Connection Pools C3P0 extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Collect the connection pool performance, usage and availability metrics for C3P0.
Quickly glance over the status of your C3P0 connection pools accross your whole environment with the included dashboard with the extension.Get insights into a specific connection pool thanks to the granularity of the metrics and their segregation into the new generic entities generated by the extension automatically.
1 of 2Quickly glance over the status of your C3P0 connection pools accross your whole environment with the included dashboard with the extension.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Get started
Overview
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Wildfly, and C3P0.
Use cases
  • Collect the connection pool performance, usage and availability metrics for C3P0.
Compatibility information
Activation and setup
  1. Install OneAgent on the virtual machine or server of your JBoss process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the C3P0 Connection Pool Overview dashboard.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
Metric nameMetric keyDescription
Max Pool Sizec3p0.connectionPool.maxPoolSize
Num Connectionsc3p0.connectionPool.numConnections
Num Busy Connectionsc3p0.connectionPool.numBusyConnections
Num Unclosed Orphaned Connectionsc3p0.connectionPool.numUnclosedOrphanedConnections
Num Idle Connectionsc3p0.connectionPool.numIdleConnections
Num Active threadsc3p0.connectionPool.threadPoolNumActiveThreads
Thread Pool Sizec3p0.connectionPool.threadPoolSize
Related tags
ApplicationJMXConnection poolMachinery for changeInfrastructure Observability
