Enhanced insights for Spark Components
Apache Spark collects JMX metrics to provide insights into spark performance.
JMX metrics provide insights into resource usage, job and application status, and performance of your spark components.
Apache Spark metrics are presented alongside other infrastructure measurements, enabling in-depth cluster performance analysis of both current and historical data.
The extension enables insights into the overall health of Spark component instances.
Dynatrace Activate this extension in your Dynatrace environment from the in-product Hub and simply select which OneAgents to enable this on.
Spark You must configure the required component metrics to be reported to the JMX sink.
$SPARK_HOME/conf/metrics.properties
For example, you can enable metric collection to the JmxSink for the master, worker, driver and executor components with a command such as:cat << EOF > $SPARK_HOME/conf/metrics.properties*.sink.jmx.class=org.apache.spark.metrics.sink.JmxSinkmaster.source.jvm.class=org.apache.spark.metrics.source.JvmSourceworker.source.jvm.class=org.apache.spark.metrics.source.JvmSourcedriver.source.jvm.class=org.apache.spark.metrics.source.JvmSourceexecutor.source.jvm.class=org.apache.spark.metrics.source.JvmSourceEOF
Refer to the Spark documentation for more details
This extension can query and collect almost all component instance and namespace metrics as defined in Spark Metric Providers
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| master.workers | spark.master.workers | — |
| master.aliveWorkers | spark.master.aliveWorkers | — |
| master.apps | spark.master.apps | — |
| master.waitingApps | spark.master.waitingApps | — |
| worker.executors | spark.worker.executors | — |
| spark.worker.coresUsed | spark.worker.coresUsed | — |
| spark.worker.memUsed_MB | spark.worker.memUsed_MB | — |
| spark.worker.coresFree | spark.worker.coresFree | — |
| spark.worker.memFree_MB | spark.worker.memFree_MB | — |
| mesos_cluster.waitingDrivers | spark.mesos_cluster.waitingDrivers | — |
| mesos_cluster.launchedDrivers | spark.mesos_cluster.launchedDrivers | — |
| mesos_cluster.retryDrivers | spark.mesos_cluster.retryDrivers | — |
| executor.bytesRead.count | spark.executor.bytesRead.count | — |
| executor.bytesWritten.count | spark.executor.bytesWritten.count | — |
| executor.cpuTime.count | spark.executor.cpuTime.count | — |
| executor.filesystem.file.largeRead_ops | spark.executor.filesystem.file.largeRead_ops | — |
| spark.executor.filesystem.file.read_bytes | spark.executor.filesystem.file.read_bytes | — |
| spark.executor.filesystem.file.read_ops | spark.executor.filesystem.file.read_ops | — |
| spark.executor.filesystem.file.write_bytes | spark.executor.filesystem.file.write_bytes | — |
| executor.filesystem.file.write_ops | spark.executor.filesystem.file.write_ops | — |
| executor.recordsRead.count | spark.executor.recordsRead.count | — |
| executor.recordsWritten.count | spark.executor.recordsWritten.count | — |
| executor.succeededTasks.count | spark.executor.succeededTasks.count | — |
| applicationMaster.numContainersPendingAllocate | spark.applicationMaster.numContainersPendingAllocate | — |
| spark.applicationMaster.numExecutorsFailed | spark.applicationMaster.numExecutorsFailed | — |
| applicationMaster.numExecutorsRunning | spark.applicationMaster.numExecutorsRunning | — |
| applicationMaster.numLocalityAwareTasks | spark.applicationMaster.numLocalityAwareTasks | — |
| applicationMaster.numReleasedContainers | spark.applicationMaster.numReleasedContainers | — |
| streaming.inputRate-total | spark.streaming.inputRate-total | — |
| streaming.latency | spark.streaming.latency | — |
| streaming.processingRate-total | spark.streaming.processingRate-total | — |
| streaming.states-rowsTotal | spark.streaming.states-rowsTotal | — |
| streaming.states-usedBytes | spark.streaming.states-usedBytes | — |
| shuffleService.numActiveConnections.count | spark.shuffleService.numActiveConnections.count | — |
| shuffleService.numRegisteredConnections.count | spark.shuffleService.numRegisteredConnections.count | — |
| shuffleService.numCaughtExceptions.count | spark.shuffleService.numCaughtExceptions.count | — |
| shuffleService.registeredExecutorsSize | spark.shuffleService.registeredExecutorsSize | — |
| appStatus.stages.failedStages.count | spark.appStatus.stages.failedStages.count | — |
| appStatus.stages.skippedStages.count | spark.appStatus.stages.skippedStages.count | — |
| appStatus.stages.completedStages.count | spark.appStatus.stages.completedStages.count | — |
| appStatus.tasks.excludedExecutors.count | spark.appStatus.tasks.excludedExecutors.count | — |
| appStatus.tasks.completedTasks.count | spark.appStatus.tasks.completedTasks.count | — |
| appStatus.tasks.failedTasks.count | spark.appStatus.tasks.failedTasks.count | — |
| appStatus.tasks.killedTasks.count | spark.appStatus.tasks.killedTasks.count | — |
| appStatus.tasks.skippedTasks.count | spark.appStatus.tasks.skippedTasks.count | — |
| spark.appStatus.tasks.unexcludedExecutors.count | spark.appStatus.tasks.unexcludedExecutors.count | — |
| appStatus.jobs.succeededJobs.count | spark.appStatus.jobs.succeededJobs.count | — |
| appStatus.jobs.failedJobs.count | spark.appStatus.jobs.failedJobs.count | — |
| appStatus.jobs.jobDuration | spark.appStatus.jobs.jobDuration | — |
| BlockManager.disk.diskSpaceUsed_MB | spark.BlockManager.disk.diskSpaceUsed_MB | — |
| BlockManager.memory.maxMem_MB | spark.BlockManager.memory.maxMem_MB | — |
| BlockManager.memory.maxOffHeapMem_MB | spark.BlockManager.memory.maxOffHeapMem_MB | — |
| BlockManager.memory.maxOnHeapMem_MB | spark.BlockManager.memory.maxOnHeapMem_MB | — |
| BlockManager.memory.memUsed_MB | spark.BlockManager.memory.memUsed_MB | — |
| BlockManager.memory.offHeapMemUsed_MB | spark.BlockManager.memory.offHeapMemUsed_MB | — |
| BlockManager.memory.onHeapMemUsed_MB | spark.BlockManager.memory.onHeapMemUsed_MB | — |
| BlockManager.memory.remainingMem_MB | spark.BlockManager.memory.remainingMem_MB | — |
| BlockManager.memory.remainingOffHeapMem_MB | spark.BlockManager.memory.remainingOffHeapMem_MB | — |
| BlockManager.memory.remainingOnHeapMem_MB | spark.BlockManager.memory.remainingOnHeapMem_MB | — |
| ApplicationSource.status | spark.ApplicationSource.status | — |
| ApplicationSource.runtime_ms | spark.ApplicationSource.runtime_ms | — |
| ApplicationSource.cores | spark.ApplicationSource.cores | — |
| HiveExternalCatalog.fileCacheHits.count | spark.HiveExternalCatalog.fileCacheHits.count | — |
| HiveExternalCatalog.filesDiscovered.count | spark.HiveExternalCatalog.filesDiscovered.count | — |
| HiveExternalCatalog.hiveClientCalls.count | spark.HiveExternalCatalog.hiveClientCalls.count | — |
| HiveExternalCatalog.parallelListingJobCount.count | spark.HiveExternalCatalog.parallelListingJobCount.count | — |
| HiveExternalCatalog.partitionsFetched.count | spark.HiveExternalCatalog.partitionsFetched.count | — |
| LiveListenerBus.numEventsPosted.count | spark.LiveListenerBus.numEventsPosted.count | — |
| LiveListenerBus.queue.appStatus.numDroppedEvents.count | spark.LiveListenerBus.queue.appStatus.numDroppedEvents.count | — |
| LiveListenerBus.queue.appStatus.size | spark.LiveListenerBus.queue.appStatus.size | — |
| LiveListenerBus.queue.eventLog.numDroppedEvents.count | spark.LiveListenerBus.queue.eventLog.numDroppedEvents.count | — |
| LiveListenerBus.queue.eventLog.size | spark.LiveListenerBus.queue.eventLog.size | — |
| DAGScheduler.job.activeJobs | spark.DAGScheduler.job.activeJobs | — |
| DAGScheduler.job.allJobs | spark.DAGScheduler.job.allJobs | — |
| DAGScheduler.messageProcessingTime.count | spark.DAGScheduler.messageProcessingTime.count | — |
| DAGScheduler.messageProcessingTime.oneminuterate | spark.DAGScheduler.messageProcessingTime.oneminuterate | — |
| DAGScheduler.messageProcessingTime.mean | spark.DAGScheduler.messageProcessingTime.mean | — |
| DAGScheduler.stage.failedStages | spark.DAGScheduler.stage.failedStages | — |
| spark.DAGScheduler.stage.runningStages | spark.DAGScheduler.stage.runningStages | — |
| DAGScheduler.stage.waitingStages | spark.DAGScheduler.stage.waitingStages | — |
