of Location Destinations> * <# of client numbers> * <# of user ids> * <# of function names> * <# of App Servers>
Related tags
ComputePythonABAPSAPInfrastructure Observability
