Connection Pools WebSphere Liberty extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Collect the connection pool performance, usage and availability metrics for Websphere Liberty.
Easily monitor all your Websphere Liberty connection pools in your environment thanks to the overview dashboard, automatically included with the extension activation.Get detailed insights into each individual connection pool thanks to the customized screen that comes with each instance of the automatically generated Liberty Connection Pool generic type.
1 of 2Easily monitor all your Websphere Liberty connection pools in your environment thanks to the overview dashboard, automatically included with the extension activation.
Get started
Overview
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Use cases
This extension collects connection pool performance, usage and availability metrics for Websphere Liberty.
Compatibility information
Activation and setup
  1. Install OneAgent on the virtual machine or server of your Websphere process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the Liberty Connection Pool Overview dashboard.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
Metric nameMetric keyDescription
Managed connectionsliberty.connectionPool.managedConnectionCount
In use connectionsliberty.connectionPool.connectionHandleCount
Free connectionsliberty.connectionPool.freeConnectionCount
In use timeliberty.connectionPool.inUseTime
Wait timeliberty.connectionPool.waitTime
Related tags
ApplicationJMXConnection poolIBMInfrastructure Observability
