Set up Business Flow
  • Latest Dynatrace
  • How-to guide
  • 3-min read
To set up Business Flow Business Flow
  1. Open Business Flow Business Flow and select Business Flow to get to the configuration page.
  2. Select the icon and rename the Configuration. In the same place, you can also describe the business flow. For example, you can create a payment process flow called ACME Payment Process.
Define your first step
  1. In the rightmost side panel, under Step 1, select Add event dropdown under Events, and choose a business event to specify a step completion.
    • You can add up to five events for each step.
    • The Add event dropdown lists the event.type and event.provider combinations found in your environment, and the result is truncated at 10,000 combinations. In high-cardinality environments, some business events might not appear in the dropdown.
    • To narrow the set of combinations that Business Flow Business Flow collects, define a bucket that contains the business events for this configuration and scope the configuration to it. For details, see Scope queries to specific buckets.
  2. Name the step by selecting Step 1 name in the side panel.
Define more steps
  1. In the main panel tree, hover over Step 1 box, and select Add tab at the bottom of the step box to add the next step.
    You can also add previous steps and generate a branch. Those steps can't be reordered.
    • To create a previous step, select Add tab at the top of the Step 1 box.
    • To generate a branch, select at the bottom of the Step 1 box. If there is (at least) one step after the Step 1, you can create a (new) branch.
    • To define a step as a loop (a step that can happen several times), select on the right side of the Step 1 box.
    • To bypass steps or branches, you can connect a step to another step that is ahead by two, or more steps in the business flow.
  2. Continue adding further steps until your business flow is complete.
Add the correlation ID
  1. In the rightmost side panel, set the default correlation ID in the app settings .
    • The default correlation ID entered here is applied to all steps.
    • Optional local correlation IDs override the default setting and can be defined for each relevant step.
  2. The Correlation ID field is pre-filled with the default correlation ID. If an event associated with this step uses a different correlation ID, enter the new name in the Correlation ID field located in the detail view of the selected step (the rightmost side panel).
Add business exceptions
Some events can indicate a business exception; for example, an out-of-stock event. Select the events that are designated as Business exception in a step.
Set the optional business KPI
  1. In the rightmost panel, find the app settings .
  2. Select Mapping event dropdown field and choose the business event that contains the attribute to use to calculate the KPI.
  3. Select Mapping attribute from event dropdown field and choose the KPI. Only attributes that are of type long or double are shown.
  4. Close the Advance settings configuration window.
  5. Select Validate & Save configuration.
Example of steps with correlation IDs (global and local) and business KPI
Step nameCorrelation IDBusiness KPI
Place order
order_id
Order confirmed
order_id
order_amount
Order shipped
order_id
Order delivered
order_number
Set a business flow configuration as an entity
A business flow configuration can be ingested in Smartscape on Grail as a new entity that ties critical business processes with your IT entities as hosts or process group instances.
Having a business flow as an entity allows Problems app - new Problems to find relationships between an IT-detected problem with any of the critical business processes that Business Flow Business Flow is monitoring. In addition, Problems app - new Problems displays which business processes are impacted by the problem, allowing drill down into Business Flow Business Flow in problems investigation mode.
  1. Set up a business flow as an entity.
  2. Define the priority level of the business process (low, medium, high, or critical).
A business flow as entity can be seen in Notebooks exploring Smartscape nodes with the type BIZ_FLOW
SmartscapeNodes BIZ_FLOW
| fields id, type, name
With a result like follows
IDTypeName
BIZ_FLOW-000000001CD85158
BIZ_FLOW
Purchase order
BIZ_FLOW-FFFFFFFFF4557E37
BIZ_FLOW
Employee onboarding
Recommendations
To fully leverage the capabilities provided when a business flow is defined as an entity, configure at least a two‑step business flow with a correlation ID. This improves traceability across steps and ensures more accurate mapping to topology entities.
Optionally, define business KPIs to enhance observability and provide greater insight into business performance. We also recommend verifying that the business events defined in each step include topological entities when data is captured by OneAgent, which improves Smartscape connectivity and enables more accurate impact analysis.
Monitoring KPIs
When a business flow is defined as an entity, Dynatrace automatically enables basic KPI monitoring. The platform runs DQL queries on a scheduled basis to evaluate each KPI and generates standardized business events that follow the Semantic Dictionary guidelines for Business Flow KPI events. These DQL queries are executed by a platform service user, which means they will appear in your system usage metrics and consumption reports.
To see the bytes scanned and billed by this platform service user, run the following query in your Dynatrace environment:
fetch dt.system.events
| filter event.kind == "BILLING_USAGE_EVENT"
| filter contains(user.email,"biz-analytics")
Both the generation frequency and evaluation timeframe for these KPIs are user-configurable. We recommend setting the evaluation timeframe to at least three to four times the average duration of the monitored business process. This ensures accurate KPI evaluation and avoids missing data windows for long‑running processes.
Generated data is stored in Grail with a default retention period of 35 days. You can adjust this retention time by creating a custom bucket based on the event.types defined in the Dynatrace Semantic Dictionary.
By default, Business Flow Business Flow analysis queries run across all bizevent buckets in your environment. In high-volume environments, this means queries scan data that is not relevant to the process you monitor, increasing scanned bytes and DPS license consumption.
Bucket scoping lets you limit analysis queries—and the Anomaly Detection DQL derived from them when alerting in business KPI metrics—to only the buckets that contain data for a given configuration.
Configure bucket scoping
  1. In Business Flow Business Flow, select Edit flow to open the edit mode.
  2. Go to the Business event buckets section. In Selected buckets, choose one or more buckets that contain the business events for this configuration.
  3. Select Save changes.
All subsequent queries for this configuration are limited to the selected buckets.
We do not recommend auto-select buckets in Business Flow Business Flow.
You must identify the buckets that contain the relevant business events for your process.
What bucket scoping applies to
Once a bucket scope is defined, it applies consistently to:
  • Edit mode queries—when collecting event.type and event.provider, it only fetches the ones that are stored in the selected buckets.
  • Analysis queries—all fetch bizevents DQL queries run from Business Flow Business Flow analysis view scan only the selected buckets.
  • Anomaly Detection DQL—the anomaly detection query derived from this configuration when defining alerts on business KPIs applies the same bucket scope, so alerting and analysis are always based on the same data.
Related tags
Business FlowBusiness FlowBusiness Observability
