Configure ActiveGate for memory dump storage
  • How-to guide
  • 4-min read
  • Published Jan 08, 2019
Applicable to Environment ActiveGate and Cluster ActiveGate
The following configuration of ActiveGate for memory dump storage is applicable to both Environment ActiveGate and Cluster ActiveGate.
When your application experiences memory leaks or high object churn, it’s important that you get memory dumps so you can analyze these issues. In production environments, this is often a challenge when you can’t log into the environment and you have no other means of triggering memory dumps. Dynatrace enables you to both trigger and securely download memory dumps to the analysis tool of your choice. To enable memory dumps, you need to configure your ActiveGate as described below.
If you configure an ActiveGate to collect memory dumps, and then restart the ActiveGate service, all instances of OneAgent will automatically reconnect and recognize that the ActiveGate can now store memory dumps. From now on, whenever a memory dump is successfully triggered, the dump will be uploaded automatically to the correct ActiveGate. Once safely stored on the ActiveGate, the OneAgent deletes the local file from its storage. Note that OneAgent automatically deletes a memory dump on the original host after one hour.
Before you begin
Familiarize yourself with the basic rules for working with ActiveGate configuration.
Activate dump functionality
Create the [collector] section in the custom.properties file, if it doesn't already exist. Specify the DumpSupported property in this section and set the value to true.
[collector]
DumpSupported = true
Specify dedicated dump directory (Optional)
Unless configured otherwise, ActiveGate saves memory dumps in a default directory.
To use a custom path, specify the path in the properties file and create the directory with appropriate permissions:
Create the [dump] section in custom.properties (if it doesn't already exist) and then specify the dumpDir property in this section. For example:
[dump]
dumpDir = dump
The dumpDir property can contain a relative path, for example, dumpDir = mydir. In this case, the directory will be a subdirectory of the default location. It can also be an absolute path, for example, dumpDir = C:\data\memory-dumps.
Create the directory, if it does not already exist, and make sure that it has correct access permissions for the user running the ActiveGate service. This is by default dtuserag for Linux, and Local Service for Windows:
  • Linux systems:
    Read, Write, and Execute
  • Windows systems:
    Read, Write, and Modify
    Example of dump directory permissions on Windows
    Dump directory permissions
Use of /temp or /tmp under Linux
Because of possible automatic purging, we recommend that you not use the Linux directories /temp, /tmp, or their subdirectories to install ActiveGate or store any data generated or used by ActiveGate.
Specify parameters for managing dump files (Optional)
Also in the [dump] section, you can specify the following properties:
PropertyDefault valueDescription
dumpDirdumpValid path of the storage directory used for dump storage
maxSizeGb100Storage quota in GBs. If full, the oldest dumps are overwritten until enough space is available to store a new dump.
maxAgeDays7Maximum age of a memory dump in days until the dump is automatically overwritten
maxConcurrentUploads5Maximum number of concurrent dump uploads from OneAgents
downloadUrlunsetA custom download URL. This is particularly useful if ActiveGate is behind a load balancer to manage end-user traffic or if ActiveGate only detects an IP address and an FQDN is required by the user. Note that a load balancer should not be placed between ActiveGate and OneAgent, as this can disrupt memory dump functionality. The URL must contain the correct schema and port.
Restart ActiveGate
If you modify your ActiveGate configuration, you must restart the ActiveGate main service to put your changes into effect.
Example custom.properties file contents
[collector]
[dump]
# relative to collector root dir or absolute path
dumpDir = dump
# maximum size in GB for stored memory dump
maxSizeGb = 100
# maximum age in days for keeping stored memory dumps
maxAgeDays = 7
# maximum number of concurrent file uploads supported
maxConcurrentUploads = 5
Related tags
Application ObservabilityProfiling & OptimizationProfiling & Optimization
