Infoblox DDI extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor Infoblox DDI using SNMP
Overview dashboardInfoblox Unified Analysis screen
1 of 2Overview dashboard
The Infoblox DDI SNMP Extension is a powerful tool designed to enhance network management capabilities by integrating Infoblox DDI with Dynatrace via SNMP monitoring.
Get started
Overview
The extension allows network administrators to monitor and manage their Infoblox DDI infrastructure using standard SNMP protocols, providing a seamless and efficient way to ensure network reliability and performance. Dynatrace's Unified Analysis screens provide at-a-glance access and analysis for your Ops, DevOps and IT Admins.
Use cases
  • Get insights into network performance and health.
  • Streamline network management tasks with automated monitoring and alerts.
  • Identify and resolve issues before they impact network operations.
  • Minimize network downtime with timely alerts and proactive measures.
Activation and setup
Activate the extension in your environment web-UI using the Dynatrace Hub. Simply provide the necessary device configuration, and Dynatrace will automatically deploy the extension and begin monitoring.
For details, see SNMP extension documentation.
Details
The extension package contains:
  • SNMP data source configuration for metric ingestion.
  • Topology definitions for Infoblox devices.
  • Dashboards offering monitoring overviews.
  • Unified Analysis pages for each created entity.
The extension is built on top of the SNMP data source that is part of Dynatrace's Extensions 2.0 framework.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
Metric nameMetric keyDescription
com.dynatrace.extension.network_device.memory_used
CPU Usagesnmp.infoblox.ddi.cpu.usageInfoblox DDI CPU Usage (ibSystemMonitorCpuUsage)
com.dynatrace.extension.network_device.cpu_usage
com.dynatrace.extension.network_device.sysuptime
Service statussnmp.infoblox.ddi.service.statusPlaceholder metric will also report a value of 1. Dimensions (Name, Status, Desc) contain data
Node Service statussnmp.infoblox.ddi.node.service.statusPlaceholder metric will also report a value of 1. Dimensions (Name, Status, Desc) contain data
Access count queriessnmp.infoblox.dhcp.ibDHCPSubnetPercentUsedPercentage of dynamic DHCP address for subnet leased out at this time. Fixed addresses are always counted as leased for this calculation if the fixed addresses are within ranges of leases.
Allocation Unitssnmp.infoblox.storage.AllocationUnitsThe size, in bytes, of the data objects allocated from this pool. If this entry is monitoring sectors, blocks, buffers, or packets, for example, this number will commonly be greater than one. Otherwise this number will typically be one.
Raw Storage Sizesnmp.infoblox.storage.SizeThe size of the storage represented by this entry, in units of hrStorageAllocationUnits.
Raw Storage Usedsnmp.infoblox.storage.UsedThe amount of the storage represented by this entry that is allocated, in units of hrStorageAllocationUnits.
Failed queriessnmp.infoblox.dns.ibBindZonePlusViewFailure.countNumber of Failed queries since DNS process started.
Average non-authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5AvgLatencyAverage latency for incoming DNS queries during the last 5 minutes where the reply was non authoritative
Non-authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5CountNumber of queries used to calculate the average latencies during the last 5 minutes where the reply was non-authoritative
Average authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSAAT5AvgLatencyAverage latency for incoming DNS queries during the last 5 minutes where the reply was authoritative
Authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSAAT5CountNumber of queries used to calculate the average latencies during the last 5 minutes where the reply was authoritative
Related tags
NetworkSNMPDNS, DHCPInfobloxInfrastructure Observability
