Troubleshoot your Dynatrace Kubernetes monitoring and Prometheus integration.
Investigate Kubernetes API server interactions with this ready-made dashboard.
Troubleshoot your Kubernetes and Prometheus integration setup with a ready-made dashboard. The extension allows you to investigate interactions between Dynatrace and the Kubernetes API server.
If you want to monitor additional Kubernetes environments, please refer to our Kubernetes extension.
To enable the extension, find Kubernetes Monitoring Statistics in the Dynatrace Hub.
Once you have enabled the extension, you need to set up custom events:
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
