Connection Pools WebLogic extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Collect the connection pool performance, usage and availability metrics for Oracle Weblogic.
Monitor all your connection pools for Weblogic closely by analyzing their data directly on the Unified Analysis screen for each connection pool individually.
1 of 1Monitor all your connection pools for Weblogic closely by analyzing their data directly on the Unified Analysis screen for each connection pool individually.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Get started
Overview
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Apache Commons.
Use cases
  • Collect the connection pool performance, usage and availability metrics for Oracle Weblogic.
Compatibility information
Activation and setup
  1. Install OneAgent on the virtual machine or server of your Oracle Weblogic process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the Weblogic Connection Pool Overview dashboard.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
Metric nameMetric keyDescription
Statement cache sizeweblogic.connectionPool.prepStmtCacheCurrentSize
Statement cache hitsweblogic.connectionPool.prepStmtCacheHitCount.count
Statement cache missesweblogic.connectionPool.prepStmtCacheMissCount.count
Stuck thread countweblogic.stuckThreads
Hogging thread countweblogic.hoggingThreads
Active connectionsweblogic.connectionPool.activeConnectionsCurrentCount
Current capacityweblogic.connectionPool.currCapacity
Leaked connectionsweblogic.connectionPool.leakedConnectionCount.count
Available connections (idle)weblogic.connectionPool.numAvailable
Waiting for connectionsweblogic.connectionPool.waitingForConnectionCurrentCount
Failed connection requestsweblogic.connectionPool.failedReserveRequestCount.count
Reconnection failuresweblogic.connectionPool.failuresToReconnectCount.count
Requests for connectionsweblogic.connectionPool.reserveRequestCount.count
Current message countweblogic.currentMessages
Pending message countweblogic.pendingMessages
Total message countweblogic.totalMessages
Max capacityweblogic.connectionPool.maxCapacity
Related tags
ApplicationJMXConnection poolOracleInfrastructure Observability
