Monitor your Control-M jobs execution status.
Control-M enables you to automate the scheduling and processing of your business workflows across various platforms and applications.
Monitor, understand and troubleshoot these business-critical assets with the Control-M extension.
Find the extension in Dynatrace Hub to and add it to your environment.
Add a monitoring configuration. This is a remote extension and runs on an ActiveGate of an ActiveGate group of your choice. Set the following configuration parameters:
URL
The address for the Control-M automation API to query.
Username
Username used for authentication against the Control-M automation API.
Password
Password for the above user.
Server
If this parameter is set, the API call will receive a server filter, effectively retrieving only jobs that belong to the specified server.
Folder
If this parameter is set, the API call will receive a folder filter, effectively retrieving only jobs that belong to the specified folder.
Filter job by name
List of rules used to filter the jobs whose specific status and execution logs will be reported. As long as the job verifies one of the rules, its status and execution log will be reported to Dynatrace. Use this feature to exclude irrelevant jobs or to include important ones only. The excluded jobs will still be taken into account for the aggregated metrics. This filtering is handled on the data returned from API.
Filter job by folder name Same as above, but using its folder’s name instead, in case there are complete folders that can be ignored or included. A job will be monitored if it verifies at least one of the rules, independently of if it’s a job’s name or folder’s name rule.
Send error events
If this flag is on, Dynatrace will generate an error event (and its subsequent problem) in Dynatrace if a job has a failed execution status, regardless of if the job is filtered in or out.
Debug
Produces more verbose logs. Enable only when troubleshooting or support makes that recommendation.
Feature sets
Lastly, select which feature sets (metric groups) you would like this configuration to collect. You can choose to monitor the summary of how many jobs are in each state and/or the individual job status.
If the configuration parameter for Send error events is enabled, the extension will send an error event whenever any job is in a Ended Not OK status. This event will be attached to the job entity.
As an alternative, it is possible to create a metric event based on the controlm.job.status metric for whenever a job is in an unwanted state, where it is also possible to attach the event to any of the generic types created by the extension.
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Job number of runs | controlm.job.number_of_runs | Number of runs that a job has individually had. |
| Job status | controlm.job.status | Metric that indicates the current status of each job. A value of 100 equals a job that ended correctly, a value of 0 indicates a job that ended incorrectly, was not found in AJF or has an unknown state. A value of 50 indicates a job in the middle of execution. A value of 25 indicates a job that is waiting. |
| Jobs waiting for condition | controlm.job_counters.wait_condition | Number of jobs with state "Waiting For Condition" |
| Jobs ended ok | controlm.job_counters.ended_ok | Number of jobs with state "Ended OK" |
| Jobs being executed | controlm.job_counters.executing | Number of jobs with state "Executing" |
| Jobs waiting for resource | controlm.job_counters.wait_resource | Number of jobs with state "Waiting For Resource" |
| Jobs waiting for user | controlm.job_counters.wait_user | Number of jobs with state "Wait User" |
| Jobs waiting for host | controlm.job_counters.wait_host | Number of jobs with state "Waiting For Host" |
| Jobs ended not ok | controlm.job_counters.ended_not_ok | Number of jobs with state "Ended Not OK" |
| Jobs with unknown state | controlm.job_counters.unknown | Number of jobs with an unknown state |
| Jobs not in AJF | controlm.job_counters.not_in_ajf | Number of jobs with state "Not In AJF(Active Job File)" |
