Business processes are the automation backbone of modern businesses, and they must operate efficiently to meet business goals. Most business processes can impact customer experience, either positively or negatively. From procurement to order fulfillment, from customer onboarding to service request tracking, most organizations rely on hundreds, if not thousands, of business processes. These business processes depend on your IT systems to achieve their business goals efficiently and at scale.
Use Business Flow to monitor and optimize business processes. Gain real-time visibility into key performance indicators and detailed analytics to improve customer satisfaction, increase efficiency, and reduce cost.
With Business Flow, you can:
This article is intended for business analysts and process managers who understand how their businesses are performing in real time and look for optimal execution of their business processes. You should have a basic knowledge of how business events are captured and some domain knowledge of the business area you are trying to analyze.
Required
order_id). The name of the correlation ID may differ between steps; the value is used to connect steps into a single flow.Recommended
Business Flow reports three standard KPIs: Average duration, errors, and conversions. You can also add a business KPI of your choice.
In many cases, process duration is one of the most important indicators of process health. Many process optimization initiatives focus on reducing delays. In Business Flow, the average duration KPI represents end-to-end elapsed time. For each step, the average duration to the subsequent step(s) is also reported. These values help to focus improvement efforts on process "hot spots."
See a screenshot of Business Flow Details.
See a screenshot of KPIs over time.
You can analyze any process flow in detail.
For in-progress flows at any step, select the step box in the main tree panel. From the right-hand panel, choose Explore, then select the step of interest.
You can open the resulting table in a Notebook for deeper exploratory analytics.
When a process step takes longer than normal to reach a subsequent step, it is flagged as a drop. It may be stuck permanently, or it may simply be experiencing an unusually long delay.
For a list of the dropped flows at any step, select the step box in the main tree panel. In the right panel, you can filter to only show dropped.
For business exceptions, select a step box in the main tree panel that shows business exceptions; from the right-hand panel, filter by Business exceptions, then select the unique flow of interest.
Here’s a brief list of some common business processes. Your organization will have a large portfolio of business processes, most of which are likely unmonitored. See a sampling list of such processes below.
Business Flow
