Monitor your Luna Network Hardware Security Module (HSM) Devices through SNMP.
This extension collects infrastructure metrics to monitor the health and performance of your Luna HSM devices.
Metrics are collected via SNMP protocol.
Simply activate the extension in your environment using the in-product Hub, provide the necessary device configuration and you’re all set up.
Read more in the SNMP extension data source documentation.
The extension package contains:
Calculations are based on the assumption that you monitor all metrics for every feature set every minute:
DDUs: 20 + (8 * Partitions) + (1 * Licenses) + (1 * Policies) + (1 * Partition policies) + (1 * Client registrations) + (1 * Client partitions) * 525.6 DDUs/year, per device
DPS (Metric data points): 20 + (8 * Partitions) + (1 * Licenses) + (1 * Policies) + (1 * Partition policies) + (1 * Client registrations) + (1 * Client partitions) * 525,600 metric data points/year, per device
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly, the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Luna HSM Client Assignment | hsm.luna.clientpartition.assignment | Placeholder metric for client assignment dimensions (only dimension data is relevant) |
| Luna HSM Uptime | hsm.luna.table.uptime | The number of seconds the HSM has been up since the last HSM reset |
| — | com.dynatrace.extension.network_device.sysuptime | — |
| Luna HSM Busy time | hsm.luna.table.busytime | The number of seconds the HSM has been busy since the last HSM reset |
| Luna HSM Command Count | hsm.luna.table.command_count | The number of HSM commands processed since the last HSM reset |
| Luna HSM Admin login attempts remaining | hsm.luna.table.admin_login_attempts | The number of failed Administrator login attempts remaining before HSM is zeroized. |
| Luna HSM Performance | hsm.luna.table.performance | The performance level of the HSM |
| Luna HSM Partitions free | hsm.luna.table.partitions.free | The number of partitions that can still be created on the HSM |
| Luna HSM Partitions created | hsm.luna.table.partitions.created | The number of partitions created on the HSM |
| Luna HSM Partitions maximum | hsm.luna.table.partitions.maximum | The maximum number of partitions allowed on the HSM |
| Luna HSM Storage available | hsm.luna.table.storage.available_bytes | The number of available bytes on the HSM |
| Luna HSM Storage allocated | hsm.luna.table.storage.allocated_bytes | The number of allocated bytes on the HSM |
| Luna HSM Storage capacity | hsm.luna.table.storage.total_bytes | The total storage capacity in bytes of the HSM |
| Luna HSM License | hsm.luna.license | Placeholder metric for license info dimensions (only dimension data is relevant) |
| Luna HSM Policy | hsm.luna.policy | Placeholder metric for HSM policy info dimensions (only dimension data is relevant) |
| Luna HSM Client Registration | hsm.luna.client | Placeholder metric for HSM Client Registration info dimensions (only dimension data is relevant) |
| Luna HSM partition storage capacity | hsm.luna.partition.storage.total_bytes | Storage capacity in bytes of the partition |
| Luna HSM partition allocated bytes | hsm.luna.partition.storage.allocated_bytes | Number of allocated (in use) bytes on the partition |
| Luna HSM partition available bytes | hsm.luna.partition.storage.available_bytes | Number of available (unused) bytes on the partition |
| Luna HSM partition object count | hsm.luna.partition.object_count.gauge | Number of objects in the partition |
| Luna HSM Operation requests | hsm.luna.operation.requests | Indicates the total number of HSM operations requested |
| Luna HSM Operation errors | hsm.luna.operation.errors | The total number of HSM operations requested which have resulted in errors |
| Luna HSM Critical events | hsm.luna.events.critical | The total number of critical HSM events detected |
| Luna HSM Non-critical events | hsm.luna.events.noncritical | The total number of non-critical HSM events detected |
| Luna HSM NTLS Status | hsm.luna.ntls.oper_status | The current operational state of the NTLS |
| Luna HSM NTLS connected clients | hsm.luna.ntls.connected_clients | The current number of connected clients of the NTLS |
| Luna HSM NTLS links | hsm.luna.ntls.links | The current number of links of the NTLS |
| Luna HSM NTLS successful client connections | hsm.luna.ntls.client_connections.successful | The total number of successful client connections of the NTLS |
| Luna HSM NTLS failed client connections | hsm.luna.ntls.client_connections.failed | The total number of unsuccessful client connections of the NTLS |
| Luna HSM Partition Policy | hsm.luna.partition.policy | Placeholder metric for partition policy dimensions (only dimension data is relevant) |
