Collect the connection pool performance, usage and availability metrics for JBoss, identify potential issues with the utilization of the connection pool, and monitor both Non-XA and XA connection pools.
Connection Pools allow you to monitor connection pool performance and identify issues such as connection leaks.
Several built-in OneAgent extensions provide an insight into the connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, and Red Hat JBoss and Wildfly.
Java Metric Extensions 2.0 (JMX).This extension package contains :
This extension is built on top of the new Extension 2.0 Framework.
This extension queries for data every minute. Once data is produced, this is ingested as metric datapoints and is subjected to license consumption. Whether you are on a Classic or DPS license model, the measurement unit for metric ingestion is based on metric datapoints.
To estimate the amount of metric datapoints produced by your extension configuration, use the following list which gives you a number of metrics per feature set and a multiplier value depending on the number of connection pools being monitored. Add all of these up, and you will have the number of datapoints produced every minute.
Connection pool time XA: 9 x number of connection pools.Connection pool XA: 5 x number of connection pools.Connection pool: 5 x number of connection pools.Connection pool time: 9 x number of connection pools.For example, a monitoring configuration that contains one connection pool where all feature sets are activated produces 28 metric datapoints per minute.
By extrapolation, it will ingest:
28 x 60 x = 1,680 metric datapoints per hour.28 x 60 x 24 = 40,320 metric datapoints per day.28 x 60 x 24 x 365 = 14,716,800 metric datapoints per year.Since JMX Extensions run on OneAgent-monitored hosts, they are subjected to included metrics per host unit.
Please refer to the following documentation depending on the license type:
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Total blocking time (XA) | jboss.connectionPool.TotalBlockingTimeXA.count | — |
| Total get time (XA) | jboss.connectionPool.TotalGetTimeXA.count | — |
| Total creation time (XA) | jboss.connectionPool.TotalCreationTimeXA.count | — |
| Total usage time (XA) | jboss.connectionPool.TotalUsageTimeXA.count | — |
| Total pool time (XA) | jboss.connectionPool.TotalPoolTimeXA.count | — |
| Max pool size (XA) | jboss.connectionPool.maxPoolSizeXA | — |
| Active count (XA) | jboss.connectionPool.ActiveCountXA | — |
| Available count (XA) | jboss.connectionPool.AvailableCountXA | — |
| Created count (XA) | jboss.connectionPool.CreatedCountXA.count | — |
| Destroyed count (XA) | jboss.connectionPool.DestroyedCountXA.count | — |
| Idle count (XA) | jboss.connectionPool.IdleCountXA | — |
| In use count (XA) | jboss.connectionPool.InUseCountXA | — |
| Timed out (XA) | jboss.connectionPool.TimedOutXA.count | — |
| Wait count (XA) | jboss.connectionPool.WaitCountXA.count | — |
| Max pool size | jboss.connectionPool.maxPoolSize | — |
| Active count | jboss.connectionPool.ActiveCount | — |
| Available count | jboss.connectionPool.AvailableCount | — |
| Created count | jboss.connectionPool.CreatedCount.count | — |
| Destroyed count | jboss.connectionPool.DestroyedCount.count | — |
| Idle count | jboss.connectionPool.IdleCount | — |
| In use count | jboss.connectionPool.InUseCount | — |
| Timed out | jboss.connectionPool.TimedOut.count | — |
| Wait count | jboss.connectionPool.WaitCount.count | — |
| Total blocking time | jboss.connectionPool.TotalBlockingTime.count | — |
| Total creation time | jboss.connectionPool.TotalCreationTime.count | — |
| Total pool time | jboss.connectionPool.TotalPoolTime.count | — |
| Total get time | jboss.connectionPool.TotalGetTime.count | — |
| Total usage time | jboss.connectionPool.TotalUsageTime.count | — |
