Gain insights into the performance of your Check Point Firewall devices.
Monitor health state and performance of your Check Point Firewall devices and provide a unified analysis for Ops, DevOps and IT Admins.
The Check Point Firewall extension leverages the SNMP protocol to provide a complete solution to monitor Check Point Firewall Devices. The extension is built on top of the Extension 2.0 Framework and its complete configuration is provided out-of-the-box.
Use this extension to:
down state.
Infrastructure & Operations for an overview of all monitored Network Devices in the environment.For more information about the configuration, see SNMP Extension Documentation.
The extension package contains:
For more information, see Simplified observability for your SNMP devices.
The Check Point Firewall extension runs most SNMP queries every minute. Once data is produced, it's ingested as metric datapoints and is subject to license consumption. Whether you are on a Classic or DPS license model, the measurement unit for metric ingestion is based on metric datapoints.
Below is a breakdown of metrics by feature set only including metrics collected once per minute (there are two metrics in the default feature set that are collected at a 30 minute interval):
default: 7 x Check Point Firewall Devices + 3 x Check Point Firewall InterfacesCheck Point Device: 15 x Check Point Firewall DevicesInterfaces: 9 x Check Point Firewall Interfaces
For example, if there is a monitoring configuration with all feature sets enabled, containing 1 Check Point Firewall with 1 Interface, the estimated yearly datapoint consumption can be calculated by the following formula:
33 x 60 x 24 x 365 = 17,344,800 metric datapoints per year
In the classic licensing model, metric ingestion will consume Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point.
Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For more information about licensing costs, see Extending Dynatrace (Davis data units) or Metrics powered by Grail overview (DPS) depending on your license model.
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Bytes in | checkpoint.firewall.if.bytes.in.count | Number of octets received on the interface |
| Packets in | checkpoint.firewall.if.packets.in.count | Number of packets received on the interface |
| Bytes out | checkpoint.firewall.if.bytes.out.count | Number of octets sent on the interface |
| Packets out | checkpoint.firewall.if.packets.out.count | Number of packets sent on the interface |
| Errors in | checkpoint.firewall.if.errors.in.count | Number of packets with errors received on the interface |
| Errors out | checkpoint.firewall.if.errors.out.count | Number of packets with errors sent on the interface |
| Oper status | checkpoint.firewall.if.status.oper | Current operational state |
| Admin status | checkpoint.firewall.if.status.admin | Desired state of interface |
| Speed | checkpoint.firewall.if.speed | Estimate of interface's current bandwidth |
| Device entity attributes | checkpoint.firewall.entity_attributes | Constant value of 1 used for reporting entity attributes at a lower frequency |
| Physical component state | checkpoint.firewall.component.state | A state metric representing the details of physical components. This is used to collect details about the device stack. Value is always 1; use the dimensions to view details. |
| — | com.dynatrace.extension.network_device.sysuptime | — |
| — | com.dynatrace.extension.network_device.cpu_usage | — |
| — | com.dynatrace.extension.network_device.memory_used | — |
| — | com.dynatrace.extension.network_device.memory_free | — |
| — | com.dynatrace.extension.network_device.if.bytes_in.count | — |
| — | com.dynatrace.extension.network_device.if.bytes_out.count | — |
| — | com.dynatrace.extension.network_device.if.status | — |
| Disk percent | checkpoint.firewall.disk.percent | Percent of free space |
| Users connected | checkpoint.firewall.users.connected | Number of connected users |
| Accepted packets | checkpoint.firewall.packets.accepted.count | Accepted packets |
| Dropped packets | checkpoint.firewall.packets.dropped.count | Dropped packets |
| Logged packets | checkpoint.firewall.packets.logged.count | Logged packets |
| Rejected packets | checkpoint.firewall.packets.rejected.count | Rejected packets |
| Number of connections | checkpoint.firewall.connections | Number of connections |
| Peak number of connections | checkpoint.firewall.connections.peak | Peak number of connections |
| Active real memory | checkpoint.firewall.memory.active.real | Active real memory |
| Active virtual memory | checkpoint.firewall.memory.active.virtual | Active virtual memory |
| Free real memory | checkpoint.firewall.memory.free.real | Free real memory |
| Processor system time | checkpoint.firewall.cpu.time.system | Processor system time |
| Processor usage | checkpoint.firewall.cpu.usage | Processor usage |
| Processor user time | checkpoint.firewall.cpu.time.user | Processor user time |
| System uptime | checkpoint.firewall.sysuptime | The system up time since boot, in system ticks (hundredths of a second) |
To troubleshoot this extension, use the guides available in the Dynatrace Community, and Dynatrace Documentation.
