Monitor your files and folders.
Monitor your files on Windows and Linux OneAgent installations.
Targeting can be done by host, host group, management zone or environment. Tags can be applied to segregate your configurations (100 configurations maximum).
For each path check, Dynatrace will create an entity and link it to the matching host. This way, extension filtering and tagging is possible to view your data. The same can be done with alerts.
/var/log/myapp:
check type = count/var/log/myapp/*.logc:\temp:
check type = countc:\temp\*.log/var/log/myapp and any subdirectories:
check type = count/var/log/myapp/**/*.logmydir inside /tmp exist?
check type = count/tmp/mydir/tmp:
check type = count/tmp/*/var/log/myapp:
check type = size/var/log/myapp/*/tmp/test/:
check type = modification age/tmp/test/*/tmp/test:
check type = modification age count/tmp/test/*.log/data/mount-data is mounted:
check type = mount point/data/mount-data/var/mylog20222211.log:
check type = count/var/mylogYYYYMMDD.logDDMMYYYY, DD-MM-YYYY, DD_MM_YYYY, YYYYMMDD, YYYY-MM-DD, YYYY_MM_DD.When a schedule is not selected, the check will run 24/7. If the check should not be performed on a Sunday, select schedule and unselect Sunday.
You can add time windows by entering the start time; use the semi colon for multiple windows. For each time, the schedule duration field will be added to determine the end. This example only runs from 10:00 and 12:00 for 1 hour.
On Linux the extension supports local file systems as long as the dtuser account can see the files. The file must be at least readable by the dtuser if not, it will be invisible to the extension. If you wish to use another account then use the run_as functionality to sudo -u <username> to switch to a user with permissions.
On Windows, The file must be at least readable by LOCAL SERVICE if not, it will be invisible to the extension.
dtuser or the run_as user has permissions.run as the user must be able to login locally.
.\usernamesudo on the checks to elevate privileges.
sudo -u <username> command However, sudo requires the calling user to have permissions. dtuser must be setup passwordless as before above.sesu -<user> -c commandChecks can be disabled for specific days and at specific times.
Go to the Filesystem extension in the Dynatrace Hub.
Create a new configuration.
For each check, select Add check.
Select the check type and enter the relevant details, and then, select Next.
Enter a description for your configuration and select Activate.
Wait until the state of the deployment changes from pending to ok. This might take several minutes.
To view your data, go to the Data explorer.
In the metric box type, select filesystem and select the relevant metric. You can split metrics by host and path, for example.
To drill down to the host or file check, hover on a data point and select View path or View host list.
/var/log/myapp:
sudo -u <username> command However, sudo requires the calling user to have permissions. dtuser must be setup passwordless as before above.sesu -<user> -c commandWhen activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
If you are not getting the expected results, typically a metric with the value 0 (file size or count for instance) or -1 (file age), it's because the extension doesn't have sufficient privileges to see the folder content. The files are invisible to the extension and it will report the value 0 or -1.
Grant access to all users first in the location and try again. The value should be correct. Once done, narrow down the access to the correct account or group.
Don't use the file size metric for calculating the size of big volumes/mount points recursively such as c:\\**, as it will scan each file and time out. The same applies to the other metrics when using recursive search with a very large number of files or sub directories.
For more information on which user runs the oneAgent, see:
To create alerts, see metric events for alerting.
