Grants permission to control opt-in/opt-out code monitoring for the entire environment or by scope.
Example policy:
ALLOW settings:objects:read, settings:objects:write, settings:schemas:read WHERE settings:schemaId = "builtin:devobs.agent.optin";
Grants permission to manage Live Debugging breakpoints.
Example policy:
Allow managing breakpoints across the environment:
ALLOW dev-obs:breakpoints:manage;
If your application's code is being transpiled or bundled, you need to include the source maps, either in-line or as separate files.
inline-source-map
or source-map
values for the devtool
option in the Webpack config file.inline
, both
or true
values for the sourceMaps
option in the Babel config file.inlineSourceMap
or sourceMap
fields to true
as well as inlineSources
to true
in the TypeScript config file.-M
(inline) or -m
flags to the coffee CLI tool.sourceMap
to true
(setting inlineSourceMap
isn’t enough in this case) in the TypeScript config file and use either the inline-source-map
or source-map
option in the Webpack config file.Live Debugger works with uglified/minified code if it's provided with source maps. However, mangling (changing of variable names) should not be applied. Webpack may automatically mangle variable names when used in production.
const TerserPlugin = require("terser-webpack-plugin");module.exports = {// ...optimization: {minimizer: \[new TerserPlugin({terserOptions: {mangle: false,},})],},};
When debugging within a remote environment, you need to know exactly what source code it is executing.
Live Debugger integrates with your source control provider to fetch the correct source code for every environment.
Configure the following environment variables to enable automatic source code fetching:
DT_LIVEDEBUGGER_COMMIT
- String that indicates your git commitDT_LIVEDEBUGGER_REMOTE_ORIGIN
- String that indicates your git remote originFor multiple sources, use the environment variable DT_LIVEDEBUGGER_SOURCES
to initialize the SDK with information about the sources used in your application.
is a semicolon-separated list of source control repository and revision information, joined by #
. For example: DT_LIVEDEBUGGER_SOURCES=https://github.com/myorg/MyRepo#abc123;https://github.com/otherorg/OtherRepo#xyz789
In JVM languages, you can also specify a path to JAR, which must contain the following attributes in its JAR manifest:
DT-LiveDebugger-Repository
DT-LiveDebugger-Revision
Then you can have a combination of URLs and paths to JARs.
Example: DT_LIVEDEBUGGER_SOURCES=https://github.com/myorg/MyRepo#abc123;/path/to/lib.jar
Live Debugger offers data masking rules to let you control sensitive data, giving you the ability to specify which data it should not collect and display to users.
You can set the data masking rules through the Live Debugger Settings page.
Go to Settings > Observability for Developers > Sensitive data masking.
Configure data masking by adding rules with a set of matchers that identify your sensitive data.
Select Add rule to start configuring your rule.
Set Name to the name to display for your configuration.
Select the rule type:
Redact by variable name
When masking by variable name, the entire value of any variable matching that name will be redacted.
For example, adding a rule for the variable name secretKey
replaces the output secretKey:12345
with secretKey:\*\*\*
Redact by regex
When masking by regular expression, all variable values matches to that expression will be redacted.
For example, adding a rule regarding the variable value \[0-9]+
will replace nameAndPassword:LordHelmet-12345
with nameAndPassword:LordHelmet-\*\*\*\*
Defined rules can be reordered, and they are executed in the order in which they appear on the Sensitive data masking page.
The redacted data is replaced, by default, with the string \*\*\*
You can choose a custom string for the rule, or replace it with an SHA-256 hash. For example, adding a rule for the variable name secretKey
with a custom replacement of REDACTED
with secretKey:REDACTED
